Question about Peachtree Software Sage Peachtree Premium Accounting 2012
Peachtree accounting 2012 activation key
Peachtree accounting 2012 activation code
Peachtree Premium Accounting 2012. Where can I get serial number?
Only Sage can help you with the serial number .should have been in or on the box . or in an email if downloaded
Oct 01, 2015 | Sage Computers & Internet
Tip
How To Run Data Verification In Peachtree Accounting
<p>Data Verification is a Peachtree utility that allows you to verify if any of your data files are missing or possibly damaged. During the verification process, Peachtree makes any needed changes so that your data records are compatible with Peachtree data formats. For example, if an ID in a data record has more than the maximum allowable characters, Peachtree will truncate the ID. Also, any files that Peachtree finds to be corrupt and unusable are deleted during the verification process. <br /> Following verification, Peachtree generates a log that details all errors encountered and reports on any changes made, as well as any corrupt records deleted. Follow these steps to run the test:<br /> <ol> <li>In your company, from the <b>Tasks</b> menu select <b>System</b>, <b>Change Accounting Period</b>.</li> <li>Highlight the first <b>Accounting Period</b> on the list and click <b>OK.</b></li> <li>From the <b>File</b> menu, select <b>Data Verification</b>.</li> <li>Select the <b>Both Tests</b> (recommended) option from the menu and click <b>Start</b>. <br /></li> <li>You will be prompted to make a <b>backup</b> of your Peachtree data. This is a required step. Click <b>Save</b>. The data verification test will begin automatically when the backup is complete.</li> <li>If no errors were found, click <b>Close</b>. If errors were found, you can examine the details of the tests by clicking the <b>View Error Log</b> button.</li> <li>To change back to the current Accounting Period follow steps 1 and 2 above.</li></ol>
on Feb 21, 2011 | Computers & Internet
Peachtree 2006 install windows 8.1
Thanks for your sharing and I'd like to share another experience to upgrade to windows 8. Guys you can try this site: https://www.facebook.com/Windons-7-Key-581343735370307 to get a cheap and genuine win 10 pro key to activate windows 10. It works 100%.
Nov 25, 2013 | Peachtree Software peachtree complete...
Peachtree 2011 corrupts, i cannot locate my data file what to do?
Run a repair on the software and you should be able to then restore companies.
In the meantime, you should be able to restore from a backup file to a new company.
Sep 05, 2013 | Peachtree Software Sage Peachtree Premium...
I am denied access to change the accounting period in peachtree
I've seen this before with peachtree. What happens every time you work on an accounting file peachtree locks the contents of the file. Occasionally the software never gets the chance to unlock it. This can happen if the computer shuts down unexpectedly, a file gets corrupted etc. You should find in your installation depending on the version a scan utility that can scan your accounting main file and see if there are problems and correct them. If not next try a re-install of peachtree and run the updates and try opening the file. Finally if not it is time to restore an update you have prior to the problem.
Sep 04, 2009 | Peachtree Software Peachtree Complete...
I have peachtree and cannot change acctg period
I HAVE PEACHTREE. SOMEHOW OVER THE WEEKEND OR AT SOME POINT OUR ACCOUNTING PERIODS HAVE GOT OFF TRACK.
I NEED TO CHANGE OR EDIT THESE TO MAKE OUR DATES RIGHT.
CAN YOU PLEASE TELL ME HOW TO CHANGE. WE ONLY HAVE
1 YEAR OPEN WHICH IS 2010.
Apr 06, 2009 | Peachtree Software Peachtree Complete...
Federal Income tax
No it has not been corrected. After yesterday's experience with the sales tax not working it finally came out that apparenty Peachtree had installed a bug that would cause the system to fail after a certain age. Your techs from your premium side that attempted to fix it before that notice failed miserably. I know there is a code somewhere inside it that cause the problem but they apparently cannot find it. I believe it is an attempt by Peachtree to force the customer to upgrade which I do not want to do.
Feb 27, 2009 | Peachtree Software Peachtree Complete...
Problem using Peachtree2004 on window vista..
Looks like you are using illegal program or... someone has somehow stolen your software key before you noticed. If you are not using this software on your another computer, try to contact software creators http://www.peachtree.com/company/contactus/
and explain the situation
Jan 23, 2009 | Peachtree Software Peachtree Complete...
Peachtree Software Sage Peachtree Premium Accounting 2012 Logo
175 people viewed this question
Top Peachtree Software Computers & Internet Experts
Are you a Peachtree Software Computer and Internet Expert? Answer questions, earn points and help others
