Question about Tools & Hardware - Others
Cutting a new counter top for a sink
I need to cut the opening for a sink in a new laminate counter top
  • 52 Answers
If you are installing a basic stainless steel sink into a laminate over particle board counter top-
Find the center of the sink along the legnth of the counter and mark the counter. Measure the sink from the top. Lay out the edges on the counter. Place the sink upside down on the counter and align with your marks. Trace around the sink in pencil. Subtract the distance to the flange where the clips slide in. Draw a new line inside the first one. This is your cut line. Check that when you make the cut that you will not hit the face frame of the cabinet. Move the sink back if needed and make new marks. Some cabinets are a tight fit. Cut the hole for the sink with a jigsaw. Start with the back line first. You may find on a counter with a back splash the jigsaw will not fit. Drill an 1/8" hole to mark the underside and cut from the bottom of the counter. Use a 1" spade bit to drill starter holes at the corners keeping away from the line you traced when the sink was upside down. Stay away from that line or you will have a hole the sink won't cover. Cut the front line. Drill a hole in the center of the counter you can put your finger in to catch the piece when it falls. Now cut the side lines while supporting the counter that is being removed. Discard the slug you removed.
Test fit the sink and remove any extra until the sink just drops in. Remove the sink and set it aside. You need at least 2 sink clips on each side of the sink but use 3 if you can get to them. Determine the location you want the clips at. Use the 3/4" spade bit to drill uot a pocket for the clips to go into. They will normally hit the bottom layer of particle board in the front and back. Center the bit horizontally 3/8" up from the underside of the counter. Drill your holes 1" deep. This is where the spring clip on your sink bolts will grab. You can test that the clips will fit then put a small beed of clear siliconized acrilic latex calk around the edge of the sink and install. Wipe up any extra squeeze out with a wet rag and then tighten the bolts and clean up again.
Now you are ready to install the plumbing. If you are using a new garbage disposer with the dish washer draining into it there is a small plastic disc you have to knock out before the dish washer can drain into the disposal. That plug is there to seal the disposer if you don't have a dish washer.
Get more help if you do not understand all the instructions. If you are pretty handy with mechanical things you should be able to get this done. If you have a different kind of sink please specify that and get more help.
Posted on Oct 01, 2016
How to cut out for a flush fit sink
There should have been a "cutout" templet with the sink. Generally a "Jigsaw" can be used to cut out the pattern after first drilling a hole to give you a starting point for the saw blade. Put masking tape or duct tape around the cutting area first to avoid marring up the counter when making the cut. One can also put duct tape on the bottom of the saw platform which will give added protection in not marking up the counter while making the cut.
Jun 18, 2014 | Blanco Home
How to cover gap at back of kitchen sink cut out that sink rim will not cover up
You can use a schlueter T molding for tile in a stainless finish. Cut the T Molding to the length of the gap, - silicone the area and place, and put some weight on it to hold it in place until the silicone hardens. You can get the molding at a tile store, or big box store
Oct 22, 2017 | Blanco - Kitchen Sink - 2 Bowl - axia 6S -...
Need instructions for granite sink oc3322-1, cut-out already done for counter top, ready to put in
There should be a clip kit with the sink if not contact moen you should already have this its part of the deal
Dec 14, 2010 | Moen 25425___ Stone Granite Double Bowl...
Existing vessel sink is stuck to polished granite vanity top. We want to replace the sink with a different one but can't get the sink to release--we originally used silicone adhesive and have tried wedging...
Silicone is an excellent adhesive once it is fully cured. I would not try to pry it off but I would suggest that you take the blade out of drywall or utility knife and carefully try to cut through it. It probably will take several cuts to get the old basin free but thats the only way I can think of to do it without damage to counter top. Hope that helps. Thanks
Nov 13, 2010 | Buck 31" Granite Vanity Top for Vessel...
Installing a vessel sink
Standard Vanity height is approx 34.5". A vessel vanity is approx 31" high. If you cannot remove the legs from your existing vanity then it will have to be replaced or cut down to the correct height. The reason a vessel vanity is lower is because your sink will be approx 3 to 6 inches higher than a standard drop in sink. This may be more work than it is worth. Vessel sinks most often will require a solid surface top, either glass, stone or another type of composite material. The standard laminate vanity top has a particle board substrate which will detiorate quickly at the drain location.
Jul 07, 2010 | Buck 31" Granite Vanity Top for Vessel...
There were no instructions to install my undermount sink. What can I do?
Most under mount sinks are installed before the counter tops go in, they are cut to fit and glued in with 2 part epoxys and secured with screws and clamps. Replacing one in an existing counter top is not an easy job. If you have a granite top, forget it. If it is wood and formica, ok, you can pull the splash off and remove the top, but it is a lot of work. You would be better off with a new top, or a new sink, rim type. Now if you are building a new house and this is new construction, then you can do it no problem. And depending on what kind of top it is, it needs to be screwed and glued. The guy here that did granite for us, would drill out little holes, about 1/4 inch dia, and 1/2 deep for these little machine inserts to go into. Epoxy them in, then clamp the sink down or up to the top with machine screws, about 10/24, 1/2 inch long. Through a clamp, and epoxy the top on, sometimes he used clear silicone. depended on the top. If it was wood, you would just screw into the wood with 1/2 inch pan heads. Hope this helps.
May 15, 2010 | Franke 34" Undermount Double Bowl...
Purchased 30 inch induction cooktop stove to
its ok to cut the laminate using the wood saw to fix the new careful to cut the laminate.
Sep 09, 2009 | Cooktops
Can not get level. countertop and sink top level.
the castng on most sinks is rarly perfect, if ever. i find they always rock to some degree, thats why you sillicone them to your level counter top, besides keeping splashed water from making it's way underneath.
Aug 16, 2009 | Home
My new stainless overmount sink will not lay flat on new counter
Probable not warped, more likely the corner tab is bent. If it is just the corner place a rag over the corner, then using a crescent wrench tighten it on the corner using the rag to protect it from scratches and lightly bend it back. Do this incrementally. If it is more then just the tab ( 6" or more from the corner), remove the sink, place it on the floor, (upside down), place a 2x4 under the offending corner and press down on the sink. Again do this in small steps. Just use a straight edge to know when you have moved it enough.
Before you do any of this make sure your counter top is level!
May 14, 2009 | Hand Tools
How to repair porcelain/cast iron sink scratches
You can repair the sink with an epoxy based porcelin kit
Epoxy will not show brush streaks it will levelitself out do not get any kits from HD or Lowes they do not harden
Go to Sherwin Williams and ask for an epoxy paint for porcelin
As for removing the under counter sink
I would try cutting through the caulk adhesive
between the bottom of the granite and cast iron
sink with a hack saw blade
I have used a diamond blade on a grinder and
cut through but it was not a granite counter top
Be extremely areful to suport the underside of the sink with 2x4 blocks to prevent stressing the granite as you cut through
Good luck
Dec 31, 2008 | Home
Tools & Hardware - Others Logo
47 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
