Question about Samsung YP-U2 MP3 Player
My device has been formated
I want to download my device driver because somebody format it completely but I haven't its cd
How can i format my computer
insert a CD/DVD copy of windows into your disk drive, then just follow the online screen guide.
You must first set your bios settings, the first boot should be the CD/DVD rom drive then your hard disk. Re-start your PC and press any key once it show during command prompt display.
Hope it helps..
Sep 09, 2011 | Compaq Presario Notebook
How to reformat my windows xp computer
OK get into system BIOS, prees DEL. F2, or whatever your key is. Set in the BIOS to Boot the DVD FIRST, Then insert you DVD, Boot off your Windows DVD, & install from, the DVD, go through the setup to where it asks you if you wish to FORMAT, choose FULL NTFS Format and let it complete, then proceed with the install, done.
Feb 21, 2010 | Microsoft Windows XP Professional SP2
EMachine T2778 new hard drive, restore disk aren't working, how do I format?
1st Option: Go to BIOS level and select the CD/DVD device is the first device for boot option and then insert the recovery CD/DVD to format or install OS.
2nd Option: If recovery CD/DVD got curropted and you are having the other OS CD/DVD, then try to load and format or install the OS. Also try to download the recovery image from vendor website.
Revert back for more assistance.
Jan 31, 2010 | E-Machines eMachines Desktop PC
I need to format the laptop
If you do not have the drivers for the devices that are installed on your laptop, then download from the IBM/Lenovo WEB site, make sure they are for your model laptop (eg. Video, audio, modem LAN etc.) before you format and reinstall Windows..
Follow these steps.
1. Boot up the laptop and press F12 function key to get a list of boot devices, select the CD drive.
2. Insert your Windows XP CD into the CD drive.
3. Press the space bar to start the bootup from CD
4. During the install process you delete the existing partition/s and create a new partition.
5. The next step is to format the partition - do a NTFS full format not a quick format
6. Follow the instructions to install windows.
7. After Windows completed the installation ,check on which device drivers didn't install and install these drivers.
Feb 05, 2009 | IBM ThinkPad R52 Notebook
Format
Hi
two options
  1. The original restore dvd / cd can be used to format and restore the computer to the original state it came on.
  2. Use the windows installation cd, format the hard drive during the setup and then continue with installing windows, at the end you will need the device drivers and those are available at http://support.acer-euro.com/drivers/downloads.html
Jan 29, 2009 | Acer Aspire 5315 Notebook
I want to format my computer but i don't have driver cd
Before formatting download all the drivers or your devices from the manufacturers websites. Save them to a cd or dvd to use after the format. Hope this helps.
Jan 23, 2009 | Computers & Internet
Gigabyte motherboard cd
You do not not need your motherboard CD to preform a format on your drive. Any windows CD. Win XP home, XP Pro, Win 2000 will format your hard drive. You can also use the hard drive's Mfg's utility disks & creat a bootable floppy disk or creat a bootable CDROM disk that will not only allow you to format the hard drive but also fun testing on the drive. You can even pick your cluster size & FAT file. Write down the name of your drive & model no#. Go to the Mfg's web site & download the utility software. Chances are Windows will have most of your boards drivers in it's data base. All you'll need to do is download from Gigabyte your missing drivers. You'll need you complete model no# & version no# if you can find it.
Mar 12, 2008 | Intel Motherboard
Samsung YP-U2 MP3 Player Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
