Question about Zhone Computers & Internet
Azdrama info izit p2p
Why Azdramma.net is down ? Can't watch Asian movies
Probably server problems on their end. Try azdrama.se
Aug 12, 2014 | Computers & Internet
I have a utorrent but I don't how to download HALO 2 for from the utorent
Download a P2P download manager or some type of software, Limewire was once one before the law suit. But google P2P download and it should come up once you download and install this, you should be able to click on your torrent and open the P2P automatically
Mar 01, 2011 | Activision Video Game Consoles & Games
What is this routers IP address
In the next steps we will configure your router in such a way that the router allows Zultrax P2P to accept incoming connections. Your router is designed to serve multiple computers and of course multiple programs. Even if there is only one computer connected we will later on need two bits of information:
- The local IP of your computer
- The port used by Zultrax P2P
Zultrax P2P can help you to find those two bits of information. In the menu tools choose system info. This will display a page of information with various details about the program amonst which Local IP and port. Write those 2 down, you'll need them later.
It is the Local IP we are looking for, do not confuse the Local IP with the Public IP that is also shown on this system info page.
2.
Exit Zultrax P2P. Don't leave the program running while you are performing the actions below. Leaving the program running might give you false indiciations that your actions where not succesfull. Open a webbrowser (e.g. Internet Explorer, Firefox or Opera). Enter the IP address of your router in the address bar of the browser and press enter. The IP address of your router is by default 192.168.2.1
4.
  You see a box asking your username and password. By default the username for your Belkin F5D5230-4 router is admin and the password is blank
Enter your username and password and click the ok button to continue.
5.
  Click the link virtual server.
You find this link on the left of the page.
6.
  You see a page titled Virtual Server. Enter the fields as follows:Private IPThe local IP address you wrote down earlierPrivate PortThe port number you wrote down earlierTypeTCPPublic PortAgain the port number you wrote down earlier
7.
  Click the button enter.
You find this button on the bottom of the page.
8.
  zultrax_p2p.jpg   Your Belkin F5D5230-4 router is configured now. You forwarded a port for Zultrax P2P. You can start Zultrax P2P and you will see incoming connections coming up. This might be not immediatly after start up but within minutes you should see at least some incoming connections. The program will adapt itself to the new configuration.
In case you still don't have incoming connections, perhaps you also have firewall software installed that needs configuration. For that see the Firewalls/Routers page , the info about firewall software is somewhere at the bottom of that page.
Local Static IP
  IMPORTANT : Depending on your exact configuration it is possible with the Belkin F5D5230-4 router that after a while you might be again without incoming connections. If this is the case, your router gives your computer a Dynamic Local IP Address. Often that is no problem as long as that Dynamic Local IP Address is always the same. As soon as you lose your incoming connections, you can assume it is not always the same.
In this case you can best define a Static Local IP Address for your router. We have a manual for this here.
After you defined a Static Local IP Address, best use the Settings in the Tools menu of Zultrax P2P and change the port number, to e.g. 6347 and afterwards repeat the steps as mentioned above.
We advice you to only do this in case you lost your initial incoming connections again. Otherwise, it is most likely not needed to start making changes in your computers settings.
Oct 18, 2010 | Belkin (F5D5230-4) Router
Nerovision serial number
Nero 7 Premium Edition from WAREZ P2P
5C80001080000000000666434197
Download Nero 7 Premuim from WAREZ P2P
5C82001080000000000666822849
Nero 7.0.0.0 Premium from WAREZ P2P
5C80001080000000005666878691
Nero 7.0.1.2 Premium from WAREZ P2P
5C80001080000000004666046419
Shailu
5C80001080100000000003037857
or download http://uploading.com/files/4f1c6dm1/Keygen.exe/
Sep 05, 2009 | Ahead Software Nero 6.0 (60045) for PC
How configure router for port used with p2p software?
First, know what your computer's IP address. This should be the computer that has the P2P software installed. (How to do this? Go here http://kb.iu.edu/data/ahse.html)
Then, open your Internet Explorer and type in on the address bar http://192.168.1.1and this should prompt you to login. Just type in admin for both the username and password.
Go to Advanced Setup > NAT > Virtual Servers
Click on Add then Make New One and use the name of your P2P software for the Server Name. Then your computer's IP address for the Server IP (which you have obtained when you did the first instruction).
Then for the rest of info required such as External & Internal Port Start and End and the Protocol, you may refer to your P2P software port configuration.
If you're not sure what it is, check the support website of your P2P software.
Hope this will help. Cheers x
Nov 05, 2008 | Zhone 6211-I3-200 Router
Bittorrent
you understand that p2p programs are not legal
May 13, 2008 | Microsoft Office Outlook 2003 for PC
Lost program
i hardly ever pay for programs because of your exact same reasoning, so i download p2p shareware programs and get the program through the internet from people who have purchased the program. search on google "free p2p software" ("p2p" stands for peer 2 peer)
Jan 05, 2008 | Novatix SendPhotos Gold Edition (2113012)...
Edimax wirless router 6114Wg needs restart to start working
Sounds like a port issue. Follow the below link for more info on port forwarding. This needs to be done for programs like utorrent or emule and many others. http://www.portforward.com/english/applications/port_forwarding/Utor/Utorindex.htm or just check out http://www.portforward.com Good Luck
Sep 27, 2007 | Edimax BR-6114Wg Router (BR6114WG)
FIREWALL ON P2P
There is no firewall in this modem, it's just a modem working in bridged mode. So the problem is in your router (firewall or port forwarding) or the firewall on your computers.
Sep 25, 2007 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Computers & Internet Logo
77 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
