Question about HP OfficeJet Pro L7580 InkJet Printer
To change language on you printer model HP OFFICEJET Pro L7580 follow the following steps:(press "?" then press "7" then Press "OK" then press "1" and then your scroll to the language of your choice o
To change language on you printer model HP OFFICEJET Pro L7580 follow the following steps: (press "?" then press "7" then Press "OK" then press "1" and then your scroll to the language of your choice or press "11" for English In Details 1.Press setup button with "?" sign under the left arrow 2. 2. Press "7" or scroll left of right to # "7" on display and press "OK" 3. Press "1" .. by now you will be asked in English to press "11" for English so you press "11" or chose your preferred language.
  • Ali Mohammad
    Ali Mohammad Mar 19, 2014
  • silver fox
    silver fox Jul 16, 2014
    OR get the users manual from HP and read it.
    New Friend:
    Problem Solver:
  • 6 Answers
You try to read your printers Manual which is in your language or in english !
Posted on Mar 19, 2014
    Top Expert:
  • HP Master
  • 25,360 Answers
Excellent.
3 Suggested Answers
  • 298 Answers
SOURCE: my HP officejet Pro L7580 says the printhead has a problem
Re-insert the print cartridges. It is also possible that the heads are burnt. Get a new set of print heads (black/yellow) and install to the printer. If problem persists, clean the contacts on the printers. Use acetone + cotton swabs.
Posted on Mar 16, 2009
  • 3 Answers
SOURCE: my son accidently changed the language on our HP
Give this a try.
1. Press the button with the wrench icon to enter setup.
2. Press the left arrow next to the "OK" button twice.
3. Press the "OK" button twice.
4. Using the keypad type "11".
5. Using the keypad type "1" to confirm.
6. Choose your region by typing the corresponding code using the keypad.
7. Using the keypad type "1" to confirm.
Posted on Jan 25, 2011
I keep getting error message 388 whenever I fax to any number. I have been able to receive faxes. My all in one is an HP officejet pro L7580
You probably need to run the fax test to check if the fax mechanism is working fine.
Click on Setup Button ( ranch like symbol ) on the printer front panel.
Scroll down till you find Tools ( press ok )
Check for Run Fax Test ( Press OK )
It will print the test results and everything should pass.
To solve your fax issue, follow the steps below.
Check for Advanced Fax Setup ( or Basic Fax Setup ) - Press OK
Look for ECM ( Error correction mode ) - Press OK
Turn the ECM OFF
Try to send fax. It Should work.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 16, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
My son accidently changed the language on our HP Officejet Pro 8500 wireless from english to chinese. How do I change it back?
Give this a try.
Jan 25, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Printer will not recognize new yellow cartridge
While your printer is turned on, please press and hold the # and *. When you see a couple of # and * on the screen, press 1 + 2 + 3, press them one at a time. When you are on the support menu, press the right arrow key twice and look for resets menu and press OK. Press again the right arrow key twice and look for semi-full reset then press OK. Printer should automatically turn off, press the power button to turn it on after 30 secs. Follow the instructions to set the language and the country of the printer.
May 04, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
How to the control panel to English on the HP Officejet 6500. It said press 11 ut it stays in Spanish. Anty
to change language on display to english do this.
press setup 7 times until preferences is displayed
press ok
press ok
press 11 for english
press 1 to confirm
if country is usa press 11 again
press 1 to confirm
Jan 06, 2010 | HP Officejet 6500 Wireless All-in-One...
How to change hp officejet 4355 language option to english
To set your language and country/region
1. Press Setup.
2. Press 7, and then press 1.
This selects Preferences and then selects Set
Language & Country/Region.
3. Press or to scroll through the languages. When the language you want to
use appears, press OK.
4. When prompted, press 1 for Yes or 2 for No.
5. Press or to scroll through the countries/regions.
When the country/region
you want to select appears, press OK.
6. When prompted, press 1 for Yes or 2 for No.
Nov 05, 2009 | HP Officejet 4355 All-In-One InkJet...
HP Officejet Pro L7580 Wireless Connection
YOUR PRINTER IS NOT A WIRELESS PRINTER IT CAN BE USED USING AN ETHERNET CABLE TO THE PRINTER FROM THE ROUTER
STEPS
SETUP>>NETWORK>>RESTORE NETWORK DEFAULTS
SETUP>>NETWORK >>WIRELESS RADIO>>ON
CONNECT THE ETHERNET CABLE FROM THE ROUTER TO THE BACK OF THE PRINTER.
SETUP>>NETWORK >>PRINT NETWORK CONFIGURATION PAGE
INSTALL THE PRINTER
SELECT WIRED CONNECTION
AND INSTALL
IT WILL PRINT.
OR IF YOU WANNA USE AS WIRELESS YOU CAN USE WPUK (WIRELESS PRINTING UPGRADE KIT)
FROM HP.COM HOPE IT FIXYA
Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
I have an HP Officejet Pro 7580. When printing in
Press "set up" button until number 6
Number 6 is "tools"
press OK
press forward arrow (to right of ok button)
No.2 is clean printhead
No.3 is align printer
No.4 is calibrate line feed
Mar 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My hp printer
Introduction There are times when a partial reset may be required to restore the HP All-in-One to proper operation. A partial reset does the following:
  • Reset the user settings to the factory defaults.
  • Reset the language and country/region settings on some models.
Performing a partial reset
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
  5. The HP All-in-One will now be reset to factory defaults.
Thank you so much.
adonscott
Jun 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP OfficeJet Pro L7580 InkJet Printer Logo
130 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
