Question about Saeco Royal Coffee Bar Coffee Maker, Espresso Machine
Ventilate message, but no air in system
My Royal Coffee Bar will only brew, steam, or rinse for a few seconds. The cycle will end early, and it will display ventilate. The message will not go away unless I run the hot water cycle until the display says watertank empty. The next coffee cycle will then abort early and start the ventilate error again. I also discovered that it does not matter how much hot water I use to clear the error. The key is to make the magnet in the water tank drop while the hot water is running. I can clear the error by just using a toothpick to force the magnet down while pumping hot water. Does this sound like a bad flow meter? If so, is it hard to replace?
  • Anonymous Mar 20, 2014
    The ventilate message shows however the steam wand and hot water dispenser both work.
  • 1,089 Answers
HI Sorry, but that sounds like a bad flow meter. The flow meter is not that hard to replace, with a little common sense, but the new flow meter should be the brass one. There are some tricks to getting the top back on, Pull forward on the bypass doser chute a little so it will center in the opening. You don't have to disconnect all the wires that go to the top. They are long enough that the top will set behind the machine carefully. Remember the tubes that go to the flow meter. You don't want to get them backwards.
Posted on Jun 14, 2009
I have a Seaco Royal Professional coffee machine and it is telling me to ventilate, what does this mean and how do I fix this problem?
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out. This mean that any steam or air blocked in the water system must get out from steam wand.
Good luck
Jul 26, 2010 | Saeco Royal Professional Espresso Machine
My Saeco Incanto Sirius machine keeps asking for yet another VENTILATE cycle
This means the water cannot flow through the machine. Normal fix is to prime the machine (turn water dispenser on, fill a cup) or descale the machine. Go through the menu, select descale, enter, then turn the steam knob fully anti-clockwise. You should put the descaling solution in the water tank first.
If you have the auto-descale in the menu then run it. Run the solution through the machine twice. Then rinse well.
Oct 03, 2008 | Saeco Vienna De Luxe Espresso Machine
Ventilation Problem
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Jun 25, 2010 | Saeco Royal Professional Espresso Machine
Keep getting ventilate message - won't ventilate and cannot operate steam or grinder w/ ventilate message
Try this run the hot water cycle for a few seconds, it that works, try steaming if you get the message again clear it by running the hot water cycle and then go to steaming, this time push in on the knob after you open it, it that works, then the tap rod or the valve assembly needs to be replaced.
May 01, 2010 | Gaggia Titanium Espresso Machine
Constant ventilate message
mine says the same thing, run hot water from the hot water/steam nozzle until the message disappears. do this a few times, mine is working fine after doing that. hope this helps
May 09, 2009 | Saeco Royal Professional Espresso Machine
Display says "ventilate" and won't operate
run hot water from the steam nozzel (for few seconds) to purge the air out of the system
you propabably ran out of water making your previous coffee?
Apr 08, 2009 | Saeco Royal Professional Espresso Machine
Gaggia Synchrony Compact Digital Problem
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
/Mirran
Nov 01, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
After descaling the Saeco Royal Professional, all features remain functional except for the coffee dispensing. It will grind and the brew unit will go through its usual cycle, but no coffee will get...
The first descaling cycle likey dislodged some calcium which then found its way into a valve or water line. A second descaling cycle resolved the problem.
Oct 06, 2008 | Saeco Royal Professional Espresso Machine
Ventilate
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
If this does not work, feel free to contact us on our website for more help.
For Saeco Parts or Cleaning supplies for your espresso machine visit www.CeriniCoffee.com
May 26, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Coffee Bar Coffee Maker, Espresso Machine Logo
441 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
