Pure one mini series 2 stuck on setting clock
Radio displaying setting clock. Do I remove the battery
KaeZoo
  • 156 Answers
SOURCE: How do I set the clock
1. While pressing the BND button, press the DISP button to display the clock display. 2. While pressing the BND button, press and hold the DISP button for two seconds or longer. 3. Press the Left button, then set the current hour. 4. Press the Right button, then set the current minute. 5. Press the BND button, then the clock is set. You can download a user's manual from this link: http://www.clarion.com/us/en/MungoBlobs/615/523/DRX5575(Manual).pdf
Posted on Jun 24, 2007
Diesel13
  • 11 Answers
SOURCE: Problems after car battery replacement
Sounds to me like you've got a fualty radio. maybe your clock radio was staying on and thats what drained your old battery. I would remove your radio and check the wiring. make sure you don't have any rubbed through wires or anything. If there's no evidence of faulty wiring then try a new cd player. After all, it could be an electrical issue inside your cd player. hope this helps ya out. O and by the way your clock light should be a yellow wire in the back of the head unit i beleive. the yellow wire is constant power from the battery specifically for the clock. you may also want to check your orange wire. that wire is an illumination wire for the radio. hope this helps
Posted on Oct 31, 2008
  • 136 Answers
SOURCE: setting clock on pioneer radio
you will need to turn unit off then press function button for a few seconds this will take you to the clock function.
Posted on Sep 05, 2009
  • 3 Answers
SOURCE: I recently moved my Legato Pure radio, now I have
Clearly, the DAB signal strength is poorer in the new radio position. Try moving it, even a foot or two can make a difference. Better still, use a roof aerial.
The display can be changed, even in standby mode - press the Display button to see the 3 options.
Posted on May 30, 2010
SOURCE: Pure DAB radio not coming
On all PURE products you have the option of being able to return the product to its original factory settings. As well as being useful for fully re-tuning the radio, a reset effectively 're-boots' the product's operating system which removes any user settings such as presets and timer/alarm settings. A reset can often resolve any anomalies found.
tip.gif Note: You will need to re-enter your network security information after performing a factory reset. Make sure you have your network security key to hand before performing a reset or you will not be able to re-connect your radio to the internet.
Instructions for EVOKE Flow/AVANTI Flow/ Oasis Flow/ ONE Flow: Make sure your radio is switched on. Press and hold the 'Options' button down for two or three seconds and confirm the reset when prompted.
Instructions for Sensia: Make sure your radio is switched on. Tap 'Settings', tap 'Update' and tap 'Factory Reset'. Confirm the reset when prompted.
Instructions for Siesta Flow: Make sure your radio is switched on. Press and hold the 'Options' button down for three or four seconds and confirm by pressing the 'YES' button when prompted.
Posted on Mar 08, 2011
How do I un-freeze my Pure One mini radio?
Try removing the power sourse, wait a few seconds, then restoring it. Hopefully it will clear this problem.
May 29, 2016 | Pure Protein Pure One Mini Series Ii...
Pure digital radio
Give it a firm thwack with the palm of your hand. I did that to mine and it started working again!
May 14, 2013 | Pure Digital Pure FMDAB Radio
How do I set the alarm so it will activate on weekdays. It only works for Saturday and Sunday. Thanks
Hello
Sure Alarm battery Back-Up System
This SmartSet® Clock Radio includes a Sure Alarm battery back-up circuit that can
wake you up even if the power is 'Off'at the selected wake up time. If your power
is 'Off'at the selected wake up time the clock display will be off and the radio will
not operate, but a separate mini-buzzer will turn 'On'automatically to wake you up,
even if you had selected the "Wake to Radio"option.
The Sure Alarm will sound for 30 seconds and then shut off automatically.
To stop the Sure Alarm buzzer immediately, press the RADIO ON/OFF button.
Pressing the SNOOZE button has no effect during Sure Alarm operation.
Note: In order to maximize the life of the built in lithium battery, please be sure
to set the ALARM 1 and ALARM 2 switches to the "OFF"position if the radio
will be disconnected from the AC outlet for more than a few hours. This will
prevent the Sure Alarm from turning 'On'unnecessarily.
1.) Depress and hold either the ALARM 1 or ALARM 2 setting button.
The display will change from the correct time
to the Alarm 1 or Alarm 2 wake up time.
2.) While holding the ALARM 1 or ALARM 2 setting button, depress either the
SET + or - button to move the display ahead or back to your desired wake up
time.
3.) When the desired wake up time appears on the display, release the SET + or
- buttons.
Note: Be sure that you have set the wake up time correctly by observing
the AM indicator. If the AM indicator is 'On'the wake up time is "AM". If the
AM indicator is 'Off', the wake up time is "PM".
4.) When the desired wake up time (AM or PM) appears on the display, release
the ALARM 1 or ALARM 2 setting buttons
Apr 20, 2011 | Emerson Smartset Clock Radio
How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
  • 3
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
  • 4
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    My dewalt radio charges, but has no display and wont play anything at all
    Try this if the display seems stuck on the same station: If you take off the front of the radio (don't forget 2 screws in back!) you will notice a set of black and red wires running from the 2 AA backup batteries to the digital display circuit board. The wires plug into the board with a little white plug. If you unplug this the display will fade to nothing. If you plug it back in it will display an unset digital clock format. This seems to reset the radio, after which it should work.
    Feb 07, 2011 | Dewalt DC011 AM/FM Radio
    My dewalt stopped giving any sound
    Nov 11, 2010 | Dewalt DC011 AM/FM Radio
    I recently moved my Legato Pure radio, now I have trouble tuning in the DAB radio and the display struggles to set the clock often flashing with a message saying it is wating for time to set. When it does...
    Dec 19, 2009 | Audio Players & Recorders
    Change Clock - Logitech Pure-Fi Elite
    hold the src button left of power along with button to the right power.a model number will appear once it does let it disappear and the unit will go into reset. set the language, 12/hr, 24hr etc and the time. :)
    Dec 13, 2008 | Logitech Pure-Fi Elite High Performance...
    Emerson Jumbo Display CKS2237 clock radio
    Sorry it took so long to get back to you with a answer to your question. You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
    Oct 05, 2008 | Emerson Smartset Clock Radio
    Computers & Internet Logo
    David Payne
    David Payne
