Question about eMachines EL1360G-UW11P Desktop PC
Driver rubber ring inside DVD is detached - eMachines EL1360G-UW11P Desktop PC
    Genius:
  • eMachines Master
  • 1,479 Answers
I've already answered this. please don't submit multiple posts for the same issue.
Posted on Mar 19, 2014
DVD coming apart
you can either remove the drive from the tower, dismantle it and work out where the drive band goes then reassemble everything or just buy a new dvd drive for peanuts and simply replace it.
Mar 19, 2014 | eMachines EL1360G-UW11P Desktop PC
Tip
How to fix DVD (not eject)
Please read my tips on how to fix the DVD players (not eject).
This problem is common on all DVD players such as VCD players,DVD/VCR combo,or even DVD ROM..
This simple tips is very easy to perform even you are non-pro in electronics.
This are the steps on how to do a D.I.Y troubleshooting:
  1. Remove the cover of your DVD player.
  2. Look at the DVD or CD tray assembly.
  3. Remove the whole CD tray assembly by loosening all screws at the left and right corner of the CD tray assembly and also you need to remove the front panel of the ejecting tray to get the whole CD tray assembly away from the DVD player for further repair and check-up.
  4. After that,look at the bottom of the DVD or CD tray and try to find out where's the motor that controls the ejecting tray.It is usually have a rubber O-ring or mini rubber belt that control the gear of ejecting tray
  5. Next,when you found the ejecting motor.Try to look at the rubber O-ring or mini rubber belt condition,if it is cut,loosen or disconnected from the motor.
  6. If the rubber belt is in good condition,check the ejecting motor.There are 2 ways of testing the motor,first the resistance checking-you should have a ohmmeter or multimeter (resistance or ohm range) point your (+/-) test prove to the terminal of the motor to measure the resistance.Secondly the actual testing-this procedure you need a battery 3vdc,connect the negative(-) terminal of the battery on the black wire of the motor and the positive(+) is connect to the red wire.If the motor is not spin-up replace it with the same type,rating,voltage and value.
  7. If you already done this procedure and the problem is still there after you replace the defective parts,if any.The problem could be the motor ejecting driver that found on the main board.This is not for D.I.Y because of the parts inside main board is very sensitive and hard to replace.If the trouble is on the main board you have to replace the whole main board or buy a new player.
Thank you for reading my tips.I hope to help you!!
on Jun 08, 2011 | Televison & Video
Tip
How to repair DVD (not eject)
My tips on how to fix the not ejecting DVD.
These are the steps on how to do a D.I.Y troubleshooting:
  2. Look for the DVD or CD tray assembly.
  4. Then look at the bottom of the DVD or CD tray and try to find out where's the motor that controls the ejecting tray.It is usually have a rubber O-ring or mini rubber belt that control the gear of ejecting tray
  5. Next,when you found the ejecting motor,try to look at the rubber O-ring or mini rubber belt condition,if it is cut/loosen or disconnected from the motor.
  6. If the rubber belt is in good condition,check the ejecting motor. There are 2 ways of testing the motor.
  • First,the resistance checking-you should have a ohm meter or multimeter (resistance or ohm range) point your (+/-) test prove to the terminal of the motor to measure the resistance.
  • Second is the actual testing in this procedure you need a battery 3vdc,connect the negative(-) terminal of the battery on the black wire of the motor and the positive(+) ,connect to the red wire.If the motor is not spin-up replace it with the same type,rating,voltage and value.
on May 11, 2011 | Televison & Video
Have a lg blue ray player that makes loud noise and says disc error
This is a hardware issue.
The LG drives motor attaches to the top rotor by help of a magnet, which fixes the disc so it can spin symmetrically. For this to happen, the drive unit has to have a fixed piece of metal. Now, this particular metal ring gets loose quite easily and then permanently sticks on the top of the unit, where the magnet is situated. As it is now loosely attached to the top of the drive unit, the optical disc will spin errandly, that is where the clunking, rattling noise comes from.
To fix it, you must open the LG player and the drive unit, which is really simple to do, and glue the metal ring back in its original position.
Thats how I did it and the drive now purrs along quietly.
PS
LG really produces those units cheaply, that is the reason the metal ring detaches so easily.
Jun 03, 2012 | LG BD670 Bluray 3D Player
How to change cv joints
I would replace the complete axle assembly,
it would be cheaper and come with a warranty.
Instructions
  1. Remove the CV Joint
    • Remove the boot straps from the CV joint using a standard screwdriver or a pair of diagonal cutting pliers.
