Question about Nikon N70 35mm SLR Camera
The door latch on my nikon n75 film camera is broken.
Can I get the parts and replace it myself? Can it be replaced?
    Brigadier General:
  • 3,006 Answers
Parts are scarce unless you get them from a scrap camera. If the broken bit is on the body then it's not worth bothering. If it's on the door then it's fairly easy to swap the door from a donor camera.
But as you can buy an n75/F75 in virtually as new condition for under £50 on auction websites you have to decide whether a repair is cost effective.
Posted on Jul 06, 2009
Who can repair the film door latch?
Any camera shop can send this out for repair or to get an estimate. It may not be repairable due to parts not being available.
Feb 01, 2012 | Nikon N75 35mm SLR Camera
The film magazine stuck in the Canone EOS 10 camera, never happened that before, i could easily insert and remove the film. it's rewinded, luckily, but I need a new one to put there, + I'm afraid if I...
Nikon N75 or Canon EOS 10????????
How is the film stuck? Is the rear door stuck? Does the film door open?
As long as you do not damage the film canister, the film will be ok. If the door opens and the film is rewound, use something to pry out the top of the canister from the camera. Then you can remove the film.
Even a film roll of 36 should not get stuck. Check the cartridge are for anything sticky. Sometimes these older cameras get some sticky residue from decaying foam in the shutter area. This would be a good time to send it in for CLA - Clean, Lubricate, Adjust.
My own EOS 10 had that problem. If you can't get the film out, the repair shop will do that for you.
Jan 20, 2010 | Nikon N75 35mm SLR Camera
Film door latch broken
Nikon doesn't supply the film door any more. You can buy a repair kit from USCamera.com to replace the latch on the film door
Jan 02, 2010 | Nikon N6006 35mm SLR Camera
Back of camera will not close looks like small piece of plastic has broken
Yes, the film door was always a problem on these. The entire door was usually replace since it was one piece with the latch.
I do not believe that Nikon supplies the part any more. You can check eBay for a dead camera, or possibly a new /used door.
The other option is a repair kit available from USCamera.com
Dec 14, 2009 | Nikon N6006 35mm SLR Camera
Broken latch on film door
Usually on this level Nikon it was a plastic "hook", part of the door moulding, that was retained by the latch mechanism in the body. The broken part may still be in there - if it is trip the latch and recover it with a tiny screwdriver or even a needle. If you can't find a replacement back door you can try welding the hook back in place with a low-temperature soldering iron - with the tip perfectly clean and a very steady hand - as long as the door is thermoplastic and not thermosetting. If that doesn't work bend a paperclip or similar to exactly the right shape with the free ends (roughened) long enough to extend into the plastic of the door by 4-5mm., heat the wire and push slowly into the edge of the door. There are many variations of this technique that I've used, all require extremely careful work! Best tip: spend more time thinking than doing. Good luck.
Nov 28, 2009 | Nikon N70 35mm SLR Camera
Camera film door will not latch. The door latch
Can it be repaired? It needs a new latch piece. Maybe a new door, if its all one piece.
I do not own one so not sure about that model. Look at the door hinge. If a small lever sticks out of the hinge, it may be easily removed and replaced with a new door. otherwise you need to remove the bottom plate of the camera to replace the door. Be very careful doing so as things could pop out when you open it.
You could also send it in to a repair shop, where they will also clean, lubricate and adjust it before returning.
Is it worth it? Only you can answer that. You might be able to pickup a used one on Ebay, so you have a source of parts.
If you have no reason to keep that particular camera, replace it with a newer Nikon, so you can keep using your flash and lenses.
Oct 04, 2009 | Nikon N6006 35mm SLR Camera
Latch for the Film door broke
This is so tedious a job that I would not try it myself unless I was adept in doing this right.Unless the camera costs a lot to start with, I would just get another SLR. I believe the cost in repairing it depending on model and the size, will be about $200. I say this because from experience, I had a $250 camera 20 years ago and the latch broke on mine and he said it would not be worth it to fix it. Unfortunately, it was way out of warranty.
Jan 16, 2009 | Nikon F80 35mm Film Camera
Nikon N75 - error message, nothing working.
You have to reset the rewind counter by pushing the two buttons simultaneously - one on the side of the lens mount, the other by the release button - red, cassette symbols. This tells the camera there's no film in it.
Nov 30, 2008 | Nikon N75 35mm SLR Camera
Nikon N65 Film Camera Broken latch
You have to replace the whole door. There is one on eBay, but you won't like the price. Find it here: eBay
Mar 15, 2008 | Nikon N65 35mm SLR Camera
N75 will not load film
Quick solution: force a manual rewind.
1. Remove film
2. Close camera back.
3. With the power turned on, press the two rewind buttons together. They are marked in red.
4. The camera will make a rewind sound and will stop after about 2 seconds.
5. DO NOT fire the shutter yet.
6. Put the mode on Manual and select a fast shutter speed like 1/90 sec. Any aperture will do.
7. Load the film correctly as given in the user's manual.
8. As you close the camera back, the film will prewind to the end of roll. At the end of the roll pre-wind the LCD will show you the total number of frames available.
9. Select any shooting mode.
10. Go on and take pictures.
Hope this helps
Dec 14, 2006 | Nikon N75 35mm SLR Camera
Nikon N70 35mm SLR Camera Logo
379 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
