Question about Acer X193W LCD Monitor
HP Pavillion zd8000 with less than full screen view
I am recieveing a used HP Pavillion zd8000 with lines in the screen. A Acer X183H LCD monitor has been purchased. When hooked up to the laptop only get partial screen, want a full screen view. Is there a setting that needs to be changed? Please inform me how to go about this. Thanks
  • 4 Answers
Try going to control panel (in windows) and clicking on the icon that looks like a monitor. there should be some display settings in there that can be adjusted. i would start by making sure the settings are set up to display on the external monitor then look at the resolution settings and the aspect ratio settings.
Posted on Jun 14, 2009
  • 518 Answers
IF YOU GO TO START, CONTROL PANEL,DISPLAY, SETTINGS YOU SHOULD BE ABLE TO SELECT YOUR MONITOR THERE,GOOD LUCK MATE.
Acer x191w white display and lines?
possible a dropped monitor. bad 19" lcd monitor possible internal damage;
also check your cables connecting the 2 devices.
Aug 22, 2011 | HP Pavilion zd8000 Notebook
My Acer X183H LCD monitor changes to a green hue and often will flicker causing the background white to go greenish or gray rapidly. How can I fix this?
You want to make sure that the VGA connector is fully secure. Also the VGA connector is hooked in and screwed in the back of the computer If it has a loose connection, remove the connector and check if has all pins in it. If one of the pins is loose then its time to replace the VGA cord. If this doesn't work it might be the LCD screen messing up internally.
Jun 05, 2011 | Acer X183H 18" Monitor
I have virtical lines on lap top
Once you start to get vertical lines on your LCD screen, it's usually time for a new screen. I would check first by running an external monitor just to be sure it's not the video card.
May 19, 2010 | HP Pavilion zd8000 Notebook
HP Pavillion zd8000 won't power up
Try attaching a normal VGA desktop monitor to it. There should be a plug either on the sides or the back of the laptop. A blue one. That way you'll be sure.
Apr 17, 2010 | HP Computers & Internet
HI, Thick white vertical line on screen
your lcd screen damaged.u need to replace it with new.
Dec 08, 2009 | HP Pavilion zd8000 Notebook
Same problem with my zd8000 HP Pavilion laptop
what has happened with your notebook is a simple wear factor. on the LCD screen there are ribbon cables witch join the main PCB controller head to the LCD laminated portion (what you see) have begun to wear. i have just recently replaced a screen because of the same issue. try gently flexing the the screen and see if the lines dissappear. next open the screen up, and check the cable running to the back of the screen take care as to not damage anything.
Aug 12, 2009 | HP Pavilion zd8000 Notebook
Hp pavillion zd8000 monitor has 37 vertical lines
Interesting that you counted them!
If you haven't tried to reinstall the video drivers, do that.
If that doesn't work, hook up an external monitor to see if the display is OK on that.
If it is, then your LCD screen has a problem and will need to be replaced.
Jun 29, 2009 | HP Pavilion zd8000 Notebook
My monitor displays images in stetched full screen format
the description you gave was the long way right click on my computer, select properties then device manager, you will be in the same place but lots faster, plug and play does not identify the monitor or its compatible display resolutions, right click on the desktop select properties then display settings, go into advanced tab and look at the monitor, and the adapter, you can play with the setting until you find one that works, 1400 x 900 may not be supported by the video card(adapter) so that may be why your loosing the video settings.
hope this helps.
Mar 15, 2009 | Acer X193W LCD Monitor
HP Pavillion zd8000
Ok the lines on the moniter means it is a bad screen that must be replaced and battery not working could be a few things it may be a bad battery or bad charging circuit to test this you can try charging another battery in your laptop and if it works it was the battery if not it might be the charging circuit.
Dec 04, 2008 | HP Pavilion zd8000 Notebook
Acer X193W LCD Monitor Logo
128 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
