Question about Garden
Briggs stratton specifications rigs
What H.P. Is Briggs and Stratton Classic 35
    Sergeant:
    Champion:
  • 266 Answers
Posted on Mar 21, 2014
  • 110 Answers
SOURCE: where can i get a manual for a briggs and stratton
You can download a manual for the engine from Briggs & Stratton's web site - you just need the numbers off the blower shroud. No manual exists for the actual mower.
Posted on Sep 22, 2009
  • 18 Answers
SOURCE: wanted briggs and stratton 92908 manual
Find the B&S website and you should be able to download a parts or service manual.
Think it is briggsandstratton.com.
You will also need your type number (after the 92908).
Posted on Apr 18, 2010
HansPP
  • 2510 Answers
SOURCE: Champion 35 Classic lawmnower with a 3.5hp briggs
Check the governor spring and throttle linkages, something may have come adrift. Also check the throttle shaft and body for wear and excessive clearance which could **** in excessive air, upsetting the mixture.
Posted on Apr 17, 2011
hunter19_46m
  • 7482 Answers
SOURCE: Briggs & Stratton Model 92502 3.5 HP Engine with
Hi hjconn...
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
NOTE: Before you dissemble the carburetor:
Make sure you mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you dissemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 25, 2011
  • 15 Answers
SOURCE: i can get my briggs & stratton push mower to
change the primer bulb it got a air leak.but firstmake sure the plastic tube going down in the gas tank with the screen on the bottom is not stopped up.
Posted on Jul 17, 2012
Need a repair manual .pdf for a Briggs and Stratton Model 311707 Type 0132-E1 engine
H.A., Check the attached links,instruction and guides for Briggs and Stratton, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My 311707 0132 E1 Model Overview from PartSelect com
http://www.smallenginesuppliers.com/html/engine-specs/briggs_vertical_shaft_engines/276781SingleCylinderOHV.pdf FAQ Small Engine Specifications Briggs Stratton Specs
Briggs Stratton Small Engine Specifications
Jul 01, 2016 | Measuring Tools & Sensors
Briggs & Stratton 35 Classic. How to fit the cable to drive the tines. Help!
briggs and stratton 35 classic is the model of engine not the rotavator
May 06, 2015 | Briggs & Stratton Garden
Briggs & Stratton 35 Classic rotorvator. How to fit drive cable to drive the tines. Help!
on tillers the control cable lengths need to be kept the same as they use the free end cable lengths to denote how much pressure is put to clutch pressure idler wheel , too long not enough pressure, too short too much pressure
Where can i get a repair manual for Briggs and Stratton Champion 35 Lawnmower
contact Briggs and Stratton USA, they will have them. I got one 12 months ago for a different (old) model.
Apr 22, 2015 | Briggs & Stratton Garden
How do i remove front wheel from briggs stratton 35 classic?
ether there is nut or a retaining clip if nut unscrew pull off if retaining clip pull off with a pair of pliers remove wheel in stall with new retaning clip
Aug 26, 2014 | Briggs & Stratton Garden
Briggs and stratton 35 classic. Need piccy of arrangement of carb/choke links and springs as think someone has changed them and mower no work. Model 9D902. Lever which may be choke, does not stay in place...
check youtube,guy on there has pics of spring set up,and still pics to follow the video.
check this name on youtube:4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close Up Detail
Apr 25, 2011 | Briggs & Stratton Briggs Stratton...
Champion 35 Classic lawmnower with a 3.5hp briggs and stratton engine. Engine starts fine but will not run regularly.Keeps revving and then dying back and then revving again continuously.
Apr 17, 2011 | Briggs & Stratton Garden
Where can i get a manual for a briggs and stratton pwr400prma 35 classic petrol rotary mower
Sep 12, 2009 | Garden
Garden Logo
137 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
