Question about Belkin (F5D6230-3) Wireless Router
Poor signal strength on wireless router? ?
I am using a Wireless belkin router to connect to internet on my laptop in my home. This has been fantastic up until a few days ago, now i am only getting 47% signal strength even if the router is right next to my laptop....this is making things like skype impossible to use....any ideas ?
    Scholar:
  • 193 Answers
K login to the w/l router and change the channels to 11>or 1 use always use these only and delete all teh temp files and delete cookies and clear history and check with antena which is straight>and reboot the router and laptop>and rate me solved if its help full
Posted on Oct 30, 2007
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
Poor signal with WiFi on my zeepad
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
Belkin N750 DB wireless connection drop
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 23, 2012 | Belkin N750 DB Wireless Dual Band N Router
I have a Belkin wireless router connected to a Virgin modem. Always has worked fine with a Compaq laptop and 2 Dell Inspiron netbooks with excellent signal. Now have tried to connect with an Acer Revo rl...
The router is designed in such a that it is compatible with all the computers. The best way to get rid of this issue is log into the router interface and change the wireless channel to suit your requirement.
1) To begin with.. Open internet explorer on a computer connected to the router and delete everything from the address bar and type http://192.168.2.1 and hit enter. Now you will be in the Belkin Router setup. It will ask for a login password when you click on anything.. Leave the password field blank and click on submit. 2) Towards the left side under wireless click on "Channel and SSID". Now you see wireless channel change it to different channel and click on "OK / Save". Now check the signal strength in your Acer computer. If its still the same try different channel and check.
Hope this helped.
Feb 22, 2011 | Computers & Internet
I have the belkin router in my home and one of my laptops are not picking up the signal for the router
Probably the Router signal strength is low.
You need to open the EWS page ( Router configuration page ) and increase the signal strength to 11 ( it must be Auto or 1,2,3, etc )
EWS Page ( Router page ) can be opened using the Router IP Address which may be 192.168.1.1 or if you know it. Open Internet Explorer and enter the ip address and hit enter ( without www or .com )
Under Wireless configuration or settings you will find the Channel Strength. You need to restart your Laptop to get connected again to the network after saving the settings are you will loose the internet connection.
Regards,
Shawn
Feb 01, 2011 | Acer Computers & Internet
Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 29, 2009 | Belkin (F5D5231-4) Router
Vista wireless connection to belkin-n
It sounds like your linksys is your main connection so therefor it will not always let belkin connect because your pc has registerd your linksys to be your connection.
Sep 20, 2009 | Belkin (F5D5231-4) Router
Have wireless signal but no IP
Starting from the obvious, check that the cables are installed correctly.
You have to have a cable that brings the internet to your place.
Connect that cable into the router's jack labeled Connection to Modem.
Then get another network cable and plug it into any other jack form the back of your wireless router, and the other end into your laptop, just to make sure you are getting connected.
Once you are sure you can surf the net, unplug the wire from your laptop, and you should be able to surf wirelessly.
And if you still can't connect, let me know to perform additional steps.
Please don;t forget to rate this answer if helps.
Jun 28, 2009 | Belkin (F5D7230-4) Router (587009)
Would a neighbors linksys router interfere with my belkin connection?
do check the signal strength of the wireless connection..you can improve signal by removing any big objects between the compu and the router/access point and/or re positioning the router.also intervening walls will affect signal..the fact that you are getting a linksys signal impilies that your home network signal is weak..hope it helps!
Oct 29, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin router
The fact that it sometimes works and sometimes not, would indicate that maybe your wireless signal strength is poor. Try moving the router and/or antenna and recheck the signal strength. If you would provide more details about the problem and your setup it may be helpful in diagnosing the problem.
Mar 31, 2007 | Belkin (F5D6230-3) Wireless Router
Belkin (F5D6230-3) Wireless Router Logo
107 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
