I have an lg tromm with an ie code replaced water pump and main board and the ie error still there cleaned inlet filters also help
  • 356 Answers
I have had problems similar to this with my Tromm, and I was able to get it to cooperate by unplugging it for a short period (30 minutes) of time and trying again. This cleared the error code and the washer worked for a long time before having to redo this procedure.
Posted on Mar 19, 2014
4 Suggested Answers
  • 3 Answers
SOURCE: My LG TROMM (WM1812CW) does
This code means that something is blocking either the water drain pipe, pump filter or the pump itself. I had the same problem and removing the filter (as recommended by LG) did not help. It turned out I had a piece of debris stuck in the pump propeller itself and consequently the water would not drain and the wash would not finish, prompting the error. This is what I did to fix the problem.
1. I removed the cover on the left bottom corner and the removed the filter and unhooked the little rubber tube (drain).
2. I removed the pump cover (lower left corner of the washing machine) and unscrewed 3 screws holding the pump from the front.
3. I disconnected the power supply and removed the back panel (attached with 4 screws)
4. Disconnected the two hoses (one black, one gray) from the pump.
5. Disconnected the power supply to the pump (I had to cut a plastic tie holding the connector in place in order to bring the connector closer so I can disconnect it).
6. Removed the pump by pressing a little tab that was holding it from the back.
7. Once I removed the pump from the washing machine, I took three screws out of the pump motor, gaining access to the propeller. This is where I found a little piece of plastic. Apparently propeller couldn't spin because of that obstruction.
8. I put the pump back together and attached the hoses. This is easier to do when you have the pump closer to the back opening of the washing machine.
9. I then connected the pump power supply connector, locked the pump back in its place and replaced the screws.
The total repair took less than 45 minutes. The hardest part was to remove and replace the drain tube springs, because I did not have the right pliers (You need decent size pliers or plenty of strength in your hands to squeeze the metal bands).
The tools you need for this repair are:
a philips and flat screwdrivers, large pliers and a sharp knife (to cut a plastic tie)
Posted on Mar 10, 2009
skimbot
  • 5 Answers
SOURCE: TROMM WASHER WM2277HW LG. GET IE ERROR AT BEGINNING OF WASH CYCLE
That noise means it is blocked. Did you get the filters in the back of the machine at the inlets? I've been through heck with this.... check out what finally worked.
IE= Inlet Error. I have struggled with this problem. After much trial and error it appears that it is due to my well water. People who have city water will probably not have this problem with this machine. Well water or hard water buyers beware. This machine is VERY much a primadonna princess capable of stopping your rinse cycle at the slightest imperfections. This is the Princess and the Pea of Washers... but I have a series of possible solutions that will have you appreciating her primadonna superiority once again.
Troubleshooting... Listen.... Does she sound like she is struggling and no water is coming in? If so then it isn't. The cycles will last forever as she makes all sorts of grunting noises. Something is preventing the water from coming in. It could also be that the pressure in to the washer is under 55 psi.
a. I have adjusted the pressure in the pumphouse to allow for minor fluctuations so that the machine will have at least 55 psi.
b. Take off the hot and cold inlet hose and clean the screen at the back of the washer. The two screens are supposed to come out of the male receptacles. They are fragile... beware. I use a squirt bottle/atomizer to clean these screens as mine chipped and will not budge.
c. You can add a screen just off the faucets so that you don't have to move the machine each and every time you get an IE error. This helps but does not solve.
d. I installed a faucet filter that I bought from Home Depot in the PVC sprinkler's section. They are made of a black plastic material and can easily cross thread, so be careful. They look about the size of a one liter container and unscrew midway to reveal a removable cylindrical mesh filter. This makes it possible to widen the surface area where tiny particles can be trapped without totally blocking flow to the inlet sensor. :-) When installing this make sure to completely rinse the hoses, and all screens coming into the machine. I took the shortcut first and thought my idea had failed only to discover that the screen behind the washer was partially blocked.
e. Periodically remove the filter and clean. Depending on the quality of your water, you may need to do this at all the points that have a screen.
I now have a screen washer between the sprinkler system filter and hose and the one that comes installed inside the male ends of the inlets for the water hoses. This has helped enormously.
f. Another possible offender is the soap and softener dispenser. To remove and clean press down on the plastic toggle piece on the soap side, the whole drawer should slide off and clean. Non-HE detergents and softeners can create a buildup of gooey gunk. Just clean it. Inside the drawer space you can clean to increase flow. I use baby wipes.
g. Make sure that the filter on the bottom is free from obstructions. If there is water in the drum, you will be flooded if you remove. This is a last resort after all the inlet lines have been cleaned and cleared.
Note: It doesn't take much to lower the flow of water to the point that this machine will not run. Since you cannot override the computer on it to run a spin cycle or even advance to remove water it can be highly frustrating. I've learned to obey my machine and just clear every last possible inlet.
Best of luck.
Posted on May 30, 2010
SOURCE: own LG Tromm Wm2277hs
may be the sensor? I have the same model and I changed the sensor now it fills.
Posted on Jun 14, 2010
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
What does error code ie indicate?
IE error mostly means not filling completely with water or very slow fill
Jan 31, 2016 | LG WM2688HWM TROMM SteamWasher
ERROR CODE 1e
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters.
TIP Make sure the water taps are fully open.
Make sure the hoses are not kinked or pinched. (Use caution when moving the washer.)
Clean the inlet filters.
Check another faucet in the house to make sure your household water pressure is adequate
You may try the following link, too http://www.lg.com/us/support/answers/front-control-top-load-washers2013/control-panel
Sep 19, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm washer what does IE stand for?wash machine stops running and IE appears
LG's 'IE' stands for (water) 'Inlet Error'.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 04, 2011 | LG WM2688HWM TROMM SteamWasher
What does the IE error code mean? The washer wont drain.
The IE fault code indicates that your washer is not filling properly with water This error code is displayed if the washer is not fully drained within 10 minutes. I will give you troubleshooting tips for both the fill problem and the drain problem.
To troubleshoot a drain problem, follow these steps:
  • Follow the steps on page 17 of your owner's manual to clean the drain pump filter. If you do not have your owner's manual, you can access it on our Manage My Home website.
  • Check your drain hose for kinks or clogs.
  • Make sure that the drain hose is properly installed according to the installation instructions for your washer.
Here are some troubleshooting steps for the filling problem:
  • Make sure that the water valves behind your washer are fully open.
  • Check the filter screens on the inlet valves where your fill hoses connect to the back of the washer. If debris is clogging the screens, remove the screens and thoroughly clean them. Flush the inlet openings thoroughly with water to prevent debris from entering the washer and corrupting the inlet water valves.
  • A drain installation problem can cause siphoning of washer fill water. Make sure that the drain hose is properly installed per the installation guidelines for your washer.
Jan 13, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Not completing cycle error IE
IE is a water supply error. turn water off to machine and unscrew your 2 water hoses on back of machine and clean inlet screens with old toothbrush. if they are clean, you probably have a stuck closed water solenoid.
Jul 25, 2010 | LG WM2277H Front Load Washer
Lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Jul 17, 2009 | LG WM-2277HW Front Load Washer
Lg washing machine error code is ie
IE = inlet error. Washer has not detected enough water after 8 minute fill time. Check screen at inlet water valves where hoses connect to machine for blockage. Look for kinked hose(s). Make sure there is water supply reaching machine. If all OK, most likely next thing is the water valve itself.
Sep 02, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
IE Error - stressed motor
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Jul 27, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
