Question about Home
The code CAL comes up on my Braun ThermoScan.
BraunType6022
SOURCE: Can't get the battery cover
I just figured it out.
Holding the device so that the ear piece part is pointing towards you, locate a little raised arrow on the top of the device, just below the battery cover.
The arrow points to a little hole, which you need to push something sharp like a pen point into. This should release the cover, which you can now slide off.
Mine did not release so easily, so I also used a flathead screwdriver (a pretty small one, only about a 1/3 inch wide) to drive in between the body and the battery cover, twisting it off as I pushed a pen into the little hole.
Should work fine. Now you just need to get those weird lithium batteries it uses!
Good luck.
Posted on Nov 05, 2008
EwingElect
  • 276 Answers
SOURCE: have a braun thermoscan and want to change it from...
From the manual of the thermometer:
This thermometer is shipped with the Fahrenheit temperature scale activated. If you wish to switch to Celsius (°C), proceed as follows:
• Turn on the thermometer. (If it is already turned on, make sure it is not in memory mode.)
• Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
• By pressing the activation button again, the Celsius scale is activated, «°C» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
If this isn't the right manual, go to: http://braun.kaz.com/kaz/service and select your country from there.
Posted on May 19, 2010
SOURCE: how to change batteries in
push down the small button directly above the battery door with a pen or something slender, while pushing the battery door downward, away from the thermometer. the 6012 model uses two CR2032 button cells.
Posted on Nov 08, 2010
SOURCE: I have a Braun thermoscan type 6022, but code po5
It's not po5, its pos... you're not positioning it properly in the ear canal.
Posted on Feb 21, 2011
  • 10 Answers
SOURCE: Can you change the temp
Turn off the thermometer
Press and Hold the L/O Button
Continue to hold the start button when the F or C display appears. Watch for these displays to cycle over the display window.
Release the start button when the F display appears on the screen.
5
Listen for a beep and watch for the Braun ThermoScan ear thermometer to shut itself off, indicating that you changed the temperature scale to Fahrenheit successfully.
6
Follow the same procedure but release the start button when C shows on the display to switch from Fahrenheit to Celsius.
Posted on Feb 28, 2011
What is the flashing horn signal on braun thermoscan
It looks like a horn it is actually a picture of the thin plastic cover that goes over the end before you put it inside the ear. Put the cover on and it will work.
Sep 25, 2012 | Braun IRT3020 Thermoscan Ear Thermometer
4 year old braun thermoscan IRT4520 having some problems
is the drawer that its stored in, in the bathroom? the humidity or moisture could affect it. I have had mine for 8 yrs and works perfectly. Are you placing the probe covers on correctly and waiting for it to click or a pop before inserting into ur ear.?
Jul 03, 2012 | Braun IRT3020 Thermoscan Ear Thermometer
Have a braun thermoscan and it keeps saying lo???
I have the same LO error msg. too... and it continues even though i followed the manual instructions.
Nov 11, 2011 | Braun Health & Beauty
Can you change the temp reading from F to Celcius on a Braun Thermoscan 6014?
5
6
Feb 28, 2011 | Braun Health & Beauty
I have a Braun thermoscan type 6022, but code po5 always comes up. What does that mean?
Jan 26, 2011 | Braun Health & Beauty
I have a Thermoscan HM1 and am getting error code 2. I need to know what it is and how to fix it. Thanks.
2 says patient temperature out of range. the error codes are in the case. Usually where the probe covers are stored. take them out to look at the codes.
Jan 15, 2011 | Braun Thermoscan Thermometer Probe Covers
Home Logo
50 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
