Question about Planet Audio AP3000D Car Amp
Replacing Planet Audio RDX1000
I am looking to replace a Planet Audio RDX1000. What Planet Audio amp is a close replacement for the RDX1000. Thanks
  • Ryan B
    Ryan B Mar 20, 2014
    The RDX1000 is a older Planet Audio amp 1350 watt mono D. I am looking to replace it with a new Planet Audio amp I just don't know which line of amp to go with. The Anarchy line seems to be getting some bad reviews. And the Axis I can't find any reviews on them. Also the Big Bang ,Sphere,and Torque lines there are just to many lines to choose from and not enough info on them. Any input on any of Planet Audio amps would be very helpful good or bad thanks.
2 Suggested Answers
pctech1
  • 1940 Answers
SOURCE: MY AMP TURNS ON BUT NO AUDIO OUTPUT TO MY SUBS! I
First, test your sub terminals for an Open connection, or no resistance. This is to test if your sub is blown. This is usually the case.
Double check your wiring, not only to the sub, but from your headunit to your sub. Make sure your headunit is configured to work with your amp, if you have a setting for this (for instance, SUB: ON).
Posted on Jul 14, 2010
My planet audio px4000d amp powers on but green or red light dont come on
disassemble check internal fuse or for burned track also recheck the antenna connection -the thing that powers the amp on.Use a multimeter to test different points to ground potential. the one that doesnt have it has the problem.
Jun 22, 2014 | Planet Audio PX4000D Class D Monoblock...
Telefunken TLC037fhda no sound picture good
take a look at the speaker,use a multimeter see if the speaker have the rated resistance.( eg .8 ohms) if speaker bad replace if.if speaker good. see if your audio amp is getting power (multimeter needed) set to d.c volts.have voltage then look for the input pin that brings audio into the amp,use a 16 -32 ohms speaker across gnd pin and input pin(bring volume up hi on tv) if audio replace audio amp.
(also look for cold solder) on p.c board before replacing amp.
May 23, 2014 | Televison & Video
Wiring diagram for P9720
Planet audio 9720 screen blank bit button light up wat I need to do to fix it
Mar 18, 2014 | Planet Audio P9725B / P9720 Car Video...
Why this planet audio protection light always comes on when i turn up the car audio
The amp in question is a very entry level amp. Meaning it needs to be ran at moderate ohm load. And have plenty of power to feed it. Check your grounds. Pos. Etc.
Feb 03, 2013 | Planet Audio AC1500.1M ANARCHY CLASS AB...
I am wondering about car amplifiers, I don't know what kind to get, I have Alpine 6.5" 2-Way Car Speakers (SPS-600), 80 watt as my front speakers, and Alpine 6 1/2" 2-Way Car Speakers (SPR-17C), 100 watt...
I would strongly recommend that you get a 5 channel amp that puts out 75watts rms per channel that will deliver between 200-300 watts to the sub channel. I use planet audio amps myself and they run strong all day every day-maybe you could look at a planet audio vrx 600.5(5-channel) it throws 100w x4 and 200 or 300 to the subs depending on the resistance of the sub. Good luck
Jan 27, 2010 | Car Audio & Video
Cuando lo conecto SE VA A corto
el mio tambien es un planet audio rxd2400 monoblock y me dicen que se proteje de echo donde lo lleve tenian otros dos iguales descompuestos de lo mismo osea ya son 3 no se si alguien sabe decifrar como reparar estos amplis mi correo para algun dato que sirva mmgl_angg@hotmail.com
Nov 22, 2009 | Planet Audio VX3002 Car Audio Amplifier
Problem when hooking two 12 inch subs to one amp
the amp is no where near strong enough that sound you hear is called hard clipping and it will destroy your subs in minutes. depending on what model JL subs you have I can sell you a better amp.
Dec 30, 2008 | Planet Audio VX602 Car Audio Amplifier
Planet audio vx3002
Sorry wayne2953 but this amplifier isn't stable @ 1ohm loads. This amplifier would be better suited running a pair of 12's, 4 12" subs could run if configured correctly but the subs would be underpowered and probably not sound very good.
Features of Planet Audio VX3002:
  • Max Power (2 Ohms) : 300W x 2
  • RMS Power (4 Ohms) : 150W x 2
  • Bridged Power (4 Ohms) : 600W x 1
  • Signal-to-Noise Ratio : 102dB
  • Frequency Response : 20Hz-20kHz
  • Dimensions : 10-5/8"W x 2-7/16"H x 16"L
Mar 31, 2008 | Planet Audio VX3002 Car Audio Amplifier
Kole audio q1-3000d
This amp is similar to many of the planet audio class D amplifiers. These amplifiers have quite a few problems. If the amplifier has failed, it needs to be serviced by someone who is familiar with the amplifier.
Do not repeatedly replace the fuses. It will lead to more damage and a more expensive repair.
Nov 12, 2007 | Kole audio Q1-3000D Car Audio Amplifier
Planet Audio AP3000D Car Amp Logo
Top Planet Audio Car Audio & Video Experts
Tygh Duval
Tygh Duval
michael galang
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
