Question about Sharp Televison & Video
My problem was Sharp LC-22L50M-BK-RD memory deflut
Gudie for me
    Top Expert:
  • Sharp Master
  • 74,198 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Mar 19, 2014
3 Suggested Answers
  • 679 Answers
SOURCE: Need SHARP LCD TV LC-22L50M-BK Service Manual
hi go to this link to download the manual.thanks hope you rate my response.
http://www.sharp.com.my/aquos/operation_manual/lc22l50m_en.pdf
Posted on Jan 19, 2011
gopakumarg43
  • 74198 Answers
SOURCE: sharp LC-22L50M-BK display error code K123 please help
It sounds like the audio output card to this TV is faulty. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Posted on Jan 14, 2014
I have LCD LC-22L50M . Audio not comes though I change the chord.
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Sharp LC-22L50M-BK 22 inch Multi-System...
Sharp LC-22L50M-BK display error code K123 please help
http://electro-medical.blogspot.com/
Sep 12, 2016 | Sharp LC-22L50M-BK 22 inch Multi-System...
My 2003 Mercury mountaineer low beams won't come on
Visual Inspection Chart Mechanical Electrical
  • Headlamp switch
  • Multifunction switch
Pinpoint Test B: The Low Beams Are Inoperative
Normal Operation
The headlamp switch sends power through circuit 13 (RD/BK)/15 (RD/YE) to the daytime running lamps relay, then to BJB fuses 42 (10A) (RH headlamp) and 43 (10A) (LH headlamp) through circuit 13 (RD/BK). After passing through the fuses, voltage is then carried through circuits 161 (DG/OG) (RH headlamp) and 160 (DB/WH) (LH headlamp) to the low beam headlamps. Circuit 1205 (BK) is the ground circuit for the headlamps.
Possible Causes
  • Circuit 13 (RD/BK)/15 (RD/YE) open
  • Circuit 697 (BN) open
  • Circuit 196 (DB/OG) open
  • Circuit 1205 (BK) open
  • Circuit 632 (GY/OG) open
  • Circuit 12 (LG/BK) open
  • Daytime running lamps relay
PINPOINT TEST B: THE LOW BEAMS ARE INOPERATIVE Test Step Result / Action to Take B1 CHECK CIRCUIT 196 (DB/OG) FOR VOLTAGE
  • Key in OFF position.
  • Disconnect: Headlamp Switch C205a.
  • Place the headlamp switch in the headlamps ON position.
  • Place the multifunction switch in the low beam position.
  • Measure the voltage between the headlamp switch C205a-8, circuit 196 (DB/OG), harness side and ground.
  • Is the voltage greater than 10 volts?
Yes
GO to B2 .
No
REPAIR the circuit. TEST the system for normal operation. B2 CHECK THE HEADLAMP SWITCH
  • Carry out the headlamp switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Is the headlamp switch ok?
Yes
GO to B3 .
No
INSTALL a new headlamp switch. REFER to Headlamp Switch in this section. TEST system for normal operation. B3 CHECK CIRCUIT 13 (RD/BK)/15 (RD/YE) FOR AN OPEN
  • Disconnect: Multifunction Switch C202c.
  • Measure the resistance between headlamp switch C205a-9, circuit 13 (RD/BK) and the DRL relay:
    • (early build) pin 3, circuit 15 (RD/YE)
    • (late build) pin 5, circuit 15 (RD/YE)
  • Is the resistance less than 5 ohms?
Yes
CARRY OUT the multifunction switch component test. If the switch tests OK, INSTALL a new multifunction switch. REFER to Section 211-00 . TEST the system for normal operation.
No
  • Battery junction box (BJB) fuse(s):
    • 16 (15A)
    • 22 (20A)
    • 42 (10A)
    • 43 (10A)
    • 46 (20A)
  • High beam relay
  • Circuitry
Sep 10, 2015 | Mercury Cars & Trucks
Tv channel changes on its own
Check and replace it main system control memory IC & all micro-switches at its front panel control board. Contact any service technician.
Gopakumar Gopalan Google
Feb 22, 2014 | Sharp LC-22L50M-BK 22" Multi-System LCD...
K3 problem in sharptv
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Error code details of many popular devices are given in detail.
Feb 14, 2014 | Sharp LC-22L50M-BK 22 inch Multi-System...
Jan 14, 2014 | Sharp LC-22L50M-BK 22 inch Multi-System...
Sirrrr in my lcd tv displaying k123 pls give me solution fastly
sir this tv sharp with the modle no. is 22L50M-BK
Its is working but will display screen in lcd show the massege K123
so this reason voloume and chanal change not working
please tell me this
Dec 25, 2012 | Sharp LC-22L50M-BK 22 inch Multi-System...
Manual is lost need to find another one for television LC 26AD5E BK
Please click Sharp Support and click Downloads Tab and download user manual of LC-26AD5E-BK
Mar 08, 2009 | Sharp Televison & Video
Car raidio
speakers: L/F - OG/LG [+] LB/WH [-]
L/R - GY/LB [+] TN/YE [-[
R/R- OR/RD[+] BN/PK [-]
R/F- WH/LG [+] DG/OR [-]
WH/YE HOT f2 20 amp fuse box
BK/PK HOT VPWR
RD/BK illumination
RD/LB Hot in start f2 5 amp fuse box
BK ground
BK/LB ground
BK/OG ground
as far as I know there isn't a "remote" wire unless you are dealing with steering wheel switches
Hope this helps!!
Feb 02, 2009 | 2002 Ford Explorer
Televison & Video Logo
49 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
