Question about Kelvinator Refrigerators
I have a four plats kelvinator stove, two plates are regulating normally but the other two are are not switching off at the right temperature, what are the possible fault?
Plates overheating, not properly regulating
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
If it's gas they are manual control, only the oven has a thermostat.
Posted on Jun 11, 2014
Wer can i purchase stove switches ,rings,bowls for spiral plates for kelvinator stove
Good luck. If this is as old as I think it is you will be needing to source parts from used salvage. Try an appliance dealer in your area to see if they can source this for you.
Nov 20, 2017 | Kitchen Ranges
Why do the elements of my stove top work at random?
I would contact the MFG. as this sounds like a bigger problem than you need .
Jan 08, 2015 | Stoves Kitchen Ranges
How to regulate flame on a gas oven stove
On a gas stove, you simply choose the desired temperature. If the stove is operating normally, it will automatically adjust the flame.
Aug 05, 2014 | Amana ACS3350AS Gas Kitchen Range
Where can i find my kelvinator stove fuses
Fuses located on the top under panel. Pull the front ends and bring it up. Oven fuse (two of them) separate from burner fuse
Jun 09, 2014 | Refrigerators
Kelvinator stove MODEL KC600BS
can i get a wiring diagram for kelvinator oven switch kc600bs
Oct 11, 2013 | Stoves Ovens
Hot plates go red hot even on low setting on my westinghouse avondale 529 stove
The hot plate needs a new thermostat. When thermostats go bad, there is no control of temperature and they stay on high. The circuit remains closed, not allowing any cycling of power, which regulates the temp
May 16, 2010 | Ovens
Coffee maker did not heat
An electric coffee maker has an electric flow-through brewing water heater with a heating resistor controlled by a temperature dependent regulating switch responsive to the temperature of the heating resistor, and a warming plate heated by the heating resistor for maintaining the prepared coffee at a desired drinking temperature. Apparatus for adjustably prolonging the interruption of heating current 2 to 5 times the normal cooling time of the regulating switch is connected in circuit with the heating resistor and the regulating switch, and a manually actuated small quantity control means connects the heating current interruption prolonging apparatus in circuit with the heating resistor and the regulating switch. The prolonging apparatus may be an adjustable auxiliary electric heater in parallel with the regulating switch and thermally coupled thereto or an adjustable timer in series with the heating resistor and regulation switch and triggered by the opening of the regulating switch
Jan 31, 2010 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
Oven does not get warm, suspect it is a fuses but cant locate it
It is probably due to a broken heating element in the oven. These are relatively easy to replace. You can test it with an ohmmeter. It should measure low ohms. If it is open circuit then it is broken.
Jul 25, 2009 | Stoves 1100DFSID Kitchen Range
Element Glows Red, can not regulate heat
you have a bad gas valve For that one specific burner. The valve is located right behing the selecter knob. You have to take all the knobs off and removve that plate to access them. You will see a switch. Remove the switch and right there is your valve. You need to turn both power and gas off when doing this repair.
Jan 04, 2009 | Whirlpool RF378 Electric Kitchen Range
Refrigerators Logo
143 people viewed this question
Top Kelvinator Refrigerators Experts
Charles T Nevin
Charles T Nevin
Melissa Martin
Melissa Martin
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
