Access pump filter on whirlpool WFW95HEXW2, no lower access panel
Wife washed her wedding and engagement ring (don't ask). E ring was in the door seal,W-ring gone. Think it's in the pump filter. What is best way to access it? Older models have a lower access panel. Ours a 2013 has a solid panel top to bottom...
    Top Expert:
  • Washing Mach... Master
  • 42,979 Answers
You have to wonder why Whirlpool would do away with the convenient front access panel but my guess is that a redesign
made the pump inacessible from the front so you are left with going in through the rear or underneath (!).
Posted on Mar 19, 2014
MNfisherman
  • 11896 Answers
SOURCE: Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
Posted on Jul 09, 2009
aborcass
  • 2651 Answers
SOURCE: Whirlpool Ultimate Care Washing Machine Agitator
after removing the agitator from the machine (7/16 bolt) i place the agitator on the floor, step on either side of it and pull up on the top half, ittl come loose, needs a little help! a word of advice though is after replacing the agitator dogs, turn the entire agitator upside down and insert the bolt through the entire agitator assy and keep constatn pressure on the bolt as you turn it boack over and try to realign with thte tranny shat. ( you see the parts wanna seperate as you try to reinstall them otherwise)
Posted on Oct 27, 2008
  • 130 Answers
SOURCE: Bosch Nexxt DLX washer-can't open round panel in lower front
Its easy to do, and no you dont need to be a tech. I use a small screww driver w/ the tip in the hole push it left or right until it comes loose. then just un screw the pump cover. be careful the edges are razor sharp.
Posted on Jan 24, 2009
aasc
  • 1606 Answers
SOURCE: water leaking during wash cycle. How do you get access to inside
I use a putty knife about 2" inward , between the top and the front panel on each side . Give a good hit on one side while slightly pulling the front panel forewafd . Then do the other side . The front panel tilts foreward and hinges on the bottom with tabs . Then lift to remove .
Posted on Aug 02, 2010
Testimonial: "I wish I had asked the question hours ago! Thanks."
honeymokey
  • 3113 Answers
SOURCE: I want to check the drain pump on a Maytag MAH6700
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174143
Posted on Jan 02, 2011
Testimonial: "Schematics helped me determine how to access washer pump from rear not by removing the door and front panel as other internet sites suggested. Thanks!"
How do I access the drain pump on a Whirlpool Duet washing machine model WFW94HEXW2?
Hi Marc,
Unfortunately, access to the pump & filter is harder on the HEXW2 model than the Duets with the removable lower panel.
First you have to remove the lid panel (screws in top rear), then pull slightly rearward and up/out.
Next you'll have to remove the control panel, then remove the front drum boot from the front panel lip. A large diameter thin wire spring holds it in place, located just under the rubber lip edge. Begin the spring removal from a wire tab located toward the lower portion of the lip.
Then remove the door latch screws (IIRC), and the screws at the bottom edge and top of the front panel. The entire front panel must be removed to access the drain filter.
Nov 03, 2014 | Whirlpool Washing Machines
Lost engagement ring in washer dryer
Check the hoses at the base of the water pump.They could stil be there.
Jan 06, 2014 | Candy Washing Machines
Whirlpool wfw94hexw front panel removal
Disconnect power off the wall socket. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. Prop up the front feet of the washer with some small blocks of wood, this will enable access to the screws.
With the screws removed, the lower panel should drop down then come off. If it is jammed just knock it off. Round big screw leads to the filter (be prepared for a lot of water and the usual smelly junk.) which you shd take out and clean. Beyond is the pump which should be examined carefully for any blocking rotation. Refit all carefully.
Pl click helped if helped.
Apr 09, 2013 | Whirlpool Washing Machines
How can I access the drain pump on a whirlpool WFW94HEXW washer when there is no lower kick plate? Does the whole front panel have to be removed including the door?
I just took apart my WFW94HEXW2 to clean the pump filter. Here's how: Take off the top panel by first removing the three screws attaching it to the back of the washer. Remove the detergent dispenser by pulling it out while pressing on the indicated tab. Take off the control panel by removing the four screws holding it. Two screws are Torx-20 where the detergent dispenser was. The other two are at the top of each corner and are 1/4 inch hex-head, as are all the others in this procedure. If you're careful you need not detach the wires from the control panel. Just take the wires our of the first two clips so you have enough slack to rest the control panel on top of the washer. Pop out the spring-loaded retaining wire that's holding the door bellows to the front panel. Remove all seven screws from the front panel, three at the top and four at the bottom. Again if you are careful you need not detach the wires to the front panel. Simply lift the panel off the retaining tabs and swing it out like a door with hinges on the right. Keep slack in the wires and securely prop up the front panel. You now have access to the water pump and filter. The filter unscrews so you can clean it and its holder. Reassembly is a matter of reversing the above steps.
Aug 07, 2012 | Whirlpool Duet: WFW94HEXW Laundry : Front...
Door doesn't open
There is an emergency door release tab/pull ring attached to the bottom of the door lock assembly.
The lower access panel can be taken off by removing the screws and then reaching up under the door lock and pulling downwards on the pull ring. Pull down and then you can open the door.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does it mean when it saids E20
Not draining properly. Remove the lower panel under the door so you can access the drain pump which is located right in front, there's a black hose coming from the tub down to the pump, loosen the ring clap at the top of the hose and pull out the coin filter and clean it out. When you loose that ring clap water will start coming out so keep some towels around.
Dec 06, 2010 | Frigidaire GLTF2940ES Front Load Washer
CLEAN PUMP LIGHT COMES ON WHERE IS THE PUMP LOCATED
The pump is located behind front bottom panel on the right side assuming that your machine is a Whirlpool or Kenmore Front-Loader. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Nov 13, 2010 | Whirlpool Washing Machines
How do you clean out the filter on a whirlpool duet sport washer?
Prop up the lower front edge of the washer or cushion the rear top edge with cloth and lean the washer against the wall for easy access to the three screws securing the lower front access panel to the cabinet. Remove the screws and pull down the lower front access panel to remove it from the cabinet.
Place a shallow pan or lay a towel under the filter to catch the water from the pump. Unscrew the filter from the pump assembly and drain the water. Clean the filter and screw it back into the pump assembly. Slide the lower front access panel up back into the cabinet and secure it with the three mounting screws.
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
165 people viewed this question
Top Washing Machines Experts
