Day and night furnace 80cd-12a
Series 152
I am trying to find out the age of my upstairs furnace. I had three contractors come out, one said it needed to be replaced, and two other one said only one part needed to be fixed but they were different...
it was made in 02 of 02. first three letters/numbers correspond to model # next 4 are year and month of manufactuer the remainder are production codes.
Have a great day!
Dec 27, 2017 | Heating & Cooling
How do I stop the heating coming on during the night?
Set automatic day and night temperatures. Forget about manual setting. Your furnace will start at night only to maintain the temperature you set. However, there is a minimum threshold where your furnace will start regardless of the temperature you set if there is a sharp drop in temperature.
Jan 31, 2017 | Heating & Cooling
Does Malm Day and Night furnace have a filter in the main unit?
Assuming this is a upflow unit? Disconnect power,remove panels should be 2 . Look in blower housing opening bottom of unit where air enters. Units come with filter new.
Oct 16, 2014 | Heating & Cooling
How to configure motorola cs3070 tab suffix
Download the CS3000 Series Scanner Product Reference Guide from the Motorola Solutions Support portal and scan the barcodes:
<Data> <Suffix 1> Adobe page 69 of 152
Scan Suffix 1 Adobe page 68 of 152
7 from the Numeric barcodes Adobe page 121 of 152
0 from the Numeric barcodes Adobe page 120 of 152
9 from the Numeric barcodes Adobe page 121 of 152
Save Configuration Adobe page 72 of 152
https://atgsupportcentral.motorolasolutions.com/content/emb/docs/manuals/13608804a.pdf
May 05, 2014 | Symbol Hotshot LS2106 Handheld
Neighbor's kerosene tank makes horrible noise at night
The oil lines that run from tank to furnace is acting like a guitar string. As oil is being pumped through the pipe, it is humming. Try placing an old rug on the tank to see if it absorbs the hum.
Jan 22, 2010 | Reddy HEATER RH125T 125,000-BTU...
Day / Night HVAC is running cool air BUT the furnace is running 2
Strange. Does the thermostat control both the air conditioning units and the furnace. If not make sure the furnace thermostat is turned down to below 65 degrees.
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
Electric Furnace Trips Breakers
it is normal for a breaker that is run right on the edge (50 amp and your furnance to use 45) to get weak after a while . the first thing you should do is change the breaker with the same type and amp rateing . it should take care if it
Jan 16, 2009 | Heating & Cooling
113 people viewed this question
k24674
jasbo
jasbo
