Question about Acer Aspire 5734Z4386 Notebook
Put acer aspire 5734z to sleep mode and wont turn on next day
I put it on sleep mode and the next day, it didn't want to turn on. The power light is on and the fan runs for about a second and then stops, but still nothing shows up.. What's the problem?
  • Siebren van der Wal
    Siebren van der Wal Mar 19, 2014
    You could try the settings in the bios; they mostly override the ones you made in windows.
    Master:
  • 397 Answers
First thing to try:
Remove your battery and charger, hold the power button for 10-15 seconds. Plug the laptop into mains ONLY leaving the battery out. Try powering it up.
If the laptop powers up ok, shut-down and re-insert your battery. You should find your laptop will continue to work fine for the foreseeable future, this kind of issue is a common occurrence on laptops.
If not I would then try re-seating your RAM/Memory, if that doesn't work and you have more than one stick remove one at a time to see if either one is causing the problem. If you have only one stick find a replacement to test your laptop with.
If you are still finding the same issues with the laptop I would then proceed to reseat all components of laptop, including the CPU.
If the issues continue I would then remove all non-essential components one by one, each time attempting to power the laptop. At worst you will eventually end up with just the mainboard, CPU, RAM and an external monitor plugged into the mainboard, that still doesn't function correctly. I would then conclude your mainboard needs replacing.
Posted on Mar 19, 2014
Testimonial: "So, question, where would my RAM be located ontop of my laptop? I'm good with computers, but completely clueless on how the actual thing works.... Thanks for your answer. I tried your first tip but that didn't work out, so I'm trying the RAM reset, I just need to know where it is first before I start anything else.."
  • 1 more comment
  • Norwich Repairs
    Norwich Repairs Mar 20, 2014
    If you power your laptop down and turn it over you should find it has an access panel to get to the internal components such as your hard disk and RAM. Remove that panel (this will require a screw driver) and under there you should see your RAM plugged into it's DIMM slot.
  • Norwich Repairs
    The slot and RAM should look similar to this:
  • Norwich Repairs
    Sorry, failed to upload for some reason, here you go:
SOURCE: My Acer Aspire one won't turn on.
I also have this problem with my Acer netbook.  I have only had it for 4 months and am in Turkey on an extended break at the moment.  I have taken the netbook to a dealer here and have been told the problem is the motherboard, verified by Acer themselves.  I am not happy with this as the netbook was not cheap and there appears to be a few Acer models with the same problem
Posted on Apr 10, 2009
  • 4090 Answers
SOURCE: Can't turn my lappy on
Damaged Bootstrap You need to take it for repair
Posted on Aug 16, 2009
  • 16 Answers
SOURCE: Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Posted on Aug 23, 2009
Testimonial: "Exactlt what I had been thinking!"
parrotheadpc
  • 2600 Answers
SOURCE: acer aspire 5920 wont start. light in AC chrger
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
  1. Unplug the computer, then take the battery out, push the power button and hold it for about 30 seconds. Plug the system back in (leave battery out) and push the power button. If it starts, Great! If not unplug go to the next step.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like this its the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
  3. Pull the memory out and find the screws that hold the keyboard on. There are symbols in the plastic there should be 2 screws holding it in. Now in the battery compartment, there are several screw at the back edge of the computer take them out and also the ones in the battery in the center strip. Some are silver and some are black. Once you have the screws out of the battery area flip the computer over and open the lid. The strip just below the LCD with the power button and controls will now be able to be lifted up. You will probably have to lightly get an edge started before it will come up. There should be several little cables hooked to it. Flip the control panel over and look for some screws holding the keyboard in. I think there's 2. Lift up the keyboard. Making sure there's nothing touching anything important and then plug the computer in. Carefully hit the power button and see if the computer tries to start. If it does try it will probably beep at you. Unplug it and put a stick of ram in it. Plug it in and try to start it again. If not, unplug the computer and Go to the next step.
