Question about Samsung Heating & Cooling
My Air Conditioner Won't Turn On. - Samsung Heating & Cooling
Heater and air conditioner won't work
It may be the blower motor resister,it's located next to blower motor.Here's a picture of it.
Jan 19, 2013 | Air Conditioning and Heat for Mitsubishi...
Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
May 18, 2012 | Hitachi RAS-09UH Air Conditioner
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
My air conditioner worked fine last night, but when I tried to turn it on today in the 101 heat, it displayed E1 (blinking). I've unplugged it because it would not let me turn it off either.
If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced
Jul 22, 2011 | Samsung AW1203B Air Conditioner
I have a portable air conditioner model LP0711WNR. My issue is when I drain the air conditioner, it only drains about one cup of water. Then, when I turn it back on it and use it, after about an hour it...
The easiest way, is to tilt it over slightly when you drain it. But, be very careful doing this, as the unit has caster wheels and you don't want it to get away from you. If you have a helper, so much the better. Remember to always turn the unit OFF & Unplug it, before draining the water from the tank.
I hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | LG LP0711WNR Portable Air Conditioner
Turned off a/c remote < now it won t turn back
It sounds like the remote sensor pc board is bad, you need to replace the sensor board.
Nov 03, 2009 | Fujitsu 24C1 Air Conditioner
Panasonic 1200btu air conditioner
you must check the fuse of pc board.its a glass fuse and propably had burned,replace it,if the fuse is ok then is the varistor and you must get an expert to fix it.
Oct 01, 2008 | Panasonic CW-C60RU Air Conditioner
Heating & Cooling Logo
10 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
