LG Rear Projection Television Model RT-56NZ23RB -LG Rear Projection Television Model RT-56NZ23RB -horizontal and vertical outputs checked..still going on for 10 second with sound and than switches off
LG Rear Projection Television Model RT-56NZ23RB -switches on for 10 seconds with sound but no screen and than just switches off..What can i do???
    Scholar:
  • 195 Answers
SOunds like a loss of B+ to the horizontal ckt. possibly bad convergence chips and one or more open fuses .
Posted on May 08, 2014
3 Suggested Answers
SOURCE: LG Rear Projection Television Model RT-56NZ23RB - Fault
For my LG TV - LG RT-56NZ23RB, I replaced two STK 392-120 chips and it has fixed convergence problem now.
Posted on Jun 09, 2008
  • 356 Answers
SOURCE: lg rt 56nz23rbLG Rear Projection Television Model RT-56NZ23RB -switches on for 10 seconds with sound but no picture and than switches off by going into stand by position.The horizontal and vertical ou
Thus problem sounds like you have some failed capacitors on the power supply circuitry. I have had this problem on an older TV and it was solved by replacing the popped caps. Do not try this repair yourself, unless you are confident you can do so safely! Also make sure that you unplug everything before poking around inside!
Posted on Mar 19, 2014
Testimonial: "Thanx Robert..see what i`ll do tomorrow and let you know..Cheers"
Lg rt 56nz23rbLG Rear Projection Television Model RT-56NZ23RB -switches on for 10 seconds with sound but no picture and than switches off by going into stand by position.The horizontal and vertical outputs...
Mar 19, 2014 | Televison & Video
My 51' hitachi hdtv television make a clicking noice when on
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 24, 2009 | Hitachi 57F500 57" Rear Projection...
No sound.
thank u!!!
rate me
Jul 02, 2009 | LG 62SX4D 62" Television
I have a Mitsubishi CS-3125R that displays a horizontal line with sound. I suspect the horizontal transistor is out and cannot find one. Any ideas?
You are misleading yourself. When you have a horizontal line across the screen it means that the vertical circuit is not working. You see, the vertical circuit moves the beam up and down which is not happening. The horizontal circuit moves the beam left and right and it is working. Your set probably needs a new vertical output IC and some electrolytic capacitors that work with it. The caps dry up with time and harm the output IC.
Jun 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Lg rt 56nz23rb
Hi there.
Replace the stk convergence ics and also the 3.9 0hm fusible resistors.
Sep 20, 2008 | LG RU-52SZ51D 52" Rear Projection...
Check your horizontal output and regulators also vertcal output.You have a deflection problem either Horizontal or vertical outputs or one of the regulators are faulty. Let me know if you require more assistance.
Feb 02, 2008 | Televison & Video
Need help
does the light blink? if so how many times?
Jan 22, 2008 | Philips 50P8341 50" Rear Projection...
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Televison & Video
Hitachi 60 in rear projection tv
If the picture is jumping from top to bottom this is a vertical issue. The common cause on older Hitacjis is loose connections on the vertical output IC.
Jan 28, 2007 | Hitachi 60EX01B 60" Rear Projection...
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
