Question about Liebherr Refrigerators
Liebherr kgt 4025
There is no temperature in the cooler
2 Suggested Answers
  • 586 Answers
SOURCE: The wine cooler temperature on
The cause of the failure arises from one of these components, either the relay switch is bad or the thermostat regulator.
Either one of them can cause the problem, have a friend that is good with such device run a check on the both the relay switch and the thermostat regulator, that way the problem will easily be detected and solved easily.
It is not a major problem, it is just a minor failure in the unit that will be corrected for just a token. It most times caused by the thermostat regulator. Once it begins to fail, these are the kind of symptoms it shows.
Hope this was helpful to you.
Goodluck
Elect_Comp
Posted on Jun 28, 2011
Stop water collecting at the bottom of a 3046
What about the drain tube? Also, check to see if there is a rubber flap or "duckbill" valve on the drain tube. Sometimes the rubber on them gets soft and will stick, not allowing the water to drip past them.
Oct 18, 2014 | Liebherr KGT 3046 Premium
Liebherr problems
Is the temperature, inside, of the freezer, at least zero? Other than that, good luck.
Sep 07, 2014 | Liebherr Refrigerators
Hello, my problem is that the freezer does not freeze, does a bit of below and already this ****-frost, some solution thank you.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 18, 2011 | Liebherr KGT 3546 Premium
Ice build up inside refrigerator Liebherr K3150
may be you have a bad temperature sensor or bad control board.
Mar 01, 2010 | Liebherr K3150 Refrigerator
Need info on electrical hook up from heater to thermostat for sauna heater
Hello
First you have to find out the electrical requirements for the sauna. Is there a transformer or is it line voltage? That means does the power go directly from the thermostat to the heater at full voltage, or to a transformer that brings the voltage down first then to the heater.
John
Jan 01, 2010 | Liebherr KGT 3031 Comfort
We have a liebherr 7082 214 model. We cannot set the temparature for the freezer. after a few seconds the temperature digits disappear and two flashing lights appear
The two flahing lights are normal if the freezer is warm. It will display temperature when it gets cold. If it doesn't get cold there is another problem.
Jul 31, 2008 | Liebherr Refrigerators
Fridge and frezeer not working
Liebherr embraco compressor....compressor fluid leaked while moving, what is the fluid? is it easy to replace?
Dec 06, 2007 | Liebherr KTS 1534 Comfort Compact...
Refrigerators Logo
59 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
