Question about Sony PS-LX250H Turntable
Needle skips across record
Needle is skipping across record
  • 141 Answers
Your tone arm needs rebalancing most likely
Posted on May 09, 2014
3 Suggested Answers
SOURCE: My Sony PS-LX520 turntable skips with tone arm not moving
Yep - Just did the repair and it was as stated above. Had exactly the same problem you have and changing this tiny drive belt was the fix. I add more details and another source to find this belt:
I had the same problem and a review of forums and my experience with my own fix indicated that this is almost certainly your problem:
The roughly 2.6 inch (circumerence) drive belt (that connects a tiny motor to the worm screw that moves the tone-arm laterally when it gets the signal) likely needs replacement. Mine was intact but old and rigid enough to keep slipping or hang up the tiny motor. Unplug the unit - take out the 8-10 screws to take off the bottom - remove this little belt - scrub the pulleys with tripled-up sewing thread, and replace with new belt. This is a good source:
http://www.turntableneedles.com/Square-Belt-Small-26-Inch_p_227.html
$6.50 (paypal available) for 2 belts to reach their minimum, free shipping, arrived in 2 days.
You might also want to clean and lightly grease the rail that the tone arm rides on, but this is unlikely to fix the problem without a replacement belt.
Posted on Jan 08, 2011
Grubhead
  • 5126 Answers
SOURCE: needle skips along records.
3 causes
1. Bad stylus.
2. Not enough weight - adjust weight on end of arm, or turn knob with numbers up slowly bit by bit, trying a record each time till it stops but doesn't "rumble".
3. Adjust anti-skate control if it's got one. Again bit by bit, testing with record.
Posted on Aug 29, 2011
Marantz tt 530 turntable
The needle skipping is caused by (A) a worn stylus. (B) not enough pressure. Which is solved by adjusting the weight on the end of the arm. It can only really be solved by trial and error. You increase the weight slightly, then play the record. You keep doing this till the record stays in the grooves but doesn't make a rumble sound. If it starts to rumble reduce the weight.
Aug 20, 2013 | Audio Players & Recorders
Needle skipping towards end of record
If you lower the tonearm to the record surface, and it just slides towards the center, chances are the stylus(needle) is either broken or covered with dust. Clean and inspect. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 28, 2012 | Stanton STR8-100 Turntable
Hello i have a pioneer pl-300 turntable. i bought it used and it's been working fine until today. now the needle skips ahead on the record. i am VERY inept with technical knowledge of turntables i just...
if its skipping ahead Almost like the needle is just gliding across the Record. It means your needle is bent, dirty or broken, Take it off and look at it closely.
May 30, 2011 | Pioneer Audio Players & Recorders
I have purchased two ARK IV white elliptical Stylus replacement needles for my turntable and I am not getting the life out of these items, despite very limited play time. Seems like they just wear down...
What's the turntable? Skipping across the record would be a (mal)function of tracking and anti-skating. The recommended tracking force for this stylus os 3.0 grams. I've been out of the vinyl groove for some years now but I remember my Shure M95 tracking in the range of 1-1.5 g. Railroad spikes track at 3.0. Is this for 'scratching' or whatever it is they call that noise?
Apr 27, 2011 | Audio Players & Recorders
The needle skips across every record I have , What could be the problem?
You need a new one, or the counterbalance weight (on the arm) is set wrong for the cartridge installed.
Jun 02, 2010 | Memorex Audio Players & Recorders
The stylus skips across the record, despite readjusting the tracking force and the anti-skate control. After repeated adjustments for too little and too much weight, nothing helps. Does the stylus need...
If your needle skips across the record, then there is only 1 thing wrong with it... it's broken, and needs to be replaced.
If after you've replaced the stylus, and problem persists, then you have something a little more serious... Tonearm damage. More than likely not, but just in case replace the stylus does not help.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Repair : Technics Turntable Parts
Aug 25, 2009 | Audio Players & Recorders
Needle skipping & not pushing down
There should be an "anti-skate" adjustment to control the arm moving across the record. It is possible that lubrication has stiffened up as well. This unit may need a general overhaul/cleaning.
Dan
Jul 20, 2009 | Technics SL-1210MK5 Turntable
Turntable swingarm skips to last song
Most likely your stylus (needle) is bent, broken or missing. Check to see if it's there or not. If it's broken or damaged, you will need to replace it. Under the cartridge, you should see a small arm that has the actual diamond on the end of it. If the arm is there, but the diamond is missing off the end, the arm won't stay in the groove and will instead skip across the record to the middle.
Mar 01, 2009 | Sony PS-LX250H Turntable
Sl-dd33 turntable
If your needle just started to skip across the LP, then that means your stylus is damaged/worn and needs to be replaced. It's very hard to see the diamond tip on the stylus, and it might not even be there at all. So checking it might not yield any results. This is what happens when the needle is worn. It will skip across the record.
- OPTiC
Turntable Technician
www.1200s.com
Aug 27, 2008 | Audio Players & Recorders
Fisher price 1978 record player
The Fisher Price record player has a device that prevented kids from pressing the needle down and sctratching the record. If you look at the cartridge where the needle is inserted, you will see that it floats up and down. The problem is that this keeps the needle from having enough pressure to play the record. Pennies just make the cartridge recede further into the arm. If you wedge something above the cartridge, the needle won't float and the it will play your records. I've had four of these and none of them worked until I figured this out.
Aug 02, 2008 | Audio Players & Recorders
Sony PS-LX250H Turntable Logo
188 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
