Question about VeriFone Televison & Video
Hypercom t4230 setting APN di EDC
I have a zte z832 unlocked cricket phone and I put my life wireless SIM card from the lifeline free phones in the phone and need to set the APN ..does anyone know the APN to set to this phone?
  • type it in exactly as it appears below.
  • APN: wholesale
  • APN type: default,mm,supl
  • Proxy: not set
  • Port: not set
  • Username: not set
  • Password: not set
  • Server: not set
  • MMSC: http://wholesale.
    mmsmvno.com
    /mms/wapenc
  • MMS Proxy: not set
  • MMC: 310
  • MNC: 260
  • Authentication type: not set
  • APN Protocol: IPv4
  • APN roaming protocol: IPv4
  • APN enable/disable: APN enabled
  • Bearer: unspecified
  • MVNO type: none
  • MVNO value: not set
Press the Menu key and save. Reboot your phone and test your data connection by opening a web page.
Oct 20, 2017 | ZTE Cell Phones
How do I repair, cc machine will not print
PDF]Hypercom t7 Plus User Manual - PaperRollsPlus
paperrollsplus.com/.../Hypercom.../Hypercom_t7_Plus_User_Manual.pd...
Oct 25, 2003 - Your old machine may qualify for a generous trade in value. Visit: www..... T7Plus Terminal Overview . ... Credit Card Sale with CVV2 Data .
Nov 03, 2015 | Hypercom T7Plus Credit Card Machine
Samsung s4 I deleted the apn on accident how can I get them back
Every carrier uses its own APN Settings to get its 3G/4G LTE network working on an Android smartphone or tablet device. Now, these APN settings are usually "downloaded" automatically to your phone when you insert a SIM card. BUT, there are times where the APN are not selected automatically OR when the APN settings are not downloaded.
In those instances, your 3G/4G LTE data will not work but that can easily be fixed.
Step 1. First, browse your Settings menu and find the "Access Point Names" menu. This is usually under "Mobile Network Settings" or "More Mobile Networks" or "Mobile Networks" under Settings menu depending on the Android device used.
Step 2. Once you are in the APN Settings menu, first thing you should check it that the APN is on the correct one. If the correct APN is not checked (sometimes this happens), simply check ON the correct APN for your carrier. That will make your 3G/4G LTE data working right away.
Step 3. There are also times where the wrong APN is listed or there's simply no APNs listed. In these rare cases, you can simply add a new APN, hit the "+" button. 25264381-evzu5111kn4ie1titkzzffdn-4-2.jpg
Step 4. For APN setting, the "Name" can be anything. "APN" setting is the most important, usually you only have to fill this out for your phone to work.
Step 6. Hit "Save" when done.
Step 7. Next, make sure to select the new APN Setting you have saved. Within 5-30 seconds, your phone should start picking up 3G or 4G LTE signals and your data should be working again on the phon 25264381-evzu5111kn4ie1titkzzffdn-4-14.jpg
Nov 01, 2014 | Cell Phones
Hypercom t7plus is asking for a password for t.i.d. whats that?
Default Password for the Hypercom T7 Plus is: 0000
The default programming password for the T7Plus is 028510
Hypercom T7 Plus 1 MB
Apr 27, 2014 | Intel Xircom CreditCard Performance Series...
Di ako makapagfb using myphone Q19i...paano po b dapat gawin para makakonekta ako gamit ko ung cp n un? ty.
APN Settings for Globe, Smart, Sun, WeRoam Cellular
The following settings are applicable to Smart, Globe and Sun Cellular for their APN settings (Access Point Name). The settings should work with majority of smartphones in the market.
Postpaid APN: internet.globe.com.ph
Prepaid APN: http.globe.com.ph
APN Settings for Smart Bro
Postpaid APN: smartbro
Prepaid APN: smartbro
APN Settings for Smart Buddy, Smart Gold
APN: internet
APN Settings for Sun Cellular
Prepaid
APN (static): minternet
Authentication: PAP
IP address: dynamic
Postpaid
APN (static): fbband or minternet
Authentication: PAP
IP address: dynamic
APN Settings for PLDT WeRoam
Postpaid: WEROAMPLANor internet
Note: If you’re using a variety of postpaid or prepaid SIM cards in one dongle, make sure to create a Setting Profile for each SIM card so it’s easier to set the APN when switching SIM cards.
Leave all other settings blank or as is.
Mar 05, 2014 | Computers & Internet
I have a problem with my Man Truck TGA 33.360, Its showing alot of error codes on dashboard EDC 00959-01, EDC 00960-01, EDC 00961-01, EDC 00962-01. What could be the problem?
I have an answer for you.The codes are coming from a lost Tachometer memory.Yoour Edc Control Unit and teh Tachometer are not correctly aligned.You need to have th Tachometer reprogrammed.It has lost memory
1.EDC:00959-01 >seconds-Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
2. EDC:00960-01>minutes- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
3. EDC:00961-01>hour- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
4. EDC:00962-01>Day- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
5. EDC:00963-01>Month- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
6. EDC:00964-01>Year- Action-Tachometer has lost memory and is not aligning with the Edc Control unit. mixture of time and date>Tachometer to be reprogrammed.
Nov 15, 2012 | Bruder MAN TGA Container Service Truck
Is my Credit Terminal Locked. Hypercom T4220
hi
someone has the Hypercom T4200 KLA unlock
Mar 26, 2012 | Computers & Internet
How do we enable our Hypercom T7p printer- we changed the paper and it says disabled- I have been onhold with hypercom for 15 minutes.
To Fix it.
Blue Function + 71 Enter
Printer is Disabled
Enabled? Yes/No
Hit Enter for Yes
http://www.gorillapaper.com/hypercom-t7p-t-thermal-terminal.html
May 16, 2010 | Office Equipment & Supplies
Hypercom T4100 credit card machine, blank screen
It's done! :) He gave you a DSN of a different Hypercom model (e.g. Hypercom t4220) and it destroyed the machine! No way it can go back to Maintenance screen! Done! Only Equinox can fix it and they charge more than the price of the machine itself! :) Sorry!
Apr 03, 2010 | Office Equipment & Supplies
Error in coonection with internet
if u want to use Net On Phonesteps to follow
  1. set home page http://live .airtelworld.co.in  (customizable)
  2. set Data Account  NOP (or GPRS)
  3. set connection type HTTP
  4. set proxy port 8080
  5. set proxy address 100.001.200.099
set APN airtelwap.com  enjoy!!!!
Apr 23, 2009 | LG KP202 - Pay as you go Cellular Phone
Televison & Video Logo
Top VeriFone Televison & Video Experts
AliennoisE
Andrew Taylor
Andrew Taylor
Are you a VeriFone Televison and Video Expert? Answer questions, earn points and help others
