Question about Eckla Multi-Rolly Cart
Where can I buy just one cigarette size anti gps jammer,tw-gj2000
Why are GPS jammers prohibited?
The use of jamming devices can place you and other people in danger. In order to protect the public and ensure access to emergency services without interference the use, sale and the manufacture of jammers is prohibited.
Feb 06, 2013 | Home Security
What can happen if I use a GPS jammer?
The operation of a jammer in the United States and in most of the countries is illegal and may subject you to substantial monetary penalties, seizure of the unlawful equipment, and criminal sanctions including imprisonment.
Can mobile network jammers block bluetooth
Yes and No!
Most Jammers can block bluetooth communication, but not all jammers can do that. Jammers are special devices used to interfere with communication frequencies and various signals have different frequencies. Most jammers today can block every communication signal including 3G, Bluetooth and Wi-Fi but jammers are occasion specific and you can easily find the type of jammer you want. Jammers can be customized to suit your jamming requirement.
Innovatiview is one such provider that lets you customize your jammer.
Source:
www.innovatiview.com
Jan 28, 2013 | Cell Phones
I have a 1999 Buick Century. When I plug my GPS power adapter into the cigarette lighter outlet, I blow the fuse. ---Can you suggest a solution? ---How many amps are in that...
Probably a 15 to 20 amps..If you use the cigarette lighter does it also blow the fuse ,you may have a short in the circuit..It should be able to handle the GPS..Dont increase the fuse size,you can cause bigger problems
Sep 05, 2011 | 1999 Buick Century
I bought at Garmin Nuvi 1300 GPS for my daughter for Christmas. She just tried to use it for the first time yesterday and it doesn't fit the cigarette lighter. What can we do now???
It's strange if the plug doesn't fit the cigarette lighter socket. They can be a tight fit so if you find it a little big for the socket try putting pressure on it to push it in. If it absolutely won't fit you can buy cigarette lighter plugs in car accessory shops. If you can get one that does fit you can cut the one that's on the lead off and fit the new one.
If you cannot get any plug to fit you can get the lead wired permanently into the car. Any garage would be able to do it for you.
Feb 01, 2011 | Garmin Nuvi 660 GPS Receiver
Porsche cigarette lighter is bigger than standard cigarette plug
Found a cigarette lighter assembly that is the standard DIN/SAE size that is a direct replacement for the one in my car.
Aug 31, 2009 | Garmin zumo 550 GPS Receiver
Magellan Maestro 4250 fuse
It is a Fast Fuse Glass type 5 x 20mm, 2A, 250v. Magellan 4250 can only take 1A of current at 5Volts Radio Shack
Jun 10, 2009 | Magellan Maestro 4250 GPS
GPS plug do not fit in car cigarette lighter
Buy a adapter for your cigarette lighter socket that has multiple sockets with one that will fit the Garmin adapter.
I've never heard of a problem you are having??
Are you using a Garmin plug?
If not get one.
May 08, 2009 | Garmin Nuvi 660 GPS Receiver
Removing vehicle locator from my dodge caravan
An easier way is to get a gps jammer. They make nice ones for cheap. Check the import sites from china. They make a small unit that plugs into cig lighter socket, and is no bigger than your thumb.
http://tayx.manufacturer.globalsources.com/si/6008827809982/pdtl/Security-products/1006202554/Car-GPS-Tracker-Jammer.htm
or
http://www.google.com/search?hl=en&source=hp&q=china+Car+GPS+Tracker+Jammer&aq=f&oq=&aqi=
Apr 15, 2008 | Vehicle Parts & Accessories
Installation / wiring
Yes, you can do what you said above. The only issue I see is that you should still add an inline fuse between the GPS and the power source you will be connecting it to.** SEE NOTE BELOW **
The cigarette lighter plug has a fuse in it. Most of the fuses you have in the car start at 5 Amps and go up in value, like 10A, 20A, etc.
The problem is these values are way too high should the GPS have a catastrophic failure or the GPS power leads get pinched or shorted to ground. You'll burn up the GPS and its wiring before the auto fuse blows.
You need a low rated fuse (probably 1/4A) inline with the GPS. This will give you adequate protection. You can buy inline fuse cords at Radio Shack.
** NOTE **
Check to make sure that the DC output of the cigarette adapter is indeed +12VDC and not some lower voltage indicating that there is an internal regulator circuit. I took a look at the 660 owners manual and it says the GPS input voltage is +12VDC, so you should be ok. I also hear there is some electronics inside of the cigarette lighter plug. It may have to do with charging the internal GPS battery. You could always take apart the cigarette plug and remove the internal board and use it in your hard wiring to your vehicle.
Once you get it all working, you could duplicate what you built for another vehicle. You can buy the cigarette adapters online.
Please let me know if I can be of further assistance to you.
- Jim
Feb 13, 2008 | Garmin Nuvi 660 GPS Receiver
Eckla Multi-Rolly Cart Logo
482 people viewed this question
Top Eckla Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you an Eckla Medical Expert? Answer questions, earn points and help others
