Question about Lexmark JetPrinter X1185 All-In-One InkJet
My cartridges are all the way to the right and not in position to move carriage stuck printer hp 4620
Hp printer all-in-one officejet 4620
5 Suggested Answers
SOURCE: problem after installing cartridges
I gently moved the cardtridge assy. to the left, then I gently strummed the belts that probably centered the sensors. you have to be careful and not do it too hard strum gently like guitar strings .hope this helps
Posted on Sep 24, 2008
Printtech
  • 1087 Answers
SOURCE: Can't change Lexmark Z42 ink cartridge
You can unplug the printer from the power source. With the printer off, open the cover where the cartridge carrier is. Hold the solid white tape found in the middle inside the printer. Slowly drag the cartridge carrier to the center. Replace the cartridges. Close the cover. Plug printer back to the power source. Hope this helps.
Posted on May 03, 2010
Testimonial: "That was too easy. I thought I would break something if I tried to pull it out like that. That a ton."
Printtech
  • 1087 Answers
SOURCE: Jammed Cartridge Carriage
This is a hardware problem. Probably the encoder strip is off-hooked or a mechanical problem inside the printer. I strongly suggest you contact Lexmark Technical Support to further investigate the problem. i hope I can assist you more on this matter.
Posted on Jul 26, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: carriage for the ink cartridges is stuck, the
    Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
    1. Unplug the printer from the power source.
    2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
    3. Remove the used cartridges.
    4. Load the new cartridges. Close the cover.
    5. Plug the printer back to the power source.
    Posted on Sep 01, 2011
    Hp officejet 4630 carriage jam
    Check first:
    Are you printing correctly? Are the papers in their correct position? Look the picture below, is it 100% identical to how your printer looks right now?
    hp-officejet-4630-carriage-jam-g3kwcv4s0uxqjd0jsmqlsidv-5-0.png There are a few ways:
    1. Open the cartridge access door and remove any obstruction in the movement of the cartridges.
    2. Re-install cartridges.
    3. Plug the printer electric source directly into the wall outlet.
    4. Check the picture above and check your alignments again.
    Jul 11, 2015 | HP Officejet 4630 e-All-in-One Printer
    I got message: Turn off then on
    There's an error in the Ink cartridges chip R/W system.
    1. Try to power printer off, Then power on, and when the printer carriage moves from the right side to the left side disconnect the power cord
    2. Remove All cartridges
    3. Gently clean the contacts where the cartridges are located
    4. Gently clean the cartridges contacts
    5. replace the cartridges
    6. move the carriage to the Extreme right position
    7. Check the timing strip. if is dirty, clean it with a tissue paper and hot water
    Hope the Best!
    ADCSFXworks Printing Center
    Oct 19, 2014 | HP Officejet J4550 All-in-One Inkjet...
    My hp officejet 6110 all-in-one carriase are stuck completely and cannot remove cartridges either my hp officejet 6110 all-in-one carriase is stuck as for left and want move at all
    Try to power off and unplug the printer, then force the carriage to move with your hand
    When the carriage moves, place it in the extreme right position, then plug in and power on :D
    Aug 17, 2014 | HP OfficeJet 6110 All-In-One InkJet...
    Why doesn't my HP OfficeJet 7500A carriage move? It is jammed
    Try to turn it off, open cover and move carriage a little bit by hand; don't push too hard. For some time it'll get back to life.
    Feb 02, 2013 | HP OfficeJet Office Equipment & Supplies
    Empty carriage stuck in my HP 7500A printer
    Hello,Lester Makang
    Your carriage got stuck in service station,is there any noise coming from the right side of printer then there will be broken gear.
    Power on your printer,after you got carriage jam error open cartridge access door and wait 5 second when you see that gears trying to move,use your hand to pull your carriage to left side.Don't use much force.If your carriage got free then install your print head and cartridges.If this will happen again then take it to service center they will change the service station or broken gear but the cost goes much high.
    Nov 06, 2012 | HP Officejet 7500a E910 Multifunction...
    HP Photosmart C3180 carriage permanently stuck on right. How to fix this?
    If the carriage totally stuck on the right side of the printer, Unplug the printer from Power outlet.
    Open the front access door. You will see the cartridges. Remove the cartridges. Check for any paper stuck in the Carriage Rod. Try to manually move the carriage 5-6 times left to right and it should move without any trouble. Put the cartridges back into the Cartridge slot and power on the printer
    If the Carriage does not move manually, there could be chances the printer needs mechanical repair as its broken.
    Regards,
    Sean
    Sep 16, 2012 | HP Photosmart C3180 All-In-One InkJet...
    Printer says "Open Door Clear Cartridge Jam" How
    You might wanna try removing and reinserting the cartridges and make sure that they are properly fitted in.
    Sometimes cleaning the cartridge and the carriage where you took out the cartridges from with a damp lint free cloth does the trick.
    If you still have that message, open the cartridge access door.
    If the carriage is stuck at the right side of the printer, move the carriage to the left side by hand. If it's stuck on the left side, try moving it by hand in the right side of the printer. Then while the printer is turned on, unplug it from the wall outlet and then plug it back in.
    If the printer does not turn on, use the power button.
    Try printing again.
    Feb 03, 2011 | HP OfficeJet 6110 All-In-One InkJet...
    Carriage cradle stuck on right side!
    Carriage system is broken. Uneconomical to repair. Sorry
    Dec 27, 2008 | HP Officejet 5610 All-In-One InkJet...
    Cartridge jam problem
    It’s a carriage jam, the carriage is plastic or metal that hold the cartridges and move from side to side to print ,try to move the carriage and see if it’s stuck or not
    Jun 24, 2008 | HP OfficeJet 4255 All-In-One InkJet...
    Lexmark JetPrinter X1185 All-In-One InkJet Logo
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
