Question about SHARKK Ipad Case With Keyboard -- Bluetooth Connection -- For Ipad 2
Sharkk bluetooth keyboard stops working
It works for 30 seconds, then stops working and I lose Bluetooth connection
Bodyglove samsung galaxy tab3 bluetooth keyboard does not work.the lights are on.The tab recognises the pairing & connects via bluetooth,however,I cannot type. Is there a way to "restart" the keyboard
I believe that you need to set the deafult keyboard on your device sertings. As you know your device keyboard is set to google or samsung keyboard. Unpair the device with the keyboard and re -pair them again, once they are paired go to device settings, language and data tap default keyboard and select bluetooth keyboard and set it as default.
Hope this helps.
Good luck.
Jul 11, 2016 | Samsung Tablets & eReaders
Is there a mouse that works with the kindle fire 5th generation? Bluetooth maybe?
Jodi, Yes, you can pair it with Bluetooth mouse and possibly through mini port. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Connect to Bluetooth
Kindle Fire Wireless mouse and keyboard on ICS
Using Qwerty Keyboard Mice and other USB device on Amazon Fire 2015 via...
Can you connect both bluetooth mouse and keyboard to Kindle HD Fire 6
May 03, 2016 | Tablets & eReaders
Why will my Samsung galaxy tab A no longer connect with bluetooth?
How to Connect Your Samsung Galaxy Tab Using Bluetooth ...
www.dummies.com/.../how-to-connect-your-samsung-galaxy-tab-using-...
Bluetooth is a wireless communication used to connect the Galaxy Tab to ... don't forget to turn them off when you're no longer using them with the Galaxy Tab.
samsung galaxy tab 2 connecting to a bluetooth keyboard ...
? 1:46
https://www.youtube.com/watch?v=-YVaAFn4vAo
Feb 10, 2013 - Uploaded by David Hodges
how to connect your samsung galaxy tab to blue tooth keyboard. ... I can connect other bluetooth items to my Tablet but notkeyboard.
Troubleshoot issues related to Bluetooth and your Samsung ...
Jan 16, 2016 | Samsung Tablets & eReaders
Keyboard will not work
Dawn,
IF your tablet and keyboard work with "Bluetooth" then check under you tablets settings page (look for Bluetooth) it may have been turned off.
IF your tablet/keyboard does not used Bluetooth, check the battery in the keyboard, It may have been depleted...
Does the keyboard have an OFF/ON switch, that my also be your issue.
Hope this helps.
Topbarhive
Jan 12, 2016 | Tablets & eReaders
Cannot get bluetooth keyboard to connect
Make sure the keyboard does not have a pairing relationship with another device in the room.
If there are any devices listed on the iPad, in Bluetooth settings, tap 'I' and forget Device.
Place the keyboard in pairing mode with a 5 second depress on power from the 'off' or no power state.
Type the keys on the keyboard that the iPad wants for the pair.
Aug 13, 2015 | Apple iPad Air
Using the keyboard for iPad not typing on the screen
check the manual...!
depends on the model - but it works with bluetooth- see a sample :
put the iPad in the slot built into the keyboard, and pair it with your iPad via Bluetooth
On your iPad, tap the Settings icon and then tap Bluetooth. Make sure Bluetooth is On.
Connect the Logitech Ultrathin Keyboard Cover i5 Logitech Support Article using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-0.jpg using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-2.jpg
Sep 15, 2014 | Apple iPad Tablets & eReaders
My shark keyboard for iPad air does not pair for blue tooth operation
Perhaps you look on this link to see you did everything right, like charging the battery, switching on and pairing. Don't forget to switch on bluetooth on your iPad. SHARKK Apple iPad Air Wireless Bluetooth Keyboard Case
Sep 10, 2014 | Apple iPad Tablets & eReaders
How to unpair bluetooth keyboard from tablet
First off go to setting an then Bluetooth. I'd first try activating it there. If it still fails to work you can stop it and also delete it from that settings screen.
Feb 28, 2014 | Samsung Galaxy Tab Tablet PC
USER INSTRUCTIONS TOO SMALL TO READ
I can't find any online manual except for a logitech version of the same thing.
Oct 20, 2013 | SHARKK Ipad Bluetooth Aluminum Keyboard...
I updated my ipad to ios7 and my Targus Bluetooth keyboard does not work anymore.
I have similar problems with my Targus keyboard connection to ipad w/ ios 7, but not yet found solution. In my situation, connect can only be made after a complete power down. Keyboard is on; Bluetooth is on; iPad says it has discovered and connected to the Targus Versavu Keyboard, but keypad does not respond.
Oct 10, 2013 | Targus BLUETOOTH KEYBOARD FOR IPAD
SHARKK Ipad Case With Keyboard -- Bluetooth Connection -- For Ipad 2 Logo
41 people viewed this question
Top SHARKK Tablets & eReaders Experts
Are you a SHARKK Tablet and eReader Expert? Answer questions, earn points and help others
