Question about Sony MUTEKI HTDDW1600 Theater System
Sound output failure
No sound coming out with speakers connected,
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 924 Answers
It can be many different issues; too many to go into on this website. It is most likely DC Offset, meaning a damaged amplifier. Please contact me directly at AUDIOSERVICECLINIC.COM for more information. You may contact me directly through the website.
Thank you,
Dave
Posted on Apr 01, 2014
How do I connect my receiver so that the sound comes from my speakers????
Please read the manual. You should connect speakers to the speaker output of the receiver, or amplifier. You connect the TV with a receiver through a HDMI cable. Depending what would be the source from that you take the output and the place the signal is going to there you should use the input. Don't connect anything without 100% certainty it is correct. You could damage the whole equipment when connected the wrong way around.
Dec 28, 2014 | Samsung 50" Uhd 4K Smart Hdtv
No sound on radio or CD,speakers working nice but dont make any sound
Possible damage to radio output ic if no audio. Output failure is usually due to shorted speaker lines either together or to ground. You can check your speaker lines at head unit and they should have approx 6v dc on +&- lines each channel. If this is not present then most likely is
output failure, if ok then is internal fault possibly with vol control ic or
power supply.
Mar 16, 2014 | Clarion Car Audio & Video
I want to put in my own radio but no sound wants to come out of my speakers
Please check the speakers with a AA cell and if there is response from the speakers then the fault seems to be with the output from the radio,. If not there is short in the speakers or the wiring.
Other wise the radio must be removed to investigate- possible failure of the output.
Sep 03, 2011 | 2003 Mitsubishi Eclipse Spyder
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
Sound not coming. what would be happen?
Have you selected the speaker option correctly. There are two button on the front panel labeled Speaker A & B. Select any one or both and see if you get sound. Make sure there are no objects pushed into the headphone socket.Test while playing a tuned radio station , make sure the tuned light and stereo indicator is on,that way we can rule out wrong connections at the back. Last - you wont hear sound if the Tape Monitor switch is on.
Mar 08, 2011 | Denon AVR-2802
Beautiful picture,no sound
Hello
If your TV displays good picture and there is no sound output from it, please connect an earphone or headphone to its headphone/earphone socket, if provided, and check whether the sound output comes from it or not. If there is sound output from the headphone socket, and not heard from the speaker of your TV, the speaker inside your TV may got damaged. Check the speaker of your TV. For that you have to open the TV. Unscrew it and go for the same type and number and replace it. There is an other possibility, that is if your TVs headphone socket itself can got damged. You can make sure it by after checking your speaker. If the speaker is alright; the socket is faulty. Replace it with same type.
An other fault can occur is Audio Output Ic failure. If it has damaged, you won't get sound output either from speaker or from the headphone socket. You can make sure about it. Keep your ear very close to the speaker side of your TV, switch on the power to TV. If there is a "Thumb" soud is heard, you can make sure that your TVs speaker is Ok, and if there is a "Hum' sound also comes from it, Output Ic is damaged.
If so you have to open your TVs back cover and locate the Audio Output Ic. It can be located by following its speaker wire. The speaker wire goes to Output Ic. Usually it may be screwed into a metal heatsink. Desolder it out of the board, and go for the same type and number. Replacing it will solve the problem.
All the precautions must be taken before opening your TVs back cover. Plug it out from the wall socket bfore doing this. Keep chldren away from you, and not let them even stand beside you. Let an adult be there beside you as a precationary measure.
Read and understand well the above said solutions and go on.
Wish you sucess.
Oct 23, 2010 | RCA 27V514T 27" TV
I get sound only from head phones
Please check you speakers, the connection and the selection of the speakers. If all seems right you might have to check for failure of fuse or loss of contact in the relay or failure of the output relay.
Please check this out. Good day
Aug 12, 2010 | Harman Kardon AVR 635 Receiver
Crate Bass Amp B100 - No sound.
Do you happen to have another speaker that you could hook up to speaker output? This would bypass the amps internal speaker and lf you get sound from that setup, it would mean either a jack failure or possible internal speaker problems. Please let me know.
Jan 24, 2010 | Crate Music
The left side main output won't put out any sound on my Denon AVR-900.
connect your right speaker cable to the left output, if the sound comes out then the problem is on the left speaker ( the cable or the speaker itself ), but if still no sound, then the problem is on the power output of the unit, need to repair them
Oct 20, 2009 | Denon AVR-900 Receiver
No sound coming from speakers Blaupunkt GTA470 Amp
Amp Failure:
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors:
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
Dec 31, 2008 | Blaupunkt PCA460 Car Audio Amplifier
Sony MUTEKI HTDDW1600 Theater System Logo
104 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
