Question about Marantz New Original CR2020U Remote Control
Marantz rc011sr remote, volume button doesn't work properly,
Feels like its sticking
2 Suggested Answers
  • 336 Answers
SOURCE: Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Posted on Feb 13, 2009
Why does the volume on my Magnavox TV immmediately go to 0 as soon as I turn it on, and then after I turn it up and take my hand off the volume button?
it would appear Volume down button is either shorted or something is constantly pushing on it forcing the volume to go down. You could try to press on the down button and see if it feels like it pushes back a little bit. The most common thing is that it gets sticky from grimy, sticky fingers, try to un-stick it using some alcohol on a cotton swab. Other that the only way to fix this is to take the tv apart and figure out the button problem that way!
Good Luck!
Rich Lilja
Apr 02, 2015 | Funai Magnavox 32md301b/f7 32-inch 720p Tv...
All of a sudden I have no volume on my TV I have 7300 marantz. I can hear a movie but when I have it on DSS it now shows analog instead of digital
You've either
  1. pressed a button on the remote that cycles the audio input from digital to analog,
  2. or a menu for audio out on the satellite box has been altered
  3. or the cable has come unplugged
  4. or the input assignment on the amp has been changed
Go for the simple stuff first. Check the cable. Look for the mode button that changes the audio input.
Sep 06, 2014 | Marantz Audio Players & Recorders
Only the volume on my Marantz rc004sr doesn't work
same here... seems to be a general problem with this remote.
Feb 04, 2014 | Marantz New Original RC004SR Remote...
DWIN tv, Marantz receiver and Dish system. Three different remotes needed to control. One for On/Off of the tv, one for the volume and the third for the Dish network. What is the best way to get to one...
Youdo have the ability to program your current DISH Network remote to all of yourcomponents. If you decide you would like to do so, I have included instructionsto assist you in programming your remote. In order to program your remote toyour DWIN television without the remote code, (I'm sorry unfortunately I wasunable to locate a remote code for a DWIN Tv L) you can complete what we refer to asa "Power Scan," to do this you would complete the following steps. 1. Withthe desired equipment on, press and hold the correct Mode button until all modebutton backlights illuminate, then release. (In this case the mode button willbe "TV") 2. Pressand release the Power button. 3. Pressthe Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, theequipment will power off. 4. Pressthe POUND (#) button. If the codeentered is valid for the remote, the mode light flashes three times.
-In addition, you can also program the remote to yourMarantz receiver this can be done by pressing and holding the AUX botton inupper left corner of remote next to the SAT button.
-Press & hold AUX until all the other mode buttonslight up, then release AUX button, all the other mode buttons should turn off,only AUX button should be blinking now,
-While AUX button is blinking enter in the remote code742 for the Marantz receiver and then press the # key (pound key.) Afterpressing the # key on your remote, the AUX mode button should blink 3 timesmeaning the programming has been completed successfully. While still in AUXmode try any function on the remote, such as turning the volume up or down onyour Marantz receiver. The DISH Network remote should now be programmed tocontrol the receiver.
-If the 742 code doesn't program the DISH Network remotesuccessfully you can also try each of the following using the same procedures, 743,651, or 740. After completing the power scan to program the DISHNetwork remote to your DWIN t.v, & completing the AUX mode buttonprogramming, the remote should now work for your TV to powere on and off, theMarantz amplifier- to control the volume, and the DISH Network receiver. Hopethis helps! -Kirstie DISH Network
Oct 04, 2010 | DISH Network IR Remote Control
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Feb 11, 2009 | Marantz SR-5200 Receiver
Directv AV1 switch Volume Problem
Did you try all the codes listed. Some work certain functions such as power but not volume. Did the installer leave a phone number where he could be reached other than directv toll free number? Did you receive the same remote as the original. Directv has two remote that are identical in appearance but one is rf capable and the other is infared. The RF remote has backlit keys and is compatible with just about any device.
Aug 03, 2008 | Universal Remote Control DIRECTV Universal...
Marantz New Original CR2020U Remote Control Logo
151 people viewed this question
Top Marantz Televison & Video Experts
 Grubhead
Grubhead
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
