Question about Samsung Propel SGH-a767 Cell Phone
How cant i turn it on
I dont know how to tur it on
Need help my psp is not working when I turn on I can only see the green light no sounds no display just green light and after a few seconds later it turns off the last thing I did I update with something...
First you have to take out the battery and use charger to turned on and when it turn on just put on the battery or take out the battery and wait for minutes then put it on and tur on,if that doesn't work when you turn on just hold R and start or repair it
Feb 06, 2013 | Sony PlayStation Portable (PSP) Slim...
My microwave oven dont turn on i can put the minutes but when i turn on dont start
It's probably a bad door switch or door switch mount.
See these links:
http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 24, 2012 | GE Microwave Ovens
My plasma tv won't tur on is there any way to fix
Not knowing model number here are some general things:
Apr 04, 2012 | Sharp Televison & Video
When i try to turn on the camera it dosent tur on
there are some little things that you need to verify 1> see if the battery is plugged and if it is then try using another battery if this does not work take it to the seller dont forget your warranty card
Mar 03, 2011 | Panasonic NV-GS150 Mini DV Digital...
I cant turn on the LG 32LH20 tv, its allready pluges in, master switch is on and there is a red light turning blue back and forward, i cant tur it on, how do i do it?
You may have failing power supply due to bad DC filter caps, that will be the first place to start looking.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 05, 2010 | LG 32LH20 32 in. LCD HDTV
95 jetta wont start unless you pop start it i changed the starter i have all the power just when i turn the key nothing
check your fuses under the hood and under the dash
check polarity of battery (if you unhooked booth leads)
is the battery any good?
you probly conected the leads to the starter incorectly (recheck them)
(the following asume your tur n key ignition system is functioning properly)
to test your tur n key system simply hook up a test light to the small lead running to the starter cylynoid "while the wire is disconected" and have a friend turn the ignition over. [dont furget to test the test light first lol]
or even got the wrong starter completly (usaly a store problem)
did you " bench test" the new/used starter befor installing it ?
iv goten brand new starters doa
is the ground strap hooked up ? is there corosian on the battery posts or any of the high amperage conections?
is the cylynoid on the starter or somewhere else under the hood?
cautiously try to bypass the cylynoid ie run a hot wire to the small lead on the cylynoid
(this can usaly be done by jumping from the main red wire on the starter to the hot lead of the cylynoid)
notes: when bypassing the ingnition system (jumping the cylynoid)
DO NOT have the ignition in the on postion and it is best to remove the lead from the cylynoid (incase of a short in the wire's some place)
if nothing remove the large red wire on the cylynoid and touch it directly to the starter lead itself (there will be a fair amount of spark when doing this its normal) but make shur you are conecting to the starter lead and not a gound point as this will cause exsesive sparking that isn't good
dose the starter tur n the engine over
back track untill you find the fault be it starter itself,cyclynoid,wiring,blown fuse,corosion,bad battery,
still cant find the problem take it to a shop!
hope i helped yah
Dec 14, 2009 | 1995 Volkswagen Jetta
Toshiba Television will no turn on, timer record lite flashes when trying to tur on T.V
Sep 05, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
When i turn on my car and tur it off it wount start no more.
Check your air system. Check your mass air flow and mass absolute pressure sensors.
Jul 16, 2009 | 2005 Nissan Altima
Compressor tries to turn on but cant.
Try changing out the start up and run capacitors for the compressor.
Jun 24, 2008 | Coleman Mach 15 Air Conditioner
Samsung Propel SGH-a767 Cell Phone Logo
12 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
