Fault code e9
SOURCE: Neff HTHB86K Microwave oven.
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
SOURCE: fault code E9E
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Sounds like an electronic problem!
Better have factory service do it!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
SOURCE: My NEC NW 652 washing machine is showing an E9 fault
E9 means the waterlevel sensor is defective or the pipe connected to it is faulty.
SOURCE: I have a defy top
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the
bottom part of the tub and blow on it and test the terminals of the
sensor if it will close or open.
Hope helps.
Sounds like the water level pressure sensor is not working. The code (E9) means the switch is open.
You'll need to replace the pressure switch. Check the manual for the repair procedures.
