Question about Lands Phones
Samsung idcs 8d
Mailbox isnt turned on, how do i turn on again
When calling voicemail I receive a message after entering my access code that states "I'm sorry, I can't talk to you right now"
this means the voicemail card is full. look at all extensions mailboxes or a general message mailbox and delete all the messages and try again. If it is no good still you will need to get in the admin mailbox and change your mailbox to allow messages.
Apr 05, 2016 | NEC Dterm 80 Phone Dth-8d-1 bk Tel 780571...
How do I fix the voicemail from keep calling back
Delete the mailbox, and re-install it. Then re-record all your outgoing messages.
Oct 20, 2015 | Samsung Falcon iDCS 18D Display Phone with...
How do yo block a number on samsung idcs 28d?
^67 then dial the number. Test it out first by calling a phone of your own with caller ID. Also try turning off the "Show Caller ID" in the settings.
Aug 05, 2014 | Samsung Falcon iDCS 28D 28-Button Keyset...
How do you reset the password on a Samsung iDCS 28D
From the Subscriber Services Menu, Press [#] [7] [1] ....you will then hear the old password XXXXX you will be able to change it...
The Manual for a typical Samsung iDCS system is available here....
http://www.samsungidcsphonesystems.com/pdf files/idcs 16/iDCS_16_user_ins.pdf
Jul 20, 2012 | Samsung Falcon iDCS 28D 28-Button Keyset...
MY WHOLE SAMSUNG IDCS PHONE SYSTEM WAS RESET BY ACCIDENT BY OUR PHONE GUY AND NOW ONE OF MY EXTENSIONS CAN NOT GET INTO HER VOICEMAIL BOX TO CHECK HER MESSAGES, AND DOES NOT BLINK TO TELL HER SHE HAS...
Hopefully you have sorted this issue by now but if not it sounds like you need to programme a VMMSG button on a softkey on her phone. I have posted you instructions on how to do this, 'abbeytel' have over 60 training videos on YouTube relating to the IDCS phone system. - Alison
Apr 13, 2010 | Samsung DCS 12 Corded Phone
I have a Samsung iDCS system. We have a phone
This clip shows how to add a phone to the group, so just reverse the process to remove a phone from the ring group on Samsung iDCS. This also works on other models from Samsung. There are loads more clips at www.AbbeyTelecom.com which you may want to "bookmark".
Oct 12, 2009 | Samsung DCS 12 Corded Phone
Samsung iDCS 28D Voicemail Problems
If you have administrator access use the following steps to change the code:
Access the Administratin Main Menu and select 4 for mailbox programming.
Select the mailbox to program. Dial option code 1402. The current value will be played. To hear the current value press 1, to enter a new value press 2, to hear the range of valid values press 3. Press 2 to enter new value. Enter the access code for the mailbox. The value you entered is played back. Press1 to save or 2 to re-enter. Press 3 to exit without saving. Press # to exiit or hang up.
Aug 03, 2009 | Samsung DCS 12 Corded Phone
How do i reset password or passcode on a phone that has not been used?
You need to access the system manager mailbox to change passwords and mailboxes. this is done from dialing auto attendant than dialing 632 and entering the password for that mailbox if asked. There is a setting for change mailbox in there. Just listen to her and remember 1 always =yes and 2 always = no
Jun 15, 2009 | NEC DTU 8D-2 Corded Phone
Lands Phones Logo
18 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
