Question about Symbol MC9060-G
Increase backlight time
Make backlight stay on longer
  • Official Brand Answer
  • 3,100 Answers
Hey there
Contact Motorola Solutions Get Support or Zebra Technologies Support Downloads for assistance.
Mark
Motorola Mobility Support
Posted on Jan 20, 2015
How should i activate gps on my samsung wave and how to download maps for it?
first increase your backlight time say 3 minutes
then goto settings --> connectivity-----> location --------> enable all GPS service(check to green light)-------> then my location ....
stay outside any building u should get activated in 4to5 minutes
Sep 04, 2010 | Samsung Cell Phones
How do you get the keyboard lights to stay on? They come on and off at will.
For you to extend your keyboard lightening time, please do this;
1. Click on the Home button > Options > Screen/Keyboard > Scroll to Backlight Timeout increase to the highest probably 2minutes. This should should keep your backlight on for as long as 2 minutes before it goes off.
This should do.
Regards
Jan 25, 2010 | RIM BlackBerry Bold 9700 Smartphone
Screen goes black but still sound
This is inverter or backlighting problem. Can you try switching it on and off quickly for a couple of times and tell me if these '2 seconds' get any longer'. If picture stays longer and longer before shutting down, one lamp needs replaced-if not, please replace inverter board
Jan 15, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
How do I set the monitor so the menu will stay on long enough to change it?
There should be a setting in the monitor menu listed as OSD (On Screen Display). Try increase the length of time for it to stay on longer.
Nov 09, 2009 | X2Gen MG19MY 19" LCD Monitor
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
Philips GoGear HDD086/05 backlight will not stay on
go to the settings on the mp3, go to backlight and set light to "always on".
May 20, 2009 | Philips GOGEAR SA6045 MP3 Player
Dell monitor 15 inch the green light stays on but no picture
It's the backlight supply tripping out from backlight failure, but the thing still stays on. I got it to act right by switching to factory presets with some fast menu action once, but the general solution is going to involve tricking the backlight into staying on; you can look at the thing in bright ambient light to see that the display is still working, but of course without a backlight it's pretty much useless.
Since $100 buys a better and more efficient monitor, just replace it; otherwise of course you can either replace the backlight (or go for one of the projector mods) or convince its drive circuit to put up with it a bit longer. I spotted a bad capacitor but swapping that out hasn't gone well yet....
Mar 14, 2009 | Dell E153FP 15" LCD Monitor
Is there anyway to troubleshoot or fix the backlight on my blackberry curve myself? The backlight wont turn on.
You can go into setting and change the settings so the backlight stays on longer. But the back light Does come on when you first switch the device i.e. take battery out and back in.
hope this helps,
Thanks.
Mar 07, 2009 | RIM BlackBerry Curve 8310 Smartphone
Tocco backlight not staying on.
Menu > settings > display and light settings > light settings > backlight time > dim> change time till dim upto 3 mins. back >on >change time light stays on .
Jan 18, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Symbol MC9060-G Logo
53 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
