Question about Electrolux EI26SS55GS Stainless Steel Side by Side Refrigerator
Fridge keeps powering on and off
Control panel turns on for about 3 seconds, then turns off for 3 seconds, then back on again. This cycle continues with almost the same consistent amount of time on and off, about 3 seconds. Then eventually it will stay on.
  • Seth Burke
    Seth Burke Mar 23, 2014
    Robert, I figured as much, but I'm also curious if there is something else causing the board to short out. I had replaced the controller board within the past 2 months when I had this same issue before. The new board fixed the problem until the breaker for the circuit that the fridge is on was flipped by accident (fridge is on it's own circuit). Are these boards really that sensitive?
  • Seth Burke
    For example, could the Main Control Board that is located under the fridge be part of the problem? Every once in a while I will get the error message "CE", then have to unplug the fridge and plug it back in to reset
  • 356 Answers
Your controller board is about to die. Call an appliance repair center and see if the board is user replaceable. Be prepared for sticker shock, the part is going to be expensive, unless it is under warranty.
Posted on Mar 19, 2014
  • Official Brand Answer
  • 4,342 Answers
Robert, thank you for the response, the control board could be the culprit. Seth, I would however suggest performing a factory default reset prior to contacting a local technician. The factory default resets all refrigerator settings such as temperature, temperature display and ring tones to their factory default settings. Simply press and hold the factory default option that is located above the fridge temp display. In the event the reset does not resolve the concern with the display, please use the link below to locate an authorized technician in your area to properly diagnose and repair your refrigerator.
http://www.electroluxappliances.com/Owner-Support/Service-Locator/
Thank you,
AP
  • Seth Burke
    Once i track down a new board, I will perform all of the cleaning and such recommended, I'm sure it has not been done in quite some time.
Washer repeats entire cycle - does not stop at end of spin cycle.
It is possible that presence of moisture within the START button can trigger the cycle to continue as it keep the processor to continue the wash cycle,Hence you must remove the panel and board after disconnecting the wiring harness and use a hair dryer to warm off any presence of moisture on the panel and board. Do it with time to ensure there is no moisture within the panel.
I think this must solve the issue. Repeat the work many times as sometimes moisture and dirt together might form a conductive bond to trigger as a pressed on switch. If possible open panel to clean switch pad.
Jan 23, 2013 | Kenmore 2.1 cu. ft. Compact Portable...
Top drawer on F&P dish drawer stuck on cycle & continuously beeping
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
Dec 17, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Xerox WorkCentre C2424: turned on, runs thru tests, initializing and then shuts off and starts the cycle again. The cycle continues but never resolves.
1. Power machine off and wait until completely off. 2. unplug power cord from wall. 3. with power cord STILL DISCONNECTED turn machine on and off again. 4. WAIT 60 SECONDS 5. plug power cord back in and turn back on
If this does not resolve the issue call for service.
Hope it helps!
Feb 09, 2011 | Xerox C2424 Copier
My fridge keeps beeping even though the door is shut. The fridge temperature indicator keeps going up and then down. Can you please tell me what's wrong?
If the reset procedures don't stop the beeping and you are out of warranty, here is an easy fix:
1- (You can unplug the fridge just to be cautious, but not necessary.) Remove the control panel from the front of the fridge. Mine pulls straight out without removing any screws.
2- On the back of the control panel is a black, round device - the only thing that pokes through the back of the panel. This device is small, maybe 1/2" in diameter and the same deep. (if it won't pop off easily, remove the 4 screws to remove the back cover for easier access.)
3- You will see a thin round disk inside. This is the speaker. Remove this disk, press the black speaker cover back on and press the control panel back into the front of the fridge.
All the controls will continue to work as before, but NO BEEPS!
Yea!
Nov 08, 2010 | Samsung RS2630SH Side by Side Refrigerator
Top refrigerator warm bottom is ice cold.
An automatic defrost time turns the defrost cycle on and off every 24 hours. If problem continues, problem is most likely defective defrost timer.
