Question about LG Flatron L1750S 17" LCD Monitor
What is the Deafult value of Rgb colourS
LCD MONITOR
  • LG Master
  • 2,013 Answers
Posted on May 28, 2014
Why my monitor screens is color green
Your RGB settings has most likely been altered, resulting in some problems. Check your settings menu on the monitor itself and reset the settings to default. If that is not the problem, it's probably the computer's settings that has caused this change. You will need to go to the computers monitor settings and reset that to default to get back to normal colours.
Nov 04, 2012 | Samsung SyncMaster 915N 19" Flat Panel LCD...
I've lost the red color to my computer. How can I fix it?
If you are using a CRT monitor and you have lost the colour RED, then whats known as the colour gun is faulty. It can be replaced at a cost. However you might find it cheaper or economically sound to purchase a new LCD monitor.
Remember to also check your screen by pushing the menu key on it.
In the menu, under colour management ensure that all colours are set to 50%.
If it is then above colour gun theory is correct.
All the best!
damnor01
Jan 30, 2011 | Computers & Internet
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I see a gray screen only when I turn thePC on. I connected my monitor to my acer extensa laptop and still stayed gray.
The CRT monitors use RGB signals for displaying colours, most of the monitors dos'nt have colour setting option, This situation can only arise whenever the RGB signals are equally of the same strength, this is an indication that the chroma section responsible for colour distribution of your monitor is now working properly, you need to examine the RGB circuitry of your monitor, one more possibility is the data cable (VGA) has been tampered internally.
Oct 05, 2009 | Acer Computers & Internet
No red colour in my lg lcd monitor ..red colour setting doesnt bring any change i screeen..pls suggest some solution
it is very simple, by default in monitor circuit RGB (Red, Green, Blue) tube is installed. and in combination of both of three colors we are able to view colorful image. due to non functionalty of Red color u r not able to view red color in screen, either you replace picture tube or purchase new monitor. coz cost of this tube is equal to monitor.
Jun 05, 2009 | LG Flatron F700P 17" CRT Monitor
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
DR-9080C BackgrounfColour Dropping Out
Color scanning is a big technology. There are concepts like Hue and intensity, refer to wikipedia for explanation. There is something called source light (your monitor for example) and reflected light (your picture that is being scanned). After scanning properly, say you view on a monitor where the Brightness & Contrast are not proper, you will see the image poorly! To test the scanning scan absolute white and check the output. It should read the values 255,255,255 for RGB (Red, Green & Blue). If the values are 255,255,255 but still the image does not appear white on the monitor, it is monitor setting that is wrong. If the output is not 255,255,255 then CANON service personnel only can help. Any good imaging software will display the RGB values.
CANON uses LED light source and they have fairly long life as compare to scanner bulbs. It is okay if you use a powerful system, but it has limited role as the scanner does all the jobs and it only sends the data to the Comp. May further processing is better withe high performance CPU and large RAM.
Aug 05, 2008 | Canon DR-9080C Path-Through Scanner
The color balance on my LCD monitor is hosed. How do I restore the white balance using rgb?
hi slk,
im not sure of the exact values for your rgb that would restore you white balance but you can install Adobe Gamma. Hope it helps.
Jun 21, 2008 | NEC Computers & Internet
Samtron monitor color display 56V
there are 15 Pins in Monitor cable which is connected to VGA port on the rear side of the Tower. First, we need to reset BIOS settings, and then try again - onboard video card only. for Add-on Video card try reseating video card in diff. slot if possible / reseat video card and try again. if it does not fix it, it could be the problem with Monitor RGB Connection - near the electron gun in the monitor CRT tube. resolder RGB , it will fix it.
by
Kasi M
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
