Question about Electrolux Washing Machines
Samsung sw50usp washing machine
Its control board is defected.. any button it press it regulates one function (water selection)
SOURCE: washing machine
wont spin
Posted on Dec 08, 2007
  • 9 Answers
SOURCE: Lights are on, but wont start
The water pump can hum and still have a defective coil.
Posted on Aug 31, 2008
  • 49 Answers
SOURCE: Programming the 00-749825 Control Board on a Hobart AM14C
That board comes with directions. if not go to hobart and have them copy you one out of a new boards box
Posted on Sep 30, 2008
SOURCE: Samsung washing machine SW50USP. Machine
I've just had the same problem with my Samsung SW50USP and had a technician out to have a look at it. Apparently the electronics are fried and it would cost much more than it's worth to fix. Time for a new machine unfortunately.
Posted on May 28, 2011
caroldon
  • 17130 Answers
SOURCE: Samsung Washing Machine won't start
Your program controller unit is working but it must be ensured that there is output on every cycle to the desired output controls. So the inlet valve must work and the motor must run when the water level is triggered by the level controller. So use a meter to check before we can suspect the controller.
Posted on Nov 11, 2011
What is the Aqua Preserve button for? It does nothing when pressed during a wash cycle.
Hi it reduces waste of water by reusing last rinsed out water ...won't function when u select rinsing twice ..cheers
Jul 15, 2017 | Samsung Washing Machines
I have a problem with a samsung wahing machine model WA95V3. No power coming on water solenoid valve when you switch on the push button,No error coming ,all the function is on.
you will find the solenoid is probably faulty and shorted out that part of the module, cheapest fix is to swap the hoses over at the taps and then select hot wash and cold water will come through the hot solenoid
Mar 08, 2014 | Samsung Wa95v3 7.5kg Washing Machine For...
Samsung j1455av front loader washing machine lcd control panel frozen
when you disconnect from power you should wait about 5 minutes prior to reconnecting. Also check the panel to be sure you didn't place it into a "lock" mode. This can be corrected simply pressing the correct selection(s) to "unlock" the control panel.
Make sure the dispenser drawer is fully closed as some units prevent operation until properly sealed to prevent water leakage.
Nov 22, 2017 | Samsung Washing Machines
All of my washing machine's "FUnction" buttons do
Change the program controler unit /the board if you need to get access to all the programs.
Remove the controller unit and make sure that the connectors are tight. Make sure the water level sensors , the door switch is working.
If there is no result the program controller is a suspect.
Jan 21, 2011 | Samsung SW62ASP Top Load Washer
Samsung washing machine SW50USP. Machine powers up, all buttons and settings work but when press start button the cold light and wash light start flashing but doesnt start to wash. After 2 minutes 4E shows...
Dec 26, 2010 | Washing Machines
What does LF mean?
It is a long fill error. It flashes when the machine control board detected no change in the water level or the water level is not reached in a certain period of time during the fill cycle. Water is probably not entering the tub due to the water inlet valve not functioning or water enters the tub but not properly due to clogged fill hose screens.
Press the Pause/Cancel button to clear the error on the display. Remove the fill hoses from the water inlet valve assembly at the back of the machine and check the screens. Clean the screens and replace it if necessary. Make sure that the water supply valve is open and water is present.
Put the machine in standby mode (only the Clothes Clean indicator is on) and activate the Manual Diagnostic Test Mode to check the operation of the water inlet valve.
  1. Select any one button except Power, Stop, and Stop.
  2. Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds
  3. Press the same button when all indicators on the console are illuminated and "88" is displayed on the Estimated Time Remaining display. A single beep sounds and display shows the two digit console ID number for 3 seconds. The displayed ID number will change to "00" and the Add a Garment indicator will flash.
  4. Select Whitest Whites cycle.
  5. Press Start>Wash/Rinse Temp. The water inlet valve should turn on and fill the tub according to the Wash/Rinse Temp selection.
  6. Press Start to turn off the valve.
  7. Press Stop or Power button to exit diagnostic test mode.
Feb 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My neptune TL stops at 11 minutes and flashes "nf"
mattscott;
My comments are based on the FAV6800A/FAV9800A.
NF = No Fill. Your machine has reached a Control Board internal timer and has not seen proper signaling from the Pressure Switch for expected water fill for the wash cycle selected.
Possible fail points.
1. Pressure Switch is not signaling for properly tor water fill.
2. Water inlet valve is restricted or not functioning.
Please confirm your machine model number is it a FAV6800A or FAV9800A? I’m going to assume your machine model is a one of those models. Here is a link for the FAV6800A/FAV9800A Service Manual.
If you can let me know how much water is in the wash basket when your Control Board triggers the no fill error “NF” to the display? I would prefer you select Quick Wash cycle with minimal machine settings for the water fill. Do you have the issue with a cold temp select fill, a warm/hot temp select fill?
If you want to DIY I would suggest you become familiar with how to get in Service Mode. We may need to go to page 16 of the SM and possible check for correct Pressure Switch transitions in Board Functional Test Input Control Keys.
We will continue after your feedback…..Rich
Jan 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Washing Machines Logo
32 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
