Question about Kenmore 24 in. Elite Built-In Dishwasher w/ Ultra Wash Filtration
Kenmore elite dishwasher fills with water, but no circulation of water. Spray arms do not move at all. Drains well.
Spray arms do not move,dishes do not get wet. Technician came in and said motor is bad. Ordered motor and went away. Second technician came in and said there is a loose connection to motor and fixed something without replacing motor. Worked fine for a couple of days and the problem returned. Where can I find a circuit diagram or how can I know which wire is loose ?
  • Ash sash
    Ash sash Mar 21, 2014
    Last time the technician said he fixed a loose connection it did work. But only for a coupel of days. Then the same problem came back. The filter is clean and there is nothing in there. Clearly the wash motor is not going.
  • 1891 Answers
SOURCE: kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Posted on Nov 22, 2009
  • 641 Answers
SOURCE: wash cycle
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
Posted on Jul 02, 2006
SOURCE: "Sensing" Light
There is a relay on the soap dispenser, if it is a Kenmore quietguard 4, I had the same type of noise, the repairman replaced the dispenser, which to me made no sense, because the relay is activated from the control board. After the $130. for the soap dispenser, he ended up replacing the control board for another $160. Now the dishwasher only goes up to the dry cycle and stops. If you press the heated dry button and then the heated wash button 5 times each, the entire control face will light up and it will do some kind of reset and try a new cycle. I have tried the button pushing and it worked great till it got to the dry cycle, so I am looking for another solution without involving Sears. Good Luck!
Posted on Jan 17, 2008
  • 530 Answers
SOURCE: Kenmore (Whirlpool) 655 1589910 Dishwasher.
you need to clean/ check the chopper. sounds like you have a bad motor. about 2-300 dollars for the part
Posted on Dec 23, 2009
erpaalai
  • 999 Answers
SOURCE: my kenmore dishwasher model 587.1414 does not
Check spray arm for obstructions and if it is clear the motor impeller could be slipping or water system may need a good cleaning with CLR.
Eric
Posted on Jan 14, 2010
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
My Kenmore Ultra Wash II fills with water but doesn't spray.
i would suspect water mains problem, not enough water getting to the machine sometimes inlet get clogged with lime.adrian,,,,
Jul 13, 2010 | Kenmore 17024 Built-in Dishwasher
Kenmore elite dishwaher 1646 not cleaning dishes.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
jklfryyr
Jul 06, 2010 | Kenmore 24 in. 16462 / 16464 / 16469...
Kenmore elite dishwasher, does not get the dishes wet
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher fills with water but does nothing else.
If your dishwasher drains and fills as it should and cycles normally, there is a problem with the spray arm assembly or recirculation pump. Esure that the spray arm is not clogged. Manually free up moving parts if the assembly can be removed.
Jun 25, 2009 | Kenmore Dishwashers
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite dishwasher 665 purchased in 2001
Sometime objects tend to build up under the screen and around the circulating pump. These objects will block the water ports and cut the ability of the spray arms to rotate. If you are carefull you can disassemble the unit under the bottom spray arm and inspect/clean the screen and circulating pump.
Jan 10, 2008 | Kenmore 16872 Built-in Dishwasher
Wash cycle
Jul 01, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24 in. Elite Built-In Dishwasher w/ Ultra Wash Filtration Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