  4. Carefully put the keyboard and control strip in place. Flip the computer over and loosen all the screws that hold the computer together. Flip the computer over again and pull the keyboard and control strip up again. Flex the inner aluminum plate that was under the keyboard lightly. Plug in the computer and then hit the power button. If it tries to start, Great! put it together again in the reverse process.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
Posted on Oct 12, 2009
SOURCE: Acer aspire one, won't wake up from sleep mode, screen blank
I'm having the same problem, but I don't want to have to turn off my computer EVERY time it does this. (I have not been able to shut down the laptop normally because it goes into sleep every time.) I've heard that after 3 hours it builds up an eletrical charge and you have to take the battery out, but I havn't had it on for 3 hours at a time.
Posted on Mar 16, 2010
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
My accer 5115 laptop wont boot up it shows the green light when i plug in the power cord and wen I go to turn it on both lights light up and then go off. please help I have put in a new hard drive and it...
Use the OS CD/DVD to boot again and repair the OS. Next get the appropriate drivers compatible for vista from this site and install them on your laptop for it to function properly:
http://www.laptop-software.com/acer-software/acer-aspire-5315-notebook-driver-software/
Nov 11, 2010 | Acer Aspire 5315 Notebook
Ma acer aspire 5738z does not atart at all. the power on led nd the on/off buton light glows but the scree remains black. when i last left the comp i put it to sleep nd it went 2 sleep after installing new...
sounds like sleep mode created a conflict while downloading updates.and your pc is still in sleep mode..about the only thing you can try,is reinstalling everything..may work may not
Oct 16, 2009 | Acer Aspire 5735 Notebook
Acer Aspire ZG5 Power Led showing yellow
Hibernation is the biggest creator of software nightmares...it has killed more computer systems and corrupted more systems than I can count. Go to control panel > power options and change your power settings in there. Turn hibernation off and just have the computer go to sleep after a certain time. You will find that the computer will come right back in sleep mode and will be ready for action. Don't worry about the system running until sleeping and then waking up, it's a lot better than finding your entire operating system is now corrupt and has to be re-installed.
Sep 15, 2009 | Acer Aspire One PC Notebook
Put vista operation platform to sleep wont wake up but all lights are on on my acer l320
I usually just shut the system down with the power button and then go into control panel, power options and turn all sleep and hibernate functions off. A deep sleep of the computer is usually initiated by hitting the power button and computers do not come out of this easy at all. All the sleep functions can be accessed in the power options of your control panel. Take your time and go through each one and modify the settings to accommodate your habits.
Sep 12, 2009 | Acer Aspire L310 Desktop
ASpire one Acer wont turn on.
Pretty new system, so try on just AC power (remove battery) failing that, get in touch with Acer for repair under warranty
Jun 29, 2009 | Acer Aspire 5100 Notebook
Wont recover from sleep mode after depleted battery
plug out the batter and give the AC. turn it up. any light? if you dont have you have a problem with Mainboard that doesnt let the electircitiy goes in.
of course i am assuming your adapter is working :)
May 30, 2009 | Acer Computers & Internet
Acer Aspire 3610 stuck in sleep mode
When you turn on your laptop do you see the P.O.S.T screen or it just remains blank? and also while booting up do you get any beep sound?
Try to boot your computer in Safe Mode by Tapping F2 (or Del in few laptops) key after pushing Power Button.
let me know what happens.
Askari :)
Mar 27, 2009 | Acer Aspire 3610 Notebook
Aspire one with windows XP. Won't turn back on while in sleep mod
I've had spotty luck with Windows and sleep or hibernate modes. I would suggest just disabling sleep/hibernate mode. The options can be found under the control panel under power options. While turning off the sleep mode won't help your battery life, if you ask me, it beats having to power off the laptop by pulling the battery out. If you don't want to turn it off, you can try adjusting the amount of time it lets pass before it goes to slee.
Mar 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 3620
you have trapped it on sleep mode and there is nothing you can do for that. the only way you may be able to fix it is 2 try and unstall windows itself or even taking it to a technician that knows about the laptop more than what you do. (dont take it offence)
Jul 29, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 5734Z4386 Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
