How do I remove the "Non-system disk or disk error" message on HP Compaq nc6400?
  • 2,072 Answers
That error means either your hard has failed, has bad sectors or the operating system has corruption. Worst case you will need to replace the hard drive and re-install everything. Best case you will need to re-install everything again. You could try and run a program called Sea Tools to attempt and repair bad sectors on the drive.
Posted on Mar 19, 2014
  • 13 Answers
SOURCE: message on screen
do you have a floppy disk in it? or is it set to boot from the cd drive, with a non-bootable os disk in it?
those errors usually happen when you computer does not find a os system in the device it is set to boot from. Try setting it to boot from the hard drive.
Posted on Dec 07, 2007
Pterocarpous
  • 202 Answers
SOURCE: issues with my compaq armada
Hello Mitchiko
This error message is often the result of corruption on your hard disk. Quite likely including the MBR.
This could indicate your hard disk is failing or just that there was a glitch in your system that caused your MBR to be over-written or corrupted. In any event, w/ an error like this, you're going to need to ...
(01) Test your hard disk to make sure it's OK
(02) Attempt to restore your MBR
There are some great (free) MBR tools HERE.
There's a nice article HERE on "How to Repair your MBR". The author does a nice job of explaining what the MBR is and how to repair it.
Please, let us know if this response was helpful for you or, of course, if you have more questions, etc. on this topic.
Thank you
BJ
Posted on Apr 04, 2008
SOURCE: compaq evo 610
Turn it all the off. Then pull the hard drive out and put it back in again. Now, put your system disk (Win XP?) into the drive and turn the laptop on. It should do something else now. I have had this happen on several laptops I have rebuilt and it takes patience to get them started sometimes.... I have managed to load XP onto all of them eventually!
Hope this helps
  • 489 Answers
SOURCE: non-system disk or disk error
Your laptop isn't seeing your hard drive to boot up the system. You need to replace the hard drive.
Posted on May 29, 2009
pankaj_dic
  • 1252 Answers
SOURCE: non system disk error or disk error when turned on
this happen when the computer does not detect the hard disk, check the cable and power connections of the hard disk
Posted on Sep 03, 2009
Non system disk or disk error replace and strike any key when ready hp compaq 6730
its asking for its bootup disc.
it sounds like some one has tryed putting its windows disc in but then stopd it before it was finished doing its work.
has some one tryed installing windows?????
Jun 27, 2014 | HP Compaq Evo Notebook N600c
C00021A Fatal System
https://www.youtube.com/watch?v=1C9oIsK5CCk
Sep 29, 2017 | HP Compaq nc6400 Notebook
I did a self test on my hp compaq nc6400 and got a read failure message.is this my hard drive.does it need to be replaced
First thing, back up all of the files that you want to keep onto either an external drive/stick/disc etc as read failures relate to hard disc drive read/write errors within specific clusters or sectors. You may get away with replacing the drive for the moment but your best bet is to run CHKDSK which will require a reboot as its a DOS utility and then run disk defragmenter which can be found in the system tools folder within Windows Vista. This will take quite a long time depending on the size of the drive but it should find any damaged clusters/sectors and quarantine them so that the installed applications don't write any files to these areas. If the however the drive starts clicking and excessively whirring
Apr 12, 2011 | HP Laptop Keyboard for HP Compaq NC6400...
I got a message that reads Non-System disc or disc error replace and strike any key when ready. What do I do?
Here the reason why youre getting the error message
Remove the non-system disk from your boot device. For example, remove the non-system disk from the floppy drive or the CD-ROM drive.
Change your computer's boot sequence in you Bios. Make sure that you select a device that has boot files (or operating system files) installed.
If you start your computer from a hard disk drive, install a bootable operating system (such as Windows XP, Vista or Windows 7) on the drive.
Thanks for using Fixya
Jan 24, 2011 | Compaq Evo N620c Notebook
Message appears : Non system disk or disk error replace and strike any key when ready during start up.
a) You have a disk in the floppy drive or CD and the computer is trying to boot from that drive. Remove disk and reboot computer. Or ...
b) Your hard disk has failed
Or ...
c) Your operating system is damaged.
Apr 05, 2010 | HP Compaq 6720s Notebook
it seems that your hard disk is not getting in to Operating System. All you need is to check your drive thoroughly and reinstall OS....reason could be any thing, may be some virus has deleted system files or your drive may have develop some bad sector...
Nov 23, 2009 | HP Compaq nc6000 Notebook
USB error message
you might need the intel chip set drivers available from HP ... sometimes you have to remove the USB ports in Device Manager .. then reboot .. that will reload the USB drivers ..
here is a discussion about that problem
http://forums13.itrc.hp.com/service/forums/bizsupport/questionanswer.do?prodSeriesId=1847703&prodTypeId=321957&threadId=1217468&admit=109447627+1258886634148+28353475
Nov 22, 2009 | HP Compaq nc6400 Notebook
This error can be a couple of things. If the "boot block" on the disk has become faulty, the system won't recognize that the disk has an operating system on it and will generate this error message. If the disk is defective completely, the same error will occur. If you have a boot floppy or CD, try re-writing the boot block on the disk. If that fails to resolve the problem, the disk is defective and will need to be replaced.
Dan
Feb 25, 2009 | Compaq Computers & Internet
Computers & Internet Logo
David Payne
David Payne
