Question about Sony VAIO Y Series Notebook VPCY118GXBI
Have to hold function key down to type normally
How do I turn this oss so my k/b operates normally
  • Philip Watson
    Philip Watson Mar 19, 2014
    thanks done a google and found that out but thanks for the prompt reply :)
    Top Expert:
  • Sony Master
  • 25,696 Answers
Hold down Alt and tap Fn key.
Posted on Mar 19, 2014
How to reset windows on is 350 lexus 2007
(a) Turn the engine switch on (IG).
(b) Halfway open the power window by pressing the power window switch.
(c) Fully pull up the switch until the power window is fully closed and continue to hold the switch for approx. 1 second after the power window is fully closed.
(d) Check that the AUTO UP/DOWN function operates normally.
If the AUTO UP/DOWN function operates normally, reset operations have been completed at this time. If not normal, follow the steps below.
(1) Disconnect the negative battery terminal for 10 seconds.
(2) Connect the battery terminal.
(3) Turn the engine switch on (IG).
(4) Halfway open the power window by pressing the power window switch.
(5) If the AUTO UP/DOWN function operates normally, reset operations have been completed at this time.
(6) Turn the engine switch on (IG).
(7) Halfway open the power window by pressing the power window switch.
(8) Fully pull up the switch until the power window is fully closed and continue to hold the switch for approx. 12 seconds after the power window is fully closed.
(9) Check that the AUTO UP/DOWN function operates normally.
Feb 05, 2017 | 2007 Lexus IS 350
Como programar el control remoto universal janesong JS-6212A
0233 0237 0436 0673. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
May 02, 2014 | RCA Universal Remote Control
Jumbled keyboard numbers
Are you typing on your laptop and notice the text has become illegible? What should be letters, have become numbers or symbols. This odd behavior can probably be explained be peering a little closer at your keyboard. Those little numbers on the keys. These numbers and symbols normally become active when you hold down the function key, usually labeled as the "FN" key. The "FN" key is similar to the Shift key, activating a second function assigned to a key. It can become active seemingly on it's own because a key is locked in the on position.
Before performing numerous key combinations, try the simple thing of lightly tapping the "FN" or "Num Lock" 5 to 6 times. There may be a small particle of something logged under the key that you can loosen, move, or crush down. Do not bang the keys, just press normally. Next focus on the "Numlock" key which usually located with the "Print Screen" and "Pause" key on the top right of your keyboard. Press the "Numlock" key, then press a scrambled key to see if it's normal. Older model laptops may require you hold down at the same time, the "Ctrl-Shift-Numlock" keys. Newer models may require holding down the "Shift" key and pressing the "Numlock" key. Turn off the Function key with the following combinations. Hold down the "FN" key and hit the "Numlock", Hold down the "FN" key and hit the "Scroll" key and Hold down at the same time "Fn+F12+Num Lock"
Feb 08, 2013 | Lenovo Computers & Internet
Keyboard numbers are jumbled
Need to find list/definitions of "function Keys"
Please open this LINK, scroll down to page no. 2-5 i.e. the section with "To use the Function Hot Keys Fn". There you'll find the details about the functional function keys of your compaq. It seems your function key i.e. Fn key is activated, to deactivate, press and hold down the Fn key while you tap the Numlock key once.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 26, 2011 | Compaq Computers & Internet
My function is stuck on, i cannot type on my keyboard unless i hold the function key down the whole time i am typing. is there such a fn key release function.
Normally, if you hold down the "Fn" key, you'll get whatever character or function is printed in blue on those keys. So holding down the "Fn" key, you now have a numeric keypad in the middle of your keyboard. Release "Fn" and things are back to normal.
Which is exactly the opposite of what the question is asking. The person asking needed to press the "Fn" keys to get the normal, white, characters for each key.
The "problem" is simply that there is a persistent toggle. If you press "Num Lk" (I've also seen it labeled "Pad Lk" for numeric Pad) it turns on the blue keys, and inverts the meaning of the "Fn" key - it's a way to use that embedded numeric keypad without having to hold down the "Fn" key the entire time.
numlk.jpg To fix it, just find and press the "Num Lk" or "Pad Lk" key again. (Note, sometimes these keys are themselves "Fn" keys, so you may, or may not, need to also hold down the "Fn" key to get the right function.) Often there is an indicator light associated with the setting.
Jan 14, 2011 | Computers & Internet
NC10: Can't type without holding function key down
I set up my girlfriends this morning, to turn off Num Lock, you need to have the machine on and select Fn + F11.
That'll turn it off and you'll have the bliss of typing normally again!!
Jan 06, 2009 | Samsung NC10-14GW Notebook
Sleep function holds for only a few seconds then reverts to normal
Are you using an optical mouse? If so, try turning it upside down before entering sleep mode. On some surfaces (with some mice only), the mouse picks up movement even if perfectly still.
Oct 23, 2008 | Computers & Internet
Sony VAIO Y Series Notebook VPCY118GXBI Logo
43 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
