Question about Kodak EasyShare One Digital Camera
Switch to memory card?
I put my memory card into my camera(a M1033 kodak) and then i switched back to the internal memory because i wanted to see pictures that i had taken that were in the internal memory space. Now i want to get back to the memory card space but i cant figure out how.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 58 Answers
Click on review and press menu (make sure menu is not pressed before review because the menu under review and main menu are different things)
when the review menu comes up, scroll down and look for IMAGE STORAGE, select that and choose AUTO> continue> ok
Posted on Aug 27, 2009
jonags3
  • 83 Answers
SOURCE: memory card
Try to check the Memory card if it is compatible with your new camera. To know this you need to read the owners manual and try to check the directions on putting your memory card. Your memory card must be check also from a computer if it is still functional. If you have files like old pictures try to save to that card. if the save files are opened then your memory card is working. But if is not then your card needs to be reformat. if it cannot be formatted thats the end of its life. You need to have a new one.
Please reply if it works or not. To give you more advices.
Jonags3
Posted on Jan 02, 2009
  • 4 Answers
SOURCE: won't read memory card
i hvae had this happen many times... ok this is what you will need to do. take the memory card out and look at the little brass things and clean them with something thats cotton. repeat this till it reads. i hope this will help.
Posted on Feb 03, 2009
  • 126 Answers
SOURCE: On my Kodak M863 digital
click review press menu go to copy click photo or all that should transfer photos to sd card .
Posted on May 05, 2009
  • 34 Answers
SOURCE: Trying to transfer pics on internal memory to my SD card.
Set the image storage setting of the camera to Internal.
Once it is set to internal, put the card in the camera and press review.
Copy the pictures from the internal memory to the card.
Posted on Jun 22, 2009
  • 11967 Answers
SOURCE: When I turn my Kodak
Move the slide switch on the side of the card to "unlocked"
Posted on Aug 10, 2010
Memory card is protected reset switch on memory card
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 31, 2010 | Kodak EasyShare M1033 Digital Camera
How do i change internal memory to card memory. the camera seems to bestuck on internal memory mode.
Menu, Camera Settings, Internal Memory has to be changed to AUTO.
The camera can only detact the memery card if in the camera otherwise it will automaticly go back to internal memory.
M1033 Memory card support : SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
Pls. rate me good if you find my advice useful
Nov 24, 2009 | Kodak EasyShare M1033 Digital Camera
The sreecn keep saying the memory card it protected
There is a lever on the SD card. Pls. change the position of the lever.
Make sure the SD card is compatible w. the cam. model.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Oct 31, 2009 | Kodak EasyShare M1033 - black Digital...
I continue to get a message saying the internal memory is full. I have a memory card in the camera. Do I have the mode or something set wrong. It will not add pictures to memeory card.
First, format the internal memory with your memory card out of the camera. Then, go into the setup menu and scroll to "reset" and follow the on-screen instructions. Put your memory card back in the camera. It should work after that.
Oct 06, 2009 | Kodak EasyShare M1033 Digital Camera
I have a kodak M1033 camara with a SD HC PNY optima 240 HD 16 GB and the camara says internal memory is full and is only 1/2 minute video in the camara please help
Hi!
Sonds like the camera hasn't switched to the memory card. Go to setup and set memory to Auto not Internal. If that doesn't help, it's possible that the camera doesn't support 16GB card, but it should give you a card error then, so check the memory settings first.
Tom
Switching from internal memory to memory card
Push the MENU button and advance through the options until IMAGE STORAGE comes up. Setting this for AUTO will route all new pics to the memory card, using internal memory only if the card is full.
Aug 23, 2009 | Kodak EasyShare Z612 Digital Camera
We cannot get the camera to use a memory card. When we insert the memory card, it says the internal memory is full. We don't want to use internal memory. We want to use the card.
Look at the cemra settings - you can choose what memory to use - Internal memory or Auto. Choose the Auto and restart the camera. Hope this helps.
Tom
Jul 19, 2009 | Kodak EasyShare M1033 Digital Camera
Kodak M1033 does not recognize memory card
  1. Turn camera on
  2. Push the options/settings button (the button next to the view/playback button)
  3. On the Capture Screen move over to "Setup"
  4. Move down to "Image Storage" and make sure its set to "Auto" {if not select it and set it to Auto}
  5. If already set to Auto, change to Internal Memory.
  6. Power off and power back on then follow steps 1-4 to set back to Auto.
If this still doesn't work, backup pictures from internal memory to computer then delete all pictures on internal memery. Camera should automatically prompt you to change to memory card.
Mar 26, 2009 | Kodak EasyShare M1033 Digital Camera
Internal memory is full
Hi There Kyle,
At the moment I have my friend's Kodak camera M1033 with me, because it has some minor problems. So Your camera model is quite the same as this one.
So coming to your problem, go to the normal Photo mode and press the Menu button.
There if you search then you'll find an option 'Image Storage'. Did u find it yet? Good. Now according to your problem, it must have been at 'Internal Memory', so set it to 'Auto' and you're good to go!
Cheers,
DJ
Feb 16, 2009 | Kodak EasyShare M1033 - black Digital...
Kodak EasyShare One Digital Camera Logo
141 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
