Question about eMachines EL1360G-UW11P Desktop PC
DVD coming apart
A rubber ring inside the DVD drive have been detached from unit
    Genius:
  • eMachines Master
  • 1,479 Answers
You can either remove the drive from the tower, dismantle it and work out where the drive band goes then reassemble everything or just buy a new dvd drive for peanuts and simply replace it.
Posted on Mar 19, 2014
Driver rubber ring inside DVD is detached
I've already answered this. please don't submit multiple posts for the same issue.
Mar 19, 2014 | eMachines EL1360G-UW11P Desktop PC
Have a lg blue ray player that makes loud noise and says disc error
This is a hardware issue.
The LG drives motor attaches to the top rotor by help of a magnet, which fixes the disc so it can spin symmetrically. For this to happen, the drive unit has to have a fixed piece of metal. Now, this particular metal ring gets loose quite easily and then permanently sticks on the top of the unit, where the magnet is situated. As it is now loosely attached to the top of the drive unit, the optical disc will spin errandly, that is where the clunking, rattling noise comes from.
To fix it, you must open the LG player and the drive unit, which is really simple to do, and glue the metal ring back in its original position.
Thats how I did it and the drive now purrs along quietly.
PS
LG really produces those units cheaply, that is the reason the metal ring detaches so easily.
Jun 03, 2012 | LG BD670 Bluray 3D Player
Bremshey (Tunturi) Orbit Control S elliptical belt alignment
Dear Si: Please do the following>
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Remove the bolts connecting the swing arms to theelliptical's upright. Detach the swing arms from the upright, then spread alayer of machine grease over the axles on the upright. Reattach the arms to theupright.
sincerely.
ernesto cuadra
managua, nicaragua. c.a.
Feb 12, 2012 | Exercise & Fitness
My sylvania portable DVD player won't read discs the display says No Disc after the spin. What do I do?
I had same problem with a sylvania portable DVD: no disc. After cleaning the laser didn't work, I took the unit apart, and found that there is a small gear that moves the laser back and forth across the disc.. The gear could easily be misaligned with a rough bump along the drive.. All I did was realign the gear to the center where the disc was. Inside, there was even a small lever to pull back on to do this.. I also noticed a small Ribbon cable connecting the laser to the main board. Again, seemed nimble. I detached the ribbon, cleaned the connectors with alcohol and reattached. Happy to say, it works perfectly now. :). Good luck.
Oct 10, 2011 | Sylvania SDVD7027BL Portable DVD Player
Screen went blank. Touch still works but nothing g is displayed on the screen
Sounds like the ribbon cable inside the unit to the screen has become detached or loosened. May have to pull unit apart carefully to re-attach it. If you go down this path be very gentle as they have a habit of ripping...
Jun 25, 2010 | Jensen's VM9312 Car DVD Player
Dvd tray on Dell Inspiron 530 hard drive not opening. The dvd in the tray is not loose because the program runs so it's not the dvd preventing the opening process. The "door" tries to open and when I...
from what it sounds like.... its a gear problem. see, inside your dvd drive, there are a set of gears, and a little "rubber band" that opens and closes the dvd drive. either A). a gear has stripped itself(or broken) or b.) that "rubber band" has broke, and has gotten itself stuck(probably in the gears). Good luck, and i hope that it wasn't an important disk.
Feb 23, 2010 | Dell Inspiron 530 Desktop Computer
HP Pavillion zd8000
double check for screws. there is a screw or two that your missing. normally the unit will come apart when all screws are removed. also make sure that you are not standing on carpet. when working inside of the computer.
Nov 18, 2009 | HP Pavilion zd8000 Notebook
Had infamous extra part once I put my steam cleaner back together
Steve, The o-ring goes inside the turbine assembly on the metal shaft.
Mar 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Kirby generation III
Hello!
Inside the machine end of the hose is a round rubber ring that holds the hose into the hose end. Take a flathead screwdriver and push the edge of the rubber ring towards the center and downward. MAKE SURE THAT YOU DON'T STAB YOURSELF IN THE PALM WITH THE SCREWDRIVER! lol
It should come out with some hard pushing. Now, just push the edge of the ring inwards again and hold it in place with your other hand. Put it up inside the new hose end and then use the screwdriver to smash the edge back out again to hold it in the new hose end. Hope this helps. If you need any more help, I have a shop on a POPULAR auction site under the exact same ID as I am using here. Feel free to contact me with any Kirby question.
Marci (b0sslady2001)
Oct 15, 2007 | Kirby Generation 3 Bagged Upright Vacuum
eMachines EL1360G-UW11P Desktop PC Logo
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
