Question about Garmin Gps 152 Waas With Internal Antenna
Garmin does garmin have internal fuses
  • 285 Answers
No, the fuse should be inline on the positive power lead. If one is not supplied, you should add your own to the positive (red) wire.
Posted on Jun 15, 2009
To replace the fuse in my garmin 650 car charger, when reassembling which goes in first the spring or the fuse ? The cap came off and the spring and fuse fell out and I am not sure how to reassemble it.
As long as it works correctly when assembled it doesn't matter, the spring is part of the circuit and as long a the fuse and spring have contact with the tip and internal connection the circuit will function properly without any risk of damage to the device. Most times the spring goes in first though.
Mar 13, 2011 | Garmin nuvi 650 GPS Receiver
Garmin 350 is there an internal fuse, I connected it to a 12 volt battery, but I think I crossed the wires, now it won't power on. Thanks
The Nuvi does not run off of +12V!!! It runs off of +5VDC. There is no internal fuse. I'm afraid you have fried your Nuvi,
- Jim
Jan 14, 2011 | Garmin Nuvi 350 Car GPS Receiver
Car charger not charging internal battery ..gtm 20 cord ...nuvi 755
There is a fuse in the car charger adapter silver tip.... Unscrew it CAEFULLY its spring loaded and check fuse
Nov 06, 2010 | Garmin nuvi 755T Car GPS Receiver
Will not turn on
It is possible that the internal battery has discharged, and is unable to recharge due to a blown fuse inside the cigar lighter plug or a blown fuse in the car's fuse block for the cigar lighter outlet.
  1. Unscrew and remove the silver or black, round end piece.
  2. fileservlet?date=1&kb=%7b6b85cfa0-194d-11dc-44cd-000000000000%7d&id=%7b6e53bea0-6874-11dd-436f-000000000000%7d&ext=jpg
  3. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  4. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
fileservlet?date=1&kb=%7b6b85cfa0-194d-11dc-44cd-000000000000%7d&id=%7b6e476290-6874-11dd-436f-000000000000%7d&ext=jpg
Consult your car's owner's manual for locating the fuse block in the car. Both fuses must be good.
If you're unable to power up the c500 outside of the car (running on internal battery) your c550's internal battery may no longer be able to accept a charge. This will require a battery replacement - or use with a cigar adapter only. You may have to return the GPS to Garmin for a battery replacement - but there are some third party battery providers for some Garmin GPS units. If one is available for the c550, you may save enough money to make going the third party route worthwhile.
Please rate this replay if helpful - good luck!
You can download / view a copy of your c550 manual here.
Aug 09, 2010 | Garmin StreetPilot c550 GPS Receiver
I keep blowing fuses in the car charger for my Garmin Nuvi 660
What happens when you replace the fuse, plug in the charger without plugging the charger into the 660? Does it blow then? If not, the 660 is damaged internally and causing the fuse to blow. If it still blows, then there is a problem in the charger.
http://www.sharc.net/gps_charger_repair.htm
- Jim
Nov 17, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin went totlly blank during use.is there a
most Garmin's are powered by external sources which charge the device. the device has a battery internally and is kept charged by such a cable connected to the cigarette lighter socket.
If its a built in Garman then most likely its the fuse.
AndystUK
Aug 30, 2009 | Garmin nuvi 350 GPS Receiver
Turn garmin on it flashes the garmin logo then shuts down
hELLO THERE:
First off i would check the power cord to see if the fuse is bad and check the fuse in the car too
if all good than press and hold in the reset button for 2 minutes to let it fully reset it'self. and if this still does not work i would have the unit inspected by a authorized shop to see if the internal fuse has went out ok? i hope that these solutions have helped you out.
please dont forget to rate these solutions that i have provided cause it helps me so i can continue to help you too>
best regrds
MICHAEL
(UNITED STATES NAVY RETIRED)
Aug 22, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin C340 will not take a charge.
The internal battery needs replacement. You can change it yourself if you are comfortable with soldering, and are mechanically inclined.
Search the internet for:
"Replace battery Garmin c330" You'll need a small Philips head screwdriver to open the case, and to remove the battery holder. It is tricky to put the antenna back, so be careful.
Jul 20, 2009 | Garmin StreetPilot C330 GPS Receiver
Internal battery won't charge
Common issue. Steps to troubleshoot/solve:
1. Pull off face, press reset tab.
2. If unit wont turn on or if turns off immediately, connect to home computer using mini usb on side of gps (any usb cord that fits will do). This will charge the internal gps battery, which is discharged.
3. You will not be able to see the gps charge indicator while the usb cord is plugged into the unit. To check charge level, disconnect it, turn it on, and note the large "battery" icon.
4 Do you have a dead internal battery? If the gps holds a charge from your computer usb port, you don't.
5. If you have a dead battery, Google DIY replacement. With some soldering it can done for $15 total.
6. If you don't have a dead battery, the issue is charging from the cigarette lighter socket. Your car socket may have blown a fuse (check car manual). Your charger unit may have blown a fuse (unscrew the tip, check fuse inside). Also, some car sockets don't work when the ignition is off. Test yours.
7. There is a good chance the connection of the charger wire to the gps cradle is the problem. Fiddle with that. Replacement cradles are available for the c340 at about $25.
8. If your unit is not charging from the cradle/socket, buy a 12v usb cord. Plug into socket and into usb port of the gps. This is a workaround or alternative to buying a new cradle.
9. IMPORTANT: observe the "battery" icon while driving, esp. if you have doubts about charging. Basically, if you can see the icon, you're not connected to an outside (car or computer) power source. That is, if you can see the battery-charge indication, it means your battery is currently discharging and unless you get another power source to work it will be dead in a few hours.
Aug 27, 2007 | Garmin StreetPilot c340 GPS Receiver
C340
I had the same problem recently... What I did was open the front casing and hit the reset button under the cover, then it turned on while plugged into the car adapter.
Dec 29, 2006 | Garmin StreetPilot c340 GPS Receiver
Garmin Gps 152 Waas With Internal Antenna Logo
123 people viewed this question
Top Garmin Boating Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Ian Summerfield
Ian Summerfield
Are you a Garmin Boating Expert? Answer questions, earn points and help others
