Question about Proview PA-32JK1A 32 in. LCD Television
Provide tv audio out
Audio out
Hello Am looking for the audio output on a changhong 42inch tv model number is chp4263a so I can plug it into my receiver. Jase
If no audio outputs are on the front (even hidden under a cover) or on the rear, your TV may not provide them.
Apr 13, 2018 | The Audio Players & Recorders
Hookup Audio to new Samsung 52"1080 TV LN52A650
The best way is to check the user manual. If you dont have i can provide one.
Sep 02, 2008 | Onkyo TX-DS575 Receiver
No volume/sound...just set up TV...
If you are using a generic HDMI or a DVI cable, you will have to provide a optical audio or composite audio cable as well. Only high end HDMI cables transmit video and audio.
Aug 27, 2011 | Sanyo CE42LM4N-NA 42 in. LCD TV
I would like to hook up my philips hts3544 to my hdtv. i have a satelite receiver in between . i cant always get the hts to provide volume for my tv . can you advise me how to
Manuals answer most of those types of questions.
SAT IN BETWEEN THEM? WHY?? HOW? Treat the SAT as an A/V audio source.
Provide "volume" for the TV?? What's that mean? No sound or no control of it?
Most TV's have multiple Video inputs. The SAT should go STRAIGHT to it. The digital audio, if available on a coaxial digital output, SHOULD be run to the HTS's coax digital input.
The TV speakers will never be under control of the HTS. TheTV volume would handle that end. What's the point? Are the TV speakers BETTER?
The HDMI cable CAN carry the audio to it. As the manual says,
"Make sure that the audio output setting is not turned off. See 'Setup Menu Options - { Audio Setup Page -
HDMI Audio }' for details."
Go to http://www.p4c.philips.com/files/h/ and drill down to the HTS3544/37 directory for the manual. The alpha directories are slow loading. Be patient.
Jun 09, 2011 | Philips HTS3544/37 Theater System
How to connect samsung hdt550 dvd home entertainment system to cable tv? so the audio outcome would work when watching regular tv as well
The quick and easy way is to take a set of RF cables(the red and white audio cables), from the back of the tv (connected to audio output 1).
You will want to connect these on the other end to your audio reciever(connected to audio input 1).
This way any sound which is produced by the tv will be reproduced at the reciever if you have selected audio input 1 as the source on your audio recievers remote control.
If you are connected this way you will just want to feed all video and audio signals directly into the tv and it will do the rest.
If you provide more details such as the model numbers of every component you are trying to make work together I could provide a much more detailed response.
Good luck, cheers.
Apr 14, 2011 | Samsung Televison & Video
Surround sound only plays via cd/dvd will not play through normal tv audio. can u help me fix this
Only a digital source can provide true surround. If you're running the audio FROM the TV TO the receiver it is probably analog stereo only.
Why not get your TV-rekated audio from the same source you're watching - like the cable/sat box?
Jun 13, 2010 | Sony HOME THEATER SYSTEM System
Digital audio cable does nothing?
You need to look at the two sources that don't work for why they're not providing surround.
HINT: It is the rare TV that can provide surround. Video is a TV's strong suit, not Audio. TV's are usually at the end of the audio chain, not the beginning.
TV-related audio always come from somewhere else than the TV, so get it from the source, not the TV.
May 03, 2010 | Samsung HT-TQ85 System
Problem getting home theatre sytem to play audio when watching tv
you need the red and white audio cable hooked into the AUDIO OUT connectors on the tv and the other end of the red and white cables into the AUDIO IN in tv to the media center (main Bose unit).....If your tv does not provide AUDIO OUT connectors, you cannot connect the tv audio to the 3-2-1 system. Continue using your tv speakers for sound.
Dec 26, 2008 | Samsung 1000W 5.1-Ch. Home Theater System...
Proview PA-32JK1A 32 in. LCD Television Logo
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Tony
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
