Question about Microsoft Xbox 360 Console
Xbox power orange light is on p. supply xbox don't power up
    Problem Solver:
  • 7 Answers
I had the same issue with an origional xbox 360. I tried different cables but all the same. I jumped on youtube and found how to get into the internals and was quite easy. Then I spent ages cleaning all the dust and crud out. Then it worked well. The power box on the cord also has a fan and I also cleaned it out. Well does in australia. Not shure about overseas models. Could be worth ago
cheeers.
Posted on Mar 20, 2014
  • 101 Answers
SOURCE: No power
there is a fuse that is located inside the console check see if it's burn.
Posted on Apr 21, 2008
localwonder
  • 6784 Answers
SOURCE: xbox 360 not powering up at all. power supply
An orange light is illuminated on the power supply for one of the following reasons:
* The console is turned off.
* The power supply is disconnected from the console.
* The power supply cord is not fully inserted into the power socket of the console.
* The power supply is faulty.
* The console is faulty. (The console might be faulty if it does not turn on when the power supply light is orange.)
The power supply has several built-in safeguards to help prevent damage to either your Xbox 360 console or the power supply itself. The power supply will automatically turn off if either the current flow, the voltage, or the temperature is too high. When the power supply turns off for any of these reasons, the light on the power supply will turn from green (normal) to orange or to red, or the light will turn off. When the power supply light is green, the power supply is working correctly. What you are experiencing is an over heating issue, that may have damaged the supply.
With that being said, i would try to reset the supply by disconnecting the unit from the console, and unplugging the power supply unit from the wall socket for 5 minutes. Once the 5 minutes have passed, reconnect the unit to the console, and plug the power supply into the wall socket. If the console dose not power up, and the supply unit is still showing an orange illuminated operating light, this will confirm that the power supply unit will need to be replaced. Contact Microsoft for the correct replacement parts needed(power supply unit)
TIPS FOR PREVENTING OVERHEATING ISSUES
* Do not block any ventilation openings in the power supply.
* Do not put the power supply on a bed, on a sofa, or on any other soft surface that might block ventilation openings.
* Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
* Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
* Do not use an unlicensed accessory, such as a replacement power supply that was not manufactured by Microsoft, or any accessory that plugs in between the Xbox 360 console and the power supply.
* Plug the power supply directly into a working wall outlet. You may have problems with the power supply if you use an extension cord or a power strip if the extension cord or the power strip is faulty or cannot supply the required power to the console.
* If you are not sure about the reliability of an AC power outlet, power circuit, or power cabling, do not use it. Contact an electrician.
Posted on Oct 26, 2009
SOURCE: MY Power Supply light is blinking orange and xbox
I hate it when people put "Red ring of Death" for a ORANGE flashing light on the power bar and actually a red ring on the front of the Xbox (which then would mean the red ring of death)!
I just fixed this problem for a friend. They had a contoller charging lead plugged in to the front which had a bad connection in it. Thats all it was so I just unplugged the charging lead and it worked.
So Unplug everything except the power and see if it works 1st, if it does then plug things back in one by one and see when it starts to flash and thats your problem lead there.
Posted on Nov 10, 2009
  • 60 Answers
SOURCE: My Xbox 360 won't turn on.
Make sure you have pushed the lead in the back of your xbox all the way! once pushed in the back you should hear it click, if the power supply is from another xbox differant year in manufacturing date, then the power supply would not be compatable as the plug in the back would not push in all the way.
Posted on Dec 04, 2009
  • 14 Answers
SOURCE: My xbox 360 elite power supply is blinking orange
Either your power supply is bad or the console has a short. You can check this by trying another power supply. If it works, then the problem is with your power supply. If not, then the console needs to be professionally fixed.
Please visit our eBay store at http://stores.ebay.com/Garons-Biz or from garonsbiz.com for all of your Xbox 360 and PS3 repair item needs.
Posted on Jul 02, 2010
My xbox power box is displaying the amber light and the xbox wont switch on is this related??
An orange light is illuminated on the power supply for one of two reasons. Either the console is turned off or the power supply is disconnected from the console. The orange light means that the power supply is in standby.
Even if the console is turned off, the power supply light may still be illuminated orange. This can occur if the power supply cord is not fully inserted into the power socket of the console.
Click Here For Toubleshooting
My YouTube
Click Here For Live Tech Support
Apr 18, 2013 | Microsoft Xbox 360 Console
Power supply light stays orange and wont turn on the XBOX PRO. HELP!
I hope this helps The power supply light is orange for one of the following reasons:
  • The console is turned off.
  • The power supply is not plugged into the console or the connection is not tight.
  • The power supply is not functioning properly.
Note An orange light usually indicates that the power supply is connected to electricity and ready to power the console. When you turn on the console, the power supply light should change from orange to green. If your console does not turn on, please see the following Knowledge Base articles: 907588 (http://support.microsoft.com/kb/907588/ ) Your original xbox 360 console will not turn on
2122656 (http://support.microsoft.com/kb/2122656/ ) Your xbox 360 S console will not turn onIf the console will not power on and you have tried the troubleshooting steps in the above article, your power supply will need to be replaced.
Contact xbox Support to obtain a replacement power supply. For information about how to contact xbox Support, visit the following website: www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Jan 04, 2011 | Microsoft Xbox 360 Pro System Console
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Tree lights in red
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
Mar 23, 2010 | Microsoft Xbox 360 Console
My 360 does not have power to console. the light
Have you tried removing all extra accessories?
Xbox.com states:
Mar 01, 2010 | Microsoft Xbox 360 Console
Xbox won't power up, orange light is on the power brick
Are you using a plug and play kit? if so disconnect it, mine does that sometimes, if thats not the case comment me,I would write them all down but I am getting a bit fed up with writing lots of solutions to problems and getting no response from the person I give the time to help.
Feb 13, 2010 | Microsoft Xbox 360 Console
360 won't power up power supply good is there a fuse
They dont have a fuse in side them , it could be dry solder joints on the main pcb where the power plug goes into the xbox, make sure you try your power supply on another xbox as well as your xbox on another power supply. Also check the led on the power supply is green when its running, if the light is orange or red(whislt running, the light will be orange when in standby) .If your led on the power supply is red , you have a faulty power supply. Good Luck.
Sep 24, 2009 | Microsoft Xbox 360 Console
Power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Apr 10, 2009 | Microsoft Xbox 360 Console
Xbox360
Sep 06, 2008 | Microsoft Xbox 360 Console
Xbox 360 red lights power supply light stays yellow
you have to disconnect and reconnect the power cables to the 360. Orange/yellow light means that your power supply is on a standby mode and the 360 is not getting enough power/electricity inside
Mar 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
19 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