    • Slide the boot back over the interconnecting shaft.
    • Get Chevrolet Info at InsideLine Free News, Videos, Photos & More!
      Detach the stop ring at the base of the CV joint assembly using a pair of snap ring pliers.
    • Pull the CV joint assembly from the interconnecting shaft to force the snap ring at the top of the shaft through the CV joint assembly.
    • Tilt the inner cage (the cage holding the balls in place inside the housing) in different angles to remove the six balls. Use your thumb or a hammer and a wooden dowel, if necessary.
    • Tilt the inner cage enough to remove it from its housing.
    • Rotate the race inside the cage--the part that holds the balls against the inner cage--and remove the race from the cage.
      Replace the CV Joint
      • Apply a thick coat of grease to the new CV joint race using special high temperature/high pressure grease (see Tips below).
      • Install the race inside the new cage. Then install the cage/race assembly inside the CV joint housing.
      • Tilt the cage at different angles and fit the new balls in place.
      • Slide a new CV joint rubber boot over the interconnecting shaft.
      • Install a new snap and stop ring on the interconnecting shaft.
      • Push the interconnecting shaft through the CV joint assembly to force the snap ring through the assembly.
      • Apply a thick coat of CV joint grease to all moving parts of the assembly.
      • Apply a coat of CV joint grease to the inside of the rubber boot. Then slide the boot over the CV joint assembly.
      • Install the boot straps at each end of the boot, and tighten the straps using a clamp tool or screwdriver, depending on the type of clamp.
Mar 22, 2012 | 1997 Chevrolet Cavalier
JVC-XVLTR1 the tray is locked and will not open with the button or the remote
Good day!
Your problem is on the ejecting motor,the broken rubber that connected to the mechanism or on the driver of the ejecting motor...
This are the procedures on how fix that problem:
1. Open the cover by removing all screws that holds the cover.
2. Try to remove the lens assembly one set including the CD tray.By unscrew the lock of that mechanism assembly.
3. Try to see the ejecting motor if the rubber O-ring is okay and remove the motor to check the resistance to determine weather it good or bad.The reading is not more than 25 ohms or or try the actual testing using a 1.5v battery if the motor spin up that's good.
4. If the rubber and the motor is good.This is gonna be a major trouble when the driver is defective this not for D.I.Y.Its better to it to the qualified service technician for immediate remedy or solution for that.
5. But when you found the trouble like on steps 2 and 3.Replace immediately on the same type and ratings.
I hope this solution will be helpful.Thank you and good luck.
Apr 24, 2011 | JVC XV-LTR1 DVD Player
Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Jun 11, 2010 | Maytag NFW7200TW Front Load Washer
Detached rubber pipe
it sounds like if attached to the exhaust a 02 sensor if not then it may go to a sensor to the transmission or it may be the engine temperature sensor
Sep 11, 2009 | 2000 Ford Focus
LVW - 5005
Remove the cover of LVW and access the DVD assy,unscrew the 4 screws holding the DVD assy to the LVW bottom,remove the top and bottom shield (also 4 screws)and remove the top black plastic cover (4 screws).You will access the DVD spindle.Remove the disk if you still have a disk stuck inside.Visually check the spindle sticky rubber ring,most likely some sticky material migrated on top of the rubber ring and your DVD was stuck on it. Clean the best you can with a cleaner and a non lint cloth.I used a cleaner/degreaser for electronics.DO NOT POWER your LVW BEFORE reinstalling the black plastic cover.There is a laser inside !!! You may now try and if the drawer opens and closes, reassemble everything opposite way you disassembled.
Nov 18, 2007 | Lite On LVW-5005 DVD Recorder
Kirby generation III
Hello!
Inside the machine end of the hose is a round rubber ring that holds the hose into the hose end. Take a flathead screwdriver and push the edge of the rubber ring towards the center and downward. MAKE SURE THAT YOU DON'T STAB YOURSELF IN THE PALM WITH THE SCREWDRIVER! lol
It should come out with some hard pushing. Now, just push the edge of the ring inwards again and hold it in place with your other hand. Put it up inside the new hose end and then use the screwdriver to smash the edge back out again to hold it in the new hose end. Hope this helps. If you need any more help, I have a shop on a POPULAR auction site under the exact same ID as I am using here. Feel free to contact me with any Kirby question.
Marci (b0sslady2001)
Oct 15, 2007 | Kirby Generation 3 Bagged Upright Vacuum
eMachines EL1360G-UW11P Desktop PC Logo
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
