Question about Canon iRC 5185i
Print quality not good
Print quality is blured
The black ink in my mp258 canon printer is blured how can i fix it
Try a few print head deep cleanings if that does not help then you could try soaking the print head in a shallow plate of hot distilled water. Soak the tip of the print head only in no more than 1/8th to 1/4 inch of water.
Jan 16, 2013 | Canon MP250
Canon mx320 blured printing
replace the ink cartidge with new one.your problem will solved
Aug 30, 2012 | Office Equipment & Supplies
My monte camera gives a blured picture .i m upset with that.plse help me right nw emal me on physics_chemistry12@yahoo.in
hi
you can enhance your picture quality by setting quality high in camera settings option.you can also change your resolution.check your camera settings in your mobile and set the resolution or change the quality high.
thank you
Dec 17, 2010 | Samsung S5620 Cell Phone
I'm having complants that my faxes are blured
Most common cause is going to be you need to have the scanner optics cleaned. Hopefully you have a local repair guy that can do this for you. However you can buy new basic fax machine like this now days for $75 to $80 which might be cheaper than servicing the old one.
Here is a tip for you tho. Make a copy using your fax machine. The quality of your copy is the same quality that you are sending out via the fax. So if your copy looks good then your outgoing faxes look fine. If you get a poor copy then that poor quality is what is being sent out. So copy quality = fax send quality.
Good Luck and Thank You for using Fixya.
Dec 01, 2010 | Sharp UX 108 Roll paper Thermal Fax
My printer prints blured letters
Hi, have you clean the printer head, if yes, have you done maintenance check on it, because all this will help put your printer in good post, if yes, i suggest you change the printer head for effective performance.
I wish you best of luck.
Jan 04, 2010 | HP DeskJet F380 All-In-One Printer
Blured photos. Canon Ixus 950IS
Is th camera shake indicator on when you go to take pics? Are you pressing the button half way to allow the camera to focus?
Jun 23, 2009 | Canon PowerShot SD850 IS / IXUS 950 IS...
Blured pictures and false colours
I would slap the camera face down in my hand as hard as I could.
May 12, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
DVD recorder isn't recording onto a blank disk in DVD format.
You just may have an issue with your DVD recorder. Happens.
Mar 29, 2017 | Televison & Video
Photos are not good
Make sure that your quality is set to best and you are using a high quality photo paper for maximum resolution and quality.
Jun 11, 2008 | HP PSC 1210 All-In-One InkJet Printer
S 5i Question: What are the best settings for quick pics
Hi: Let's go by parts... :) You want to print your photos in 8 x 10 inches without bluring some areas on the picture... in Europe we talk about centimeters. It's something like 20 x 25 centimeters. If you want the picture to be with the best quality for printing, then you have to set your image resolution in, at least, 300 dpi (dots per inch) - this you have to do with software, like Adobe Photoshop CS2. For you to change the resolution of your picture to print with that size without losing any quality, you have to have a picture with, at least, 3000 x 2400 pixels. So, it's better for you to take pictures with the highest quality in your camera, 2560 x 1920, and still you loose some detail. When you have a picture with the resolution 1024 x 768 taken by any normal camera, you will get a resolution of 72 dpi (the same resolution that pictures in the Internet or monitors have. When you print it at your size, 8 x 10 inches, the computer or the printer, one of them is going to change the resolution of your pictures. That process is called "interpolation" and it means that some pixels are generated with middle colors. It's dificult for me to explain the process without showing images but I think that if your search through Google engine you will find lost of pages talking about it... maybe one day I can post in my site about that subject ;) If you have any question about what I tryed to explain just post again ;) Regards
Aug 30, 2005 | Pentax Optio S5i Digital Camera
Canon iRC 5185i Logo
18 people viewed this question
old marine
old marine
