Question about Sony Video Game Consoles & Games
Getjar com My PSP scroll wheel is not working how I can fix it
How yo download psp games
First, you have to find the game you want, and download it to your computer.
  1. 1 Once the PSP games are downloaded, connect the PSP to your computer by using the USB cable that comes with the PSP console. Change your PSP console into PSP mode by pressing the "Home" button. Next scroll left to the "Setting" column and scroll down until "USB Connection". Press "X" button to enter PSP into USB mode.
  2. 2 To download the PSP games into your console, the games must be copied and downloaded onto the correct folder in order for the games to work. And the correct path is PSP > GAME in order for the any PSP games to work correctly. If the "PSP" and "GAME" folder does not exist on your PSP memory stick, you need to manually create the folder with folder name in ALL CAPS.
  3. 3 Once you have finished downloading or transferring the games onto the PSP memory stick, you can disconnect your PSP from the computer. From the PSP console main menu, scroll over to the "GAME" column on your Sony PSP and continue to scroll down on the memory stick. Press "X" and a list of game files will be displayed. Scroll downward and you will be able to see the games you have just installed.
  4. 4 Press "X" again to confirm your selection and play the PSP games. I had tried to practice the steps above many times in my PSP and it worked all the time. Hopefully it will also work for your console too.
Hopefully, this works for you!
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
How do i download free psp go games
Like many others who had purchased original PSP games from the retail outlets, you will realize that as the games is completed, buying new games seem to be getting expensive and unaffordable. What else can I do if I want to continue to play new or old fashioned games on my PSP console? I start search and looking for website that offers free PSP download games.
Once I had downloaded the PSP games onto my console, how to play PSP download games was my next question. I'm not sure exactly how PSP works when I download new PSP games onto the unit, but I sure have found some answers while I was looking for it. Since I'm facing and struggling with this problem on how to play PSP download games on my unit, lots of other people must be also getting the same problem.
Hope that I get this right for everyone to play PSP download games because I used the same method here to play on my console. Before we get started, I'm using a PSP unit with firmware of 1.5 and having a Sony PSP compatible memory stick pro duo.
Since you are going to download the PSP games, you must download the games for the correct version of firmware, if not it will not work. Newer version of the firmware is available to anyone from the PSP official website. Most homebrew PSP games works with firmware 1.5 and below because the newer firmware upgrade is trying to block people from using homebrew games. Make sure the games you are downloading ends with PSP because only PSP files are compatible with Sony PSP unit.
instruction
  • Once the PSP games are downloaded, connect the PSP to your computer by using the USB cable that comes with the PSP console. Change your PSP console into PSP mode by pressing the "Home" button. Next scroll left to the "Setting" column and scroll down until "USB Connection". Press "X" button to enter PSP into USB mode.
  • To download the PSP games into your console, the games must be copied and downloaded onto the correct folder in order for the games to work. And the correct path is PSP > GAME in order for the any PSP games to work correctly. If the "PSP" and "GAME" folder does not exist on your PSP memory stick, you need to manually create the folder with folder name in ALL CAPS.
  • Once you have finished downloading or transferring the games onto the PSP memory stick, you can disconnect your PSP from the computer. From the PSP console main menu, scroll over to the "GAME" column on your Sony PSP and continue to scroll down on the memory stick. Press "X" and a list of game files will be displayed. Scroll downward and you will be able to see the games you have just installed.
  • Press "X" again to confirm your selection and play the PSP games. I had tried to practice the steps above many times in my PSP and it worked all the time. Hopefully it will also work for your console too.
  • Dec 20, 2010 | Computers & Internet
    Ive got a psp and the move button is sticking it always in the down position
    If this is only happening in games, it's a problem with the joystick assembly. It's pretty common on the PSP for this part to wear out and characters [or menu options in games] will start scrolling by themselves. Replacing the part will fix the PSP up. Check the following website out -- they sell the joystick and perform replacement repairs:
    http://store.richspsxparts.com/pspanstasre.html
    Nov 17, 2009 | Sony PlayStation Portable (PSP) Console
    How do you lock some pics on k500 so other people dont look
    You can go on www.getjar.com and select your phone and then go to search and write "lock" then scroll down with the mouse and you will find one application iLock click on it and select download jar file ,put it on your phone and that need to work
    Aug 03, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
    Scroll wheel not working.
    try installing the MS Intellipoint drivers http://www.microsoft.com/hardware/mouse/download_ns.asp
    Jun 26, 2009 | Microsoft ARC Mouse
    Psp scrolls down and left Help Plz
    Your directional pad is sticking. you can buy a replacement cheaply on ebay
    Jan 04, 2009 | Sony PlayStation Portable (PSP) Console
    Psp won't read game disks.
    This is, unfortunately, a pretty common problem with some PS3 models. it's almost always a hardware issue where the lazer lens inside the PSP fails or is otherwise no longer able to read game discs.
    The only real fix for most people is to send it in to Sony for replacement; but that's only good if it's still under warranty (they'll want a copy of the original receipt).
    Otherwise, your only choices are to get a new PSP or only play games stored on the memory card.
    Nov 18, 2008 | Sony PlayStation Portable (PSP) Console
    Nikon d50 scroll wheel
    that needs to be fixed by a technician , bring it to a repair shop where the sell nikon , or contact nikon at www.nikon.com for a repairshop or service point near you
    Jun 04, 2008 | Nikon D50 Digital Camera
    Psp anolog stick
    replacement pack should fix that, but did the stick fell itself or ur psp fell? Also u can try to open psp and clean, i had similar problem just cleaned and it helped
    Oct 05, 2007 | Sony PlayStation Portable (PSP) Console
    Video Game Consoles & Games Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
