Question about Sharp Audio Players & Recorders
Speakers quit working-but tryed in another unit n they work--work great on -headphones still-very baffled
My speakers arnt working in my unit all of a sudden-there not blown however it worked before n just got second handed what happened!!!dont have a remote n can i reset the speakers n ty so much
  • 341 Answers
There should be a speaker selector switch of button on the front of the receiver, make sure that you have selected one or both of the speaker possibilities.
Posted on Mar 19, 2014
SOURCE: remote control not working...
I'm not sure of the exact fix, but when these components were assembled a few of the connections involving the remote sensor were not saudered. An easy fix if you know where to look.
Posted on Jul 21, 2007
  • 6 Answers
SOURCE: Reset the remote control?
I have the same amp. Try leaving the batteries our for a while like more than a day. Also if you can join a wire from each battery terminal to the others for a while. That will short out the remote and 0 it. This should cure your problem. I have had to redo the remote many times. Also while the remote is out press all the buttons in as many as your can for a while.
Posted on Sep 01, 2007
  • 4234 Answers
SOURCE: Kenwood Receiver KR-a5020 receiver won't come out of standby
The unit is in what is commonly known as "protect" mode. This means that a problem has been detected in the final output stage of the amp and the outputs are shutdown to prevent further damage to either the receiver or speakers. This should not be a difficult repair for a service shop. Expect a parts cost in the $25-$40 range. Add in the local labor rate for the total repair cost.
Dan
Posted on Nov 28, 2008
SOURCE: Philips FR965/17 Digital Audio/Video Surround Receiver
http://www.p4c.philips.com/files/f/fr965dht/fr965dht_dfu_eng.pdf im pretty resourceful
Posted on Dec 18, 2008
rscheutz
  • 54 Answers
SOURCE: All Speakers suddenly dead
The internal audio amplifier is most likely dead, as it drives all speakers and the headphone output. If this is still under warranty, I would go that route. If not, it may be cheaper to buy a new receiver. Parts and labor can be expensive...you will have to take it to an electronics repair shop for an estimate.
Posted on Mar 25, 2009
When i am putting my audio jack in port the dection is shows but sound does not come from the speakers
It would be great to see screen shot.
Which windows do you have ? Are you sure speakers work ?
Try checking mixer is it set to headphones instead of speakers ?
Try pluging in other speakers (headphones) to see if it works.
Oct 14, 2013 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Speakers not working but headphone ix ok.
Open volume control - headphone and speakers are a separate control.
Jul 26, 2013 | Dell Inspiron Computers & Internet
Hi .i have hp compaq 610 laptop.my in build speakers not working.how can solve the problem.please help me.
The inbuilt speakers on my laptop do not work. I believe the headphone input socket to be the problem because when i stick my headphones in it only works if i squeeze the laptop near the socket. The input has been quite heavily used so i'm quite certain its broken somehow. Anyway, my layman theorising has led me to the conlcusion that my laptop thinks that headphones are plugged in when they're not and so disables the speaker so maybe if i could disable the headphone input the speakers might work. I'm sorry if this sounds confusing but my computer knowledge is really, really limited. Any help would be massively appreciated. thanks
Jan 02, 2011 | HP Compaq Computer Speakers
Will 5" x 7" work
No. The 5x7" speaker is smaller than the stock 6x8" speaker. In order to make this work you will need to create a thin baffle that can be screwed into the mounting holes of the OEM 6x8. A table router and some 1/8" hardboard works great for this. Cut out the new baffle to accomodate the 5x7 and you are good to go.
Dec 21, 2010 | Kenwood Car Audio & Video
How do I make the microphone work? I can hear the other party, but they can't hear me
The biggest thing woul be check your sound settings on your comptuer and make sure its not muted. also if thier is a switch on the headphone make sure they arnt muted,
to check your comptuers volume settings, look for a speaker phone down by your start menu, or go to your control panel, look for anything that has to do with sound. open that open, and just make sure the mic isnt muted,
Nov 05, 2009 | Motorola Mobility S9 Headphones
No speaker sound, headphone works
Hiya . The 8ohm is fine and would work. Check for the obvious, a speaker on off switch. If not that then amplifier module is faulty.
Jul 10, 2009 | Audio Players & Recorders
No sound comming from the left side speakers in my 04 Envoy XUV.
first> road vibrations can cause cable connections to come loose so you can start by taking out your radio and making sure all of the questions in the back are connected as they should be.
Second> if this doesnt seem to work then the next step is to check the wires going to the speakers that arnt working (this will b quite a job, but if you can do it, it will save u quite a bit of money) .. checking the wires your checking for >bad connection to the speakers >cuts in the wire or if any part of the wire is touchin any other metal object
Was This Helpful ?
May 29, 2009 | 2004 GMC Envoy
Low sound in headphone
I would say it is because the unit does not have a built in amplifier. The speakers are powered PC speakers of studio monitors I am guessing. Try plugging the headphones into the headphone jack of the speakers if they have a headphone jack or try a set of powered headphones out of the Edirol and see if it helps.
That should remedy the problem.
Dec 27, 2008 | Edirol UA-4FX External Sound System
Midiland ir-hf1 right speaker broken
Hi evtan
The only thing I can suggest you do is to swap the right and left inputs to the transmitter base over whilst wearing the headphones. If the fault transfers to the other channel, then you have a faulty interconnect lead that needs to be replaced. If it stays with the same channel, then the headphones or the base staion will be faulty. Best bet then is to return it to the place you purchased it from and request a replacement unit,. Thanks for using FixYa....a FixYa rating is a great reward from you to me for helping out :) Cheers
regards
robotek
May 08, 2008 | MidiLand IRS 858 Consumer Headphones
Headphone problem
A little more info would help please. Brand, Model Number ?
Cheers
Feb 10, 2008 | Radio Communications
24 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