Even electronically controlled units often have electro-mechanical timers for defrost cycle.
Jun 15, 2010 | Amana ABB1927DE Bottom Freezer...
Evaporator coils ice up after a few days and the refrigerator comparment only stops cooling. The unit is 2 years old. When removing the backing from the inside of the fridge and after thawing out the coil...
I have some information on your model and that would involve forced defrost by the service manual page 28 at bottom. How old is your Samsung? Forced Operation Function (Pull-down / Refrigerator Defrost / Refrigerator . Freezer-Defrost / Cancellation)
● This function enables a pull-down mode, a defrost mode for the refrigerator only, a defrost mode for the freezer and the
refrigerator at the same time, and a cancellation of this function.
● Press Power Freeze and Fridge Temp. buttons for 8 seconds simultaneously to get in the ready mode for a forced
operation.
● The display panel will return to normal after 20 seconds in the ready mode.
● At the ready mode, press any button(except Ice Type and Child Lock) once to start a pull-down operation, twice for a
defrost cycle for the refrigerator, three times for a defrost cycle for the freezer and the refrigerator, and finally four times
for cancellation of this function.
● Another way to cancel this function is to simply plug out and in the power cord.
1) Pull-down
1-1) At the ready mode, press any button once then the buzzer will beep (ON for 1/2 second and OFF for 1/2 second)
until this mode is cancelled.
1-2) At this pull-down mode, the compressor will start immediately (No 5 minute delay) and if the system is in the
defrost cycle, it will be cancelled right away.
note) If this pull-down mode begins right after the compressor was off, the compressor may not start to run due to an
overload condition.
1-3) At this mode, the compressor and freezer fan will operate continuously for 24 hours and the refrigerator fan will be
on and off according to the set temperature(34℉)
1-4) After 24 hour operation, the system will be cycled at -14℉ for the freezer and 34℉ for the refrigerator.
1-5) In order to cancel this mode at any time, select the next mode on the ready mode or power off the system.
2) Refrigerator Defrost / Refrigerator . Freezer-Defrost operation
2-1) At the pull-down mode, press any button again on the ready mode to begin the defrost cycle for the refrigerator.
2-2) The beep sound continues for 3 second at the beginning, then ON for 3/4 seconds and OFF for 1/4 second until
this mode cease.
2-3) After this operation, the system will come back to normal operation.
2-4) At this mode, press any button again on the ready mode to operate the defrost cycles for both compartments.
2-5) The beep sound continues for 3 seconds at that time, then ON for 1/4 second and OFF for 3/4 seconds until the
defrost operation cease.
3) Cancellation
3-1) At the R,F-Defrost mode, press ant button again on the ready mode to return to a normal operation.
3-2) Simply unplug the power cord, then plug it again to return to a normal operation.
Press both button for 8seconds at the same time Send maual in one moment, Thanks, Sea Breeze
Jan 20, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Hello, I have a samsung side by side fridge freezer (SRS597NP) that keeps icing up the fan and coils behind the bottom two draws of the fridge. It ices up that much that the fan hits the ice and makes a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Dec 27, 2009 | Refrigerators
I have to keep the temperature turned up to 9 in order to keep the food at 45 degrees. The fridge is only 3 years old.
If it's the freezer control you keep at 9, it's probably a defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If it's the fridge temp control you're talking about The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 15, 2009 | Refrigerators
Status light blinking red
please follow the steps given below to power cycle and reset the product.
Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product..
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
  • If the copy job is successful, you do not need to continue troubleshooting.
Reset the product Follow these steps to reset the product. Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
May 22, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Power issues. turns on than cycles off and on till you turn back off.
Sounds like something is shorted. Don't keep trying to turn it on it will most likely either ruin the Power supply or something else. Have someone qualified look at it. Good luck. Jay
Jul 29, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Electrolux EI26SS55GS Stainless Steel  Side by Side Refrigerator Logo
273 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
