Question about Refrigerators
Zanussi zx97 5si diagnostic codes
The freezer on my Zanussi zx97 5si is defrosting and the temperature alarm keeps going off, i have tried to get a diagnostic code (switch of then press all buttons until it flashes) and i get 4 flashes, what could the fault be?
SOURCE: Freezer alarm keeps going off..
Mate prehaps the defrost element could be burntout thus no auto defrost and the big freeze and the alarm, when you switch off the defrost starts and the alarm resets?
Posted on May 03, 2008
22yooper
  • 828 Answers
SOURCE: When I come home the
Could be warning you that the condenser coil is in need of cleaning. Under front by toe plate or in the back under fiber cover. Vacuum out all dust and make sure the air circulation fan is running when the compressor is in operation.
Posted on May 15, 2008
SOURCE: Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Posted on Sep 01, 2008
  • 531 Answers
SOURCE: samsung model ss22wg1/sja freezer not freezing .
you may have defrost problem
Posted on Apr 07, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have an fisher and
Hi and welcome to FixYa, I am Kelly
You should enter the diagnostic mode to determin your fault:
Diagnostic Mode
To enter diagnostic modes, press and hold the MENU button
- then press the UP button for 4 seconds. The PC temperature
will be displayed on the LCD. The actual temperature of the PC is
shown. Note Temperatures are shown in Degrees Centigrade.
PC Sensor Temperature ____
- By pressing the Up button once more, this
will indicate the FC sensor temperature. Note: The "min" indicates minus 12°C
FC Sensor Temperature
- By pressing the Up button once more, this will indicate the Defrost sensor temperature.
Defrost Sensor Temperature
- By pressing the Up button once more, this will indicate the input/Output Status.
Input/Output Status
- Press UP one and two more time, both LCDs display 87.5 but should be ignored
Spare/ Blanks
- Press UP one more time and fault history will be shown.
Fault History
To exit diagnostic mode press MENU button
FAULT CODES:
A wrench symbol and LCD fault code will appear automatically if there is a fault in the
temperature measuring system, defrost system, fans or low ambient heater.
When the PC door is opened an alarm will sound, the number of beeps also indicates
the fault code. Pressing any of the control buttons can deactivate these alarms
Fault Code 1
Reason: On last power up, the power module failed self test.
Primary Action: Replace power module
Fault Code 2
Reason: The previous 2 defrosts were aborted after 30 minutes
Primary Action: Check defrost element
Fault Code 3
Reason: The resistance of all the temperature sensors is outside the normal range
(>45K Ohms)
Primary Action: Check 6 -way Rast connector at power module
Fault Code 4
Fault Code 5
Reason: The resistance of the FC sensors is outside the normal range (>45K Ohms)
Primary Action: Check sensor connector at power module
Fault Code 6
Fault Code 7
Reason: The resistance of the Defrost sensor is outside the normal range (>45K Ohms)
Fault Code 8
Fault Code 9
Reason: The resistance of the PC sensors is outside the normal range (>45K Ohms)
Fault Code 10
Fault Code 11
Reason: The current for the LAH, PC &FC Fan is lower than expected
Primary Action: Check the 6 way fan/LAH, connector at module.
Fault Code 12
Reason: The current for the LAH, PC &FC Fan is higher than expected
Fault Code 13
Reason: LAH is drawing less current than expected.
Primary Action: LAH open circuit
Fault Code 14
Reason: LAH is drawing higher current than expected.
Primary Action: Check wiring connection
Fault Code 15
Reason: PC fan is drawing less current than expected.
Primary Action: PC fan open circuit
Fault Code 16
Reason: PC fan is drawing higher than expected current
Primary Action: Check fan wiring or connections
Fault Code 17
Reason: FC fan is drawing less current than expected.
Primary Action: FC fan open circuit
Fault Code 18
Reason: FC fan is drawing higher current than expected.
Primary Action: Check FC fan & wiring circuit
There are also Ice maker faults that are NOT included above. This should get you started and if everything passes above diagnosis the problem is most likely in your ice maker circuit. The reason I did not include ice maker faults is because they do not cause alarms.
Thanks for choosing FixYa,
Kelly
Posted on Mar 15, 2011
Why is Zanussi frost free freezer alarm always flashing
Because it does not achieve the correct temperature (for example: -18 degrees centigrade).
For a more precise answer I need more information.
A lot of things may be incorrect:
- Doesn't work defrosting cycle
- The cooling fan is not working
- Too much ice on the evaporator battery
- Faulty thermostat or NTC sensor
- Faulty cooling system (gas leak)
- Compressor
- Electronic
Dado
Aug 26, 2014 | Zanussi Freezers
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
Oct 14, 2013 | Zanussi 14.62 cu. ft. / 414 liter Chest...
Fridge temperature rising - currently at 10 degrees. Internal temperature alarm not being triggered. Freezer not affected. Motor running when door opened/closed.
Although I have never worked on a Zanussi unit, from what you have said it is a classic frost build up in the cooling tubes, which is usually a result of defrost system failure. To verify this you can manually defrost your unit. If the problem goes away, then you need to troubleshoot your defrost circuit, because it will be back in days or weeks.
Sep 14, 2011 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi fridge freezer alarm keeps sounding
If the refrigerator and freezer are both working properly. Then the only problem would be the alarm, It's either the placement of the alarm thermometer or the alarm thermometer is stuck closed.
Mar 15, 2010 | Freezers
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Kenmore upright freezer
you have a defrost system problem. Could be the defrost timer or defrost heater or defrost thermostat. Bottom filled with ice could be from a plugged drain system. Where you termed "condenser coil" is in reality the "evaporator coil".
May 24, 2008 | Zanussi ZEBF250W Bottom Freezer...
Apr 28, 2008 | Refrigerators
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Power light flashing on & off
Try to unplug and plug the power cord this may help, flashes is an error code. Try also the defrosting, error codes alarm the owner if there are some abnormal operation int the unit.
Jan 08, 2008 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
