Question about New Boss 822UA CAR STEREO DOUBLE DIN MP3 COMP CD RECEIVER AM FM
Boss 822ua car stereo red power light comes on but that is all that happens is there something I can try?
RED power light comes on but nothing else happens
What happens if my red and yellow wires touch in my stereo
The yellow wire is for ignition the red one is main power nothing bad will happen but you will have too take the face off or your stereo will run your battery down
Nov 14, 2014 | Cars & Trucks
No power to unit?
Here is the wiring diagram make sure you have a good earth.
Red to 12 v IGNITION and yellow to constant battery power. Hope this helps
Jun 07, 2013 | BOSS AUDIO SYSTEMS 612ua
My new dual XDMA450 stereo wont turn on. when i take off the face plate the red sensor light is flashing. this only happens when my head lights are on. what problem am i having with my stereo and why
Check your wiring connections. A similar thing started happening to me out of the blue. The unit would work fine for a period of time, and then just shut off for no reason, and I couldn't get it to come back on. The next day, it would come on again when I started the car and stay on for a while, only to shut down again. The red light behind the face plate continually flashed, regardless of whether the receiver was working. In my case, there was something off in my red wire connection. The unit would turn on / shut off when I moving the wires on either side of the connection. I redid the connection, secured it with electrical tape, and the problem has not reoccurred. If the red wire is not the problem in your case, try the black and yellow connections. These appear to be the wires that could cause this to happen. I can't explain why the power kept repeating the power on / off cycle, unless the wires were in just the right position to be moved / jostled slightly while driving. Hope this helps.
Oct 19, 2012 | Dual Audio Players & Recorders
Tv won't turn on. red power light is out
red light is on, but when the tv is turned on, it immediately shut down and goes back to the red light setting. It is like it blows a fuse or something to that effect.Post Solution
Mar 02, 2010 | LG 50PC3D 50 in. Plasma Television
Color code for speaker diagram 94 Ford Explorer xlt
Please rate this info.
1994 Ford Explorer Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Light Blue/Red
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Pink/Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Black/White
Mar 14, 2009 | 1994 Ford Explorer Limited
Pioneer AVIC-N2 does have unlock code?
no, this radio has no security code... Check to see that you have power on the yelow wire at all times, Power on the red wire when the key is on, and make sure the black wire is grounded well. something could have been disconnected at the paint shop.
Jan 03, 2009 | Pioneer AVIC-N2 Car DVD Player
Kenwood ddx6019 comeing on
that red triangle falsh is a power warning take a meter to the accesory wire going to the radio ( its red for the love of god please tell me you know that) but anyways see whats happening there odds are you have a faulty wire it should read 12-14v dc. when you try and meter it for resistance to ground never should you see a ground spike if you do you have a problem.
Feb 06, 2008 | Kenwood DDX-6019 Car DVD Player
New Boss 822UA CAR STEREO DOUBLE DIN MP3 COMP CD RECEIVER AM FM Logo
37 people viewed this question
Top New Boss Car Audio & Video Experts
xxxxxx xxx
Are you a New Boss Car Audio and Video Expert? Answer questions, earn points and help others
